0 Replies Latest reply on Oct 19, 2009 5:37 PM by Peter Farland
    [svn:fx-trunk] 11019: Checking in a build of /lib/xercesPatch. jar based directly on the sources checked in revision 11018.
    Peter Farland Level 3
      Revision: 11019
      Author:   pfarland@adobe.com
      Date:     2009-10-19 17:37:10 -0700 (Mon, 19 Oct 2009)
      Log Message:
      Checking in a build of /lib/xercesPatch.jar based directly on the sources checked in revision 11018. This binary was built using Sun JDK 1.5.0_14 but targeted source as Java 1.4.
      QE notes: Please keep an eye on FDB test cases that make use of MXML breakpoints for attributes on lines different from the associated XML tag.
      Doc notes: No
      Bugs: Bugs: SDK-16818 - Open-source the code for xercesPatch.jar.
      Tests run: Checkintests
      Is noteworthy for integration: Not really - this should be equivalent to the previous xercesPatch.jar binary.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-16818
      Modified Paths:
          flex/sdk/trunk/lib/xercesPatch.jar
