1 2 Previous Next 63 Replies Latest reply on Jun 11, 2014 8:44 AM by d3mac123
    [JS CS3/4] ScriptUI How to color a button ?
    Loic.Aigon Adobe Community Professional
      Is it a way to get a colored button in the ScriptUI DOM ?
      I tried
      dlg.button1.graphics.backgroundColor = dlg.button1.graphics.newBrush(dlg.button1.graphics.BrushType.SOLID_COLOR,[0.7,0.7,0.7],1);
      But although the dialog is drawn, the button is not styled in best case, not visible in the worst case.
      Is that possible to get a colored button ?
      Hope so.
      Do you have any tip ?
      TIA
      Loic
        • 1. Re: [JS CS3/4] ScriptUI How to color a button ?
          Kasyan Servetsky Level 5
          Hi loic,
          I'd like to know the answer to this question as well. I was trying to figure out how to do this for a couple of hours, but it turned out a too hard nut for me to crack.
          I could paint both the dialog and the panel:
          var dlg = new Window('dialog', 'Test');
          var pnl = dlg.add('panel', undefined, 'My Panel')
          var btn = pnl.add('button', undefined, 'My Button', {name:'ok'});
          var g = pnl.graphics;
          var brush = g.newBrush( g.BrushType.SOLID_COLOR, [0.7, 0.7, 0.7, 1] );
          try {
                g.backgroundColor = brush;
          catch(e) {
                $.writeln(e);
          dlg.show();
          But when I try to do the same with button, I get an error:
          Error: Cannot set backgroundColor property for this element type
          Then I tried to set foregroundColor using ScriptUIPen, but failed to create it.
          var pen = g.newPen( g.PenType.SOLID_COLOR, [0.7, 0.7, 0.7, 1] );
          throws an error: TypeError: Bad argument list.
          And the documentation is so obscure on this topic — no examples provided (Graphic Customization Objects chapter in JavaScript Tools Guide).
          I've found only two examples — both by Bob Stucky. He is the only person, I know about, that can do this sort of things.
          Here is one more question that keeps me awake at night — the following script sets the text of the button to Arial, BOLD, 12px:
          var g = btn.graphics;
          g.font = ScriptUI.newFont("Arial", "BOLD", 12);
          dlg.show();
          Why do we use graphics object, when we create a new brush?
          And why do we use ScriptUI, when we create a new font?
          Kasyan
          • 2. Re: [JS CS3/4] ScriptUI How to color a button ?
            Bob Stucky Adobe Employee
            I have tried in the past but not been able to color a button.
            What I have been able to do is use the onDraw callback to print an image instead of the standard control.
            You may want to try that.
            Wish I could be of more help. Kasyan's correct, the docs are sketchy at best. The biggest hurdle is that some of the custom drawing functionality seems to be a bit brittle and prone to failure in some cases.
            Below is an example of drawing an image in place of a dropdown list to make a poor mans' flyout menu.
            Regards
            Bob
            // Ever wanted to embed an image file in a jsx file?
            // below is a multi-step process for doing so. It's a little cumbersome but worth the bother at times when a script depends on
            // a binary object, but there is no fail-safe way to ensure the binary is delivered or installed with the script (like this sample!)
                 function myFileStringer( myFile ) {
                      // read the image file
                      myFile.encoding = "BINARY";
                      myFile.open( "r" );
                      var myBuf = myFile.read();
                      myFile.close();
                      // create an output file of the same name with the extension "txt"
                      var outName = myFile.name.substr( 0, myFile.name.lastIndexOf( "." ) ) + ".txt";
                      var outFile = new File( myFile.parent.absouteURI + "/" + outName );
                      outFile.open( "w" );
                      // write the buffer to the text file using toSource(). The text in the file will be JSON, ready to copy and paste into your script
                      outFile.write( myBuf.toSource() );
                      outFile.close();
                      // open the text file, copy the text in the file in a single line, paste it into your source code as a single line, something like this:
                      // var myBinary = (newString("\u0089PNG\r\n\x\1\A\n\x00\x00\x00\riHDR\x00\x00\x00... ) );
                      // it will be a very long string
                 function myFileMaker() {
                      // the (new String(....) in the line below is the output as pasted from myFileEnstringer
                      // it is in JSON notation from the toSource() call above - when this line is executed, myBinary will contain an accurate binary representation of the image
                      // the binary below is a PNG image that is an icon for a flyout menu.
