0 Replies Latest reply on Oct 19, 2009 12:55 PM by F.Bowman
    ComboBox Binding
    F.Bowman Level 2
      I'm trying to attach some information from a ComboBox in an HTTP request. The problem is that everytime I go to the State where the ComboBox exists, I get some warnings from the compiler:-
      warning: unable to bind to property 'label' on class 'Object' (class is not an IEventDispatcher)
      warning: unable to bind to property 'data' on class 'Object' (class is not an IEventDispatcher)
      warning: unable to bind to property 'data' on class 'Object' (class is not an IEventDispatche)
      This is the HTTP Request:-
      <mx:HTTPService
      id="
      scheduleYearRequest"
      url="
      {engineURL}"
      method="
      POST"
      resultFormat="
      text"
      result="handlerRequestResult(event);"
      fault="handlerRequestFault(event);"
      <mx:request xmlns="">
      <action>scheduleYearRequest</action>
      <type>{download_type.selectedItem.data}</type>
      <user>{download_user.selectedItem.label}</user>
      </mx:request>
      </mx:HTTPService>
      This is the state:-
      <mx:State
      name="Download" basedOn="Authenticated">
      <mx:AddChild relativeTo="{panel2}" position="lastChild">
      <mx:TitleWindow x="150.5" y="63" width="320" height="240" title="Download ECS" layout="absolute" showCloseButton="true" close="currentState='Authenticated'">
      <mx:Form x="0" y="0" width="300" height="200">
      <mx:FormItem label="Employer:">
      <mx:ComboBox id="download_user" editable="false" enabled="true" dataProvider="{listUser}" change="downloadInteract('user')" />
      </mx:FormItem>
      <mx:FormItem label="Type:">
      <mx:ComboBox id="download_type" editable="false" enabled="false" dataProvider="{listType}" change="downloadInteract('type')" />
      </mx:FormItem>
      <mx:FormItem label="Year:">
      <mx:ComboBox id="download_year" editable="false" enabled="false" dataProvider="{listYear}" change="downloadInteract('year')" />
      </mx:FormItem>
      <mx:FormItem label="Month:" >
      <mx:ComboBox id="download_month" editable="false" enabled="false" dataProvider="{listMonth}" change="downloadInteract('month')" />
      </mx:FormItem>
      <mx:FormItem label="ID:" >
      <mx:ComboBox id="download_id" editable="false" enabled="false" dataProvider="{listID}" change="downloadInteract('id')" />
      </mx:FormItem>
      <mx:FormItem>
      <mx:Button id="download_download" enabled="false" label="Download" />
      </mx:FormItem>
      </mx:Form>
      </mx:TitleWindow>
      </mx:AddChild>
      </mx:State>
      The variable definitions:-
      Bindable]
      private var listID:ArrayCollection;
      Bindable]
      private var listMonth:ArrayCollection;
      Bindable]
      private var listType:ArrayCollection;
      Bindable]
      private var listUser:ArrayCollection;
      Bindable]
      private var listYear:ArrayCollection;
      Additional code:-
      listID =
      new ArrayCollection([{label:"Select",data:"Select"}]);
      listMonth =
      listType =
      new ArrayCollection([{label:"Select",data:"Select"},{label:"Export",data:"exports"},{label:"Upload",data:"uploads"}]);
      listUser =
      listYear =
      Can anyone share any insight into why I'm getting the warnings? Is there a way to bind the selectedItems so the HTTP request?
