13 Replies Latest reply on Oct 22, 2009 10:30 AM by WillProd
    PPro 1.5 media encoder cutting black off edge
    WillProd
      When trying to encode a short vid in PPro 1.5 using the Mpg2 encoder, a good portion of the right side of the video is cut off or clipped or covered over by black.  I don't understand why it is doing this.  When I just render a normal movie with the *.avi raw video there is not black cut off.  Any ideas?  Plus is there a very good article that will help me to understand the complexities of streaming video?
        • 1. Re: PPro 1.5 media encoder cutting black off edge
          Jim_Simon Level 8
          My first guess on this one is operator error.  You did something wrong.
          Without more information, however, that can be only a guess.
          • 2. Re: PPro 1.5 media encoder cutting black off edge
            the_wine_snob Level 9
            Welcome to the forum.
            Now, some questions:
            1.) What is your Project Preset?
            2.) What is your source footage (full details please)?
            3.) What are your full Export settings?
            It is most likely that something in those will give the clue as to what is going wrong.
            • 3. Re: PPro 1.5 media encoder cutting black off edge
              WillProd Level 1
              Video Summary:
              Codec: MainConcept MPEG Video
              Quality: 5.0 (high quality)
              TV Standard: NTSC
              Frame Rate [fps]: 30
              Field Order: None (Progressive)
              Aspect Ratio: 16:9
              Profile: Main Profile
              Level: High Level
              Frame Width [pixels]: 864
              Frame Height [pixels]: 480
              Bitrate Encoding: VBR, 2 Pass
              Minimum Bitrate [Mbps]: 4.0000 (low quality)
              Target Bitrate [Mbps]: 8.0000 (low quality)
              Maximum Bitrate [Mbps]: 10.0000 (low quality)
              M Frames: 3
              N Frames: 15
              Closed GOP every: 0
              Automatic GOP placement: On
              Macroblock Quantization: 10
              VBV Buffer Size [2Kbytes]: 488
              Noise Control: Sensitivity
              Noise Sensitivity/Reduction: 5
              Write SDE: No
              Force VBV Delay: 0xffff
              Intra DC Precision: 9 Bits
              I Frame Settings:Intra VLC Format: Table 1
              P Frame Settings:Intra VLC Format: Table 1
              B Frame Settings:Intra VLC Format: Table 1
              I Frame Settings:Frame Prediction DCT: Frame
              P Frame Settings:Frame Prediction DCT: Frame
              B Frame Settings:Frame Prediction DCT: Frame
              I Frame Settings:Quantization Scale Type: Non Linear
              P Frame Settings:Quantization Scale Type: Non Linear
              B Frame Settings:Quantization Scale Type: Non Linear
              I Frame Settings:Scanning Pattern: Zigzag
              P Frame Settings:Scanning Pattern: Zigzag
              B Frame Settings:Scanning Pattern: Zigzag
              Write Sequence End Code: Yes
              Embed SVCD User Blocks: No
              Ignore Frame Interval: 0
              Reaction Parameter: 0
              Initial Average Activity: 0
              Initial Complexity Measure: 0
              I Frame Settings:Initial Virtual Buffer: 0
              P Frame Settings:Initial Virtual Buffer: 0
              B Frame Settings:Initial Virtual Buffer: 0
              P Frame Motion Vectors - Forward Search Width: 127
              P Frame Motion Vectors - Forward Search Height: 120
              B Frame1 - Forward Search Width: 70
              B Frame1 - Forward Search Height: 40
              B Frame1 - Backward Search Width: 127
              B Frame1 - Backward Search Height: 80
              B Frame2 - Forward Search Width: 127
              B Frame2 - Forward Search Height: 80
              B Frame2 - Backward Search Width: 70
              B Frame2 - Backward Search Height: 40
              Motion Estimation Type: 11
              Do Half Pel Search: On
              Online Encoding: Offline
              Encoding Level: 31
              here are my exact export settings... I've exported video using this settings before and got a video that was perfect.  But maybe i changed something and don't realize it.  i'm using raw footage i shot from an XL2, mostly.  My Project is 30drop frame, interlaced. 720x480 ntsc dv widescreen
              • 4. Re: PPro 1.5 media encoder cutting black off edge
                Jim_Simon Level 8
                I don't see the Pixel Aspect Ratio listed in your settings.  Make sure that's at 1.0.
