0 Replies Latest reply on Oct 19, 2009 9:48 AM by Peter Farland
    [svn:fx-trunk] 11004: Simple fix of DefineMorphShape so that it reports its fill style asset dependencies correctly for SWF linkage .
    Peter Farland Level 3
      Revision: 11004
      Author:   pfarland@adobe.com
      Date:     2009-10-19 09:48:07 -0700 (Mon, 19 Oct 2009)
      Log Message:
      Simple fix of DefineMorphShape so that it reports its fill style asset dependencies correctly for SWF linkage.
      QE notes: Flex doesn't use morph shape directly, but Flash Authoring SWFs that do will encode this tag and we should be able to decode them correctly for asset embedding.
      Doc notes: None
      Bugs:
      SDK-19227 - Compiler crash when including SWC containing shape tween with a bitmap fill
      Reviewer: Paul
      Tests run: Checkintests, bug test case
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-19227
      Modified Paths:
          flex/sdk/trunk/modules/swfutils/src/java/flash/swf/tags/DefineMorphShape.java
          flex/sdk/trunk/modules/swfutils/src/java/flash/swf/types/MorphFillStyle.java
