1 Reply Latest reply on Oct 20, 2009 3:48 AM by Dipanwita S
    Method introspection on extended CFC's
    rottmanja
      I have written a few small test application with CFbuilder and the biggest bug that I have found so far is that CFbuilder does not introspect extended cfc's thus allowing the code completion of inherited methods.
      To give an example, I have created 3 seperate CFC's that all implement an interface.
      CFC1 (implements ICFC1)
           CFC2 (implements ICFC2)
                CFC3 (implements ICFC3)
      I would then use this code to call the cfc's
      <cfscript>
          myVO = createObject("component","org.model.vo.CFC3").init();
              myVO.setSomeMethod('test');  // no introspection here
      </cfscript>
      Ideally when I attempt to set a value with an inherited methods, I should be able to view all the methods that CFC3 inherits.
      I have attached my test project to this post.
        • 1. Re: Method introspection on extended CFC's
          Dipanwita S Level 1
          You have mentioned that you do not see the inherited methods for extended CFCs. When I try the same stuff out in my test projects, I do get introspection on all extended CFCs. But, when I try it out on the example project that you have posted, it does not show up the methods. We need to investigate this, could be an issue with path resolution. I will log a bug for this issue. Thanks a lot for the sample project.
          Dipanwita
          Adobe ColdFusion QE Team