                • 5. Re: PPro 1.5 media encoder cutting black off edge
                  WillProd Level 1
                  The pixels need to be square?
                  • 6. Re: PPro 1.5 media encoder cutting black off edge
                    Jim_Simon Level 8
                    In this case, yes.
                    • 7. Re: PPro 1.5 media encoder cutting black off edge
                      WillProd Level 1
                      not true... i've encoded mpeg2 before.  I was creating demos for the web and my initial one work just fine... this second one isn't turning out and i don't know why.  I've used 16:9 pixel ratio before.
                      vid that isn't working:
                      <object width="400" height="224" ><param name="allowfullscreen" value="true" /><param name="allowscriptaccess" value="always" /><param name="movie" value="http://www.facebook.com/v/170284442680" /><embed src="http://www.facebook.com/v/170284442680" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="400" height="224"></embed></object>
                      vid that is working:
                      <object width="400" height="224" ><param name="allowfullscreen" value="true" /><param name="allowscriptaccess" value="always" /><param name="movie" value="http://www.facebook.com/v/168478697680" /><embed src="http://www.facebook.com/v/168478697680" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="400" height="224"></embed></object>
                      • 8. Re: PPro 1.5 media encoder cutting black off edge
                        Jim_Simon Level 8
                        not true.
                        True.  Trust me.  Make them square during output at the specified resolution.
                        • 9. Re: PPro 1.5 media encoder cutting black off edge
                          WillProd Level 1
                          I did, and what I got was a video very out of shape.  The square pixels made
                          the frame short and  wider... the frame and subjects in the frame looked as
                          if they'd been run over.
                          • 10. Re: PPro 1.5 media encoder cutting black off edge
                            Jim_Simon Level 8
                            OK.
                            List your exact media properties, sequence settings, and export settintgs.
                            • 11. Re: PPro 1.5 media encoder cutting black off edge
                              WillProd Level 1
                              Project Settings:
                              DV Playback (Editing Mode)
                              23.976fps
                              720x480
                              D1/DV NTSC WIDESCREEN 16:9 (1.2)
                              Progressive Scan
                              Display Format 24fps timecode
                              my clips are
                              720x480
                              AVI (raw video)
                              29.97 fps and some are 23.976fps
                              most are 1.2pixel aspect a few are 0.9
                              Export settings are MPEG2
                              Video Summary:
                              TV Standard: NTSC
                              Aspect Ratio: 16:9
                              Level: High Level
                              M Frames: 3
                              N Frames: 15
                              Closed GOP every: 0
                              Write SDE: No
                              Encoding Level: 31
                              Audio Summary:
                              Audio Format: MPEG
                              Codec: MainConcept MPEG Audio
                              Audio Layer: MPEG-1, Layer II Audio
                              Audio Mode: Stereo
                              Sample Size: 16 bit
                              Frequency: 48 kHz
                              Bitrate [kbps]: 192
                              Psych Mode: Psychoacoustic model 2
                              De-emphasis: No emphasis
                              Enable CRC: Off
                              Set private bit: Off
                              Set copyright bit: Off
                              Set original bit: Off
                              Multiplexer Summary:
                              Multiplexing: MPEG-2
                              Bitrate Type: Variable
                              Mux Rate [kbps]: 0
                              Packet Size [bytes]: 2045
                              Packets/Pack: 1
                              Video Buffer Size [kB]: 0
                              Audio Buffer Size [kB]: 4
                              Sectors Delay [ms]: 0
                              Video Delay [ms]: 180
                              Audio Delay [ms]: 180
                              Max file size [MB]: 0
                              Write Program end code: On
                              Pulldown: Auto
                              Include Time Stamp In: All Frames
                              Align Sequence Header: Off
                              Lately i'm also getting at times the error "Mulitplexing has failed. Please check settings."
                              • 12. Re: PPro 1.5 media encoder cutting black off edge
                                Jim_Simon Level 8
                                Right away there's part of the problem.  Don't mix and match frame rates and screen sizes.
                                • 13. Re: PPro 1.5 media encoder cutting black off edge
                                  WillProd Level 1
                                  Well Hot damn, I fixed it!  I initially rendered the sequence as a raw
                                  .avi.  Placed that .avi into a new sequence and then used adobe media
                                  encoder and it works perfectly.  I appreciate the help.  Had no idea mixing
                                  fps and pixel ratio would cause issues.
