6 Replies Latest reply on Nov 3, 2009 6:17 AM by fader5
    Unsupported audio rate in file
    fader5 Level 1
      "Unsupported audio rate in file" error message is what I get when I try to import any avi file from a Canon SD400 still camera. I also get "unsupported format or damaged file /One of the necessary components may not have been installed."
      I have PE3 installed and importing of avi files works fine. I upgrade to PE4 and that's where the problem is.
      The properties of the avi file  I'm trying to import are as follows
      Image      width       640
                     height     480
      Audio       Duration 0:00:53
                     Bit rate     88kbps
                     Audio sample size     8 bit
                     audio format           PCM
      Video
           Frame rate           30 frames/second
           data rate          14620 kbps
      I'm running windows xp sp3
      2.00 ghz
      1.5gb of ram
      info of file when played with cyberlink
      Hardware Information:
        Processor: AMD Sempron(tm) Processor 3300+ running at 2001 MHz
        3DNow! Technology:  In Use
        Enhanced 3DNow! Technology:  In Use
        3DNow! Professional Technology:  In Use
        IA MMX Technology:  In Use
        IA Streaming SIMD Extensions:  In Use
        IA SSE 2:  In Use
        Video Accelerator:  DirectX VA (not in use)
        Multispeaker Audio Device:  Vinyl AC'97 Audio (WAVE) (not in use)
        SPDIF Output Device:  Vinyl AC'97 Audio (WAVE) (not in use)
      All AVI videos play fine with Windows Media Player, Windows Movie Maker, Apple quicktime player 7.6.4, CyberLink. Again Importing in PE3 is not the problem, its with PE4 where it doesn't work.  I thinking it's a codec problem but what .
      Bill
        • 1. Re: Unsupported audio rate in file
          Atlhough some people can make it work, generally trying to edit vide directly from a still camera can be kind of iffy.
          You'll get the best results and have the least problems if you convert the video to DV-AVIs with Windows MovieMaker first, per the FAQs to the right of this forum.
          http://forums.adobe.com/thread/415317?tstart=0
          • 2. Re: Unsupported audio rate in file
            the_wine_snob Level 9
            That 8-bit sample size is probably your issue.
            What is your Project Preset? It needs to match your source material perfectly.
            It is very likely that you will need to convert these files, prior to Import. If you are going to output to DVD-Video, or similar, then I would strongly suggest that you convert to DV-AVI Type II w/ 48KHz 16-bit PCM/WAV Audio. This is the ultimate format (with the DV CODEC) for PrE to edit smoothly.
            Also remember that there is a great difference between a computer being able to play an AV file, and an NLE (Non Linear Editor), like PrE, being able to edit those same files.
            Good luck, and we'll be looking for the info on Project Preset,
            • 3. Re: Unsupported audio rate in file
              fader5 Level 1
              Project Preset is set the same in PRe3 and PRe4
              DV
              Standard 48kHz
              - For editing with IEEE1394 (FireWire/i.LINK) DV equipment.
              - Standard NTSC video (4:3 interlaced).
              - 48kHz (16 bit) audio.
              - Drop-Frame Timecode numbering.
              General
              Editing mode: DV NTSC
              Timebase: 29.97 fps
              Video Settings
              Frame size: 720h 480v (0.900)
              Frame rate: 29.97 frames/second
              Pixel Aspect Ratio: D1/DV NTSC (0.9)
              Fields: Lower Field First
              Audio Settings
              Sample rate: 48000 samples/second
              Capture Format
              DV Capture
              Video Rendering
              Maximum Bit Depth: Off
              Preview File Format: DV NTSC
              Compressor: DV NTSC
              Color depth: Millions of colors
              Default Timeline
              Video tracks: 3
              Stereo tracks: 3
              • 4. Re: Unsupported audio rate in file
                fader5 Level 1
                Any other suggestions on how or what I can change? I installed Pe on my laptop with Vista and it has no problems importing and recognizing these avi files.
                Is it some setting in the register that can be added or change?
                Or could it be a codec
                My registry shows for Premiere Elements
                3.0
                Codec Info Entry Point
                VGetCodecIterator
                but nothing for 4.0
                Bill
                • 5. Re: Unsupported audio rate in file
                  fader5 Level 1
                  Here's the latestest! I've installed Pre 4 on my son computer and it works fine I'm able to import files that I wasn't able to do on mine. Should I compare his installed codec's to mine  would it be a video or audio ?  Error message again is "Unsupported audio rate in file."
                  • 6. Re: Unsupported audio rate in file
                    fader5 Level 1
                    After unistalling somethings (including PRe3 and Pre4, Pinnacle Studio 8(linx)) and reinstallling PRe4 it works like a champ.
                    Thanks for all your help and suggestions.
                    Bill
