0 Replies Latest reply on Oct 19, 2009 5:02 PM by Peter Farland
    [svn:fx-trunk] 11018: Checking in the source files for /lib/xercesPatch. jar made originally by rsun to patch Apache Xerces 2.4. 0 to retain attribute line numbers.
    Peter Farland Level 3
      Revision: 11018
      Author:   pfarland@adobe.com
      Date:     2009-10-19 17:02:40 -0700 (Mon, 19 Oct 2009)
      Log Message:
      Checking in the source files for /lib/xercesPatch.jar made originally by rsun to patch Apache Xerces 2.4.0 to retain attribute line numbers.
      From Rebecca's original notes:
      "fix for 76207 - can't set breakpoints on event handlers that occupy different lines in the mxml file.
      this fix involves changing the implementation of the xerces parser that we are using. the code that needed to be changed in order to extract per-attribute line number information is very far deep in the pipeline, so we've had to change quite a few of the xerces classes.
      the new xercesPatch.jar is based on the Xerces 2.4.0 distribution, as are the existing xercesImpl.jar and xmlParserAPI.jar files in /lib. it contains only the files we've modified for the patch, not the xerces classes themselves. the entry point is contained in the javax.xml.parsers.SAXParserFactory file, where we point to our own implementation of the parser rather than the xerces one."
      QE notes: None.
      Doc notes: None.
      Bugs: SDK-16818 - Open-source the code for xercesPatch.jar.
      Reviewer: Frances, Matt
      Tests run: Checkintests
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-16818
      Added Paths:
          flex/sdk/trunk/modules/thirdparty/xerces-patch/
          flex/sdk/trunk/modules/thirdparty/xerces-patch/build.xml
          flex/sdk/trunk/modules/thirdparty/xerces-patch/src/
          flex/sdk/trunk/modules/thirdparty/xerces-patch/src/java/
          flex/sdk/trunk/modules/thirdparty/xerces-patch/src/java/META-INF/
          flex/sdk/trunk/modules/thirdparty/xerces-patch/src/java/META-INF/services/
          flex/sdk/trunk/modules/thirdparty/xerces-patch/src/java/META-INF/services/javax.xml.parse rs.SAXParserFactory
          flex/sdk/trunk/modules/thirdparty/xerces-patch/src/java/META-INF/services/org.apache.xerc es.xni.parser.XMLParserConfiguration
          flex/sdk/trunk/modules/thirdparty/xerces-patch/src/java/org/
          flex/sdk/trunk/modules/thirdparty/xerces-patch/src/java/org/apache/
          flex/sdk/trunk/modules/thirdparty/xerces-patch/src/java/org/apache/xerces/
          flex/sdk/trunk/modules/thirdparty/xerces-patch/src/java/org/apache/xerces/impl/
          flex/sdk/trunk/modules/thirdparty/xerces-patch/src/java/org/apache/xerces/impl/XMLDocumen tFragmentScannerMMImpl.java
          flex/sdk/trunk/modules/thirdparty/xerces-patch/src/java/org/apache/xerces/impl/XMLDocumen tScannerMMImpl.java
          flex/sdk/trunk/modules/thirdparty/xerces-patch/src/java/org/apache/xerces/impl/XMLNSDocum entScannerMMImpl.java
          flex/sdk/trunk/modules/thirdparty/xerces-patch/src/java/org/apache/xerces/jaxp/
          flex/sdk/trunk/modules/thirdparty/xerces-patch/src/java/org/apache/xerces/jaxp/SAXParserF actoryMMImpl.java
          flex/sdk/trunk/modules/thirdparty/xerces-patch/src/java/org/apache/xerces/jaxp/SAXParserM MImpl.java
          flex/sdk/trunk/modules/thirdparty/xerces-patch/src/java/org/apache/xerces/jaxp/javax.xml. parsers.SAXParserFactory
          flex/sdk/trunk/modules/thirdparty/xerces-patch/src/java/org/apache/xerces/parsers/
          flex/sdk/trunk/modules/thirdparty/xerces-patch/src/java/org/apache/xerces/parsers/Abstrac tSAXParserMMImpl.java
          flex/sdk/trunk/modules/thirdparty/xerces-patch/src/java/org/apache/xerces/parsers/Integra tedParserConfigurationMMImpl.java
          flex/sdk/trunk/modules/thirdparty/xerces-patch/src/java/org/apache/xerces/parsers/SAXPars erMMImpl.java
          flex/sdk/trunk/modules/thirdparty/xerces-patch/src/java/org/apache/xerces/parsers/XML11Co nfigurationMMImpl.java
          flex/sdk/trunk/modules/thirdparty/xerces-patch/src/java/org/apache/xerces/util/
          flex/sdk/trunk/modules/thirdparty/xerces-patch/src/java/org/apache/xerces/util/XMLAttribu tesMMImpl.java
