3 Replies Latest reply on Jan 21, 2011 12:08 AM by toddy3927
    Display barcodes in Reader 9
    air125
      We have to display documents with a barcode type Code 128 on Adobe Reader 8 and 9.
      Adobe Reader 8 displays them easily but I did not manage to make the barcodes visible in Adobe Reader 9. Instead I see a line of hieroglyphics and alphabetic characters. (e.g. Á09DE955610398189E1RÈ)
      I installed the font type Code128 in Windows (XP) and activated the use of local fonts in the Reader.
      Does anybody know the phenomenon and possibly a remedy?
      Any help will be appreciated!
        • 1. Re: Display barcodes in Reader 9
          toddy3927
          *pushup*
          hello there,
          i still have the same problem with adobe reader x.
          the font "code128" is installed in windows 7 pro correctly, the used user ist still administrator.
          if i open an existing document with barcodes in it it will only display other things like numbers or signs, if i try to open this document with "another" reader for pdfs the barcodes is correctly shown.
          the document prosperties of the pdf-file in adobe reader shows the font code 128 but it seems that it will be replaced by adobe sans mm.
          any ideas?
          • 2. Re: Display barcodes in Reader 9
            George_Johnson MVP & Adobe Community Professional
            Why don't you embed the font when you create the PDF?
            • 3. Re: Display barcodes in Reader 9
              toddy3927 Level 1
              I cant. I got these documents from our distributors or from other customers. Maybe i could please them to make these documents correctly for displaying in the reader. but thats not the problem. also viewing or printing these documents with another open-source reader e.g is an acceptable solution.
              i still searched a while for a solution cause i thought it could only be a little problem. but i didnt find anything except that it has something to do with the creation of the document as you said.
              i only wants to know if there is no solution why making an pdf unreadable for the reader....