                      var myBinary = (new String("\u0089PNG\r\n\x1A\n\x00\x00\x00\rIHDR\x00\x00\x00\x10\x00\x00\x00\t\b\x06\x00\x00\x00;*\u00AC2\x00\x00\x00\tpHYs\x00\x00\x0B\x13\x00\x00\x0B\x13\x01\x00\u009A\u009C\x18\x00\x00\x0FciCCPPhotoshop ICC profile\x00\x00x\u00DA\u00ADWi8\x14\u00EC\u00D7?3\u00C6\u00D8\u00C76\u00C6\u00CEX\u00B2d\x1B\u00FB\u0096u\u0090\u009D\u00EC$\u008C\x19\u00CBX\u00A7\u00B1/\u00A1B\u008F\u0088\u00B4\u00A1\u0088\x14i\u00A1\u0094\u0084\u0092\u00AD\u00B2\u0094\u00A2\x12ey\u00B2\u00A6B\"K\u008B\u00E6\u00FD\u00A0\u00A7\u00E7\u00BA\u00FE\u00EF\u00F5\u00BE\u00EF\u0097\u00F7|\u00FA\u009Ds\u009Ds~\u00E7\u00BE\u00CF}]\u00E7>\x00\u00BCB$\x1A-\x02\t\x00\u0091Q\u00B1t\u0097\u00DD\u00E6x/o\x1F<\u00CBk\u00E0\x04~\u00C0\u0082>H\u0092\u00C8143gg{\u00F8\x1Fe\u00FD5 \x00\x00^\u00AA\u0090h\u00B4\u0088|\u00F6\x00J\u00DF\u00D4\u00D9\u0092z\u00C3\x15\u00E7/\u00B2\u0087d\u00E1\x7F\x17\f\u00DD\u00CB\u00DB\x07\x00\u00A1\f\x00\u00D8\u0090ml\n\x00\u00D8\u00C0m\u00EC\x06\x00\u00D8\u0084XZ,\x00\"\x14\x00\u00B0\u00E4P\x12\x05\x00\u0091\n\x00\u00CAt7\x17\"\x00\u00A2\x06\x000!\u00DB\u00B8\t\x000\u0081\u00DB\u00B8\x07\x000\u00F1\u00E4\u0090X\x00\u00C4\b\x00\u009A/\u008AB\u008D\x02`Y\x00@\x1BS\u0082b\u00C8\x00\x18e\x00\u00A0Pb\u00C8\u0091\x00\u0098\u00E3\x00H\u00D5\u00C8\u00C8h\n\x00O;\x00(\u0090i\u00F4X\x00\u009Ey\x00P\u00F1\u00F2\u00F6\u00C1o\u0097L\u00D9\x000@\x01\u00A0\u00DF\u00FEk\x0B\u0093\x02\u00A8\u00BD\x03 &\u00F5\u00AFM\u00FE\x01\u0080\x10\t\u00E0\u00E6\u00CE\x7Fm\u00AB.\u0080\x00\x00\x04\u00EEyL\u00B0\u00A6\x06\x00\x00 8\u00CD\x01\u0098'\x18\u008CU9\x00\u0096\x13\x00[\u0085\f\u00C6\u008FJ\x06c\u00EB\"\x00\u00D3\x18@{\x049\u008E\x1E\u00FF\u00FB\u00BE\x10\u0088~\u0080\u00FFK\u00DF>\u00F3oaB\x00 \x01\u0090jL\u008E\u00A8P\u00E6\x03\u00E8\x12\u0096\u009B\u00AC\u009Dl#\u00EC\u009F8V\u00B8\u00D81\u0082\u00DCR<*\u00BC\x06|f\u00FC\u00F6X7\x01O\u009C\u009F Y\u0088*L\x13\u0089\x11\u008D\x15\u008B\x13O\u0094H\u0091\u00CC\u00C0gJeJ\x1F\u00919*\u009B\u00BF\u00E3\u00B4\u00DC9\u00F9\n\u0085\x1A\u00C5\x1B;\u009B\u0094\u00BA\u0095\u0087T&U\u00D7\t\u00EC\u00EA\u00D2\x1A\u009A\u009A\u00EEZ)\u00DA\x15:}\u00BA\u009B\u00FA\u008A\x06$\u00C3s\u00BB\u00C6\u008D%M\u00A8\u00A6w\u00CD9\u0089\u00FB,n[\u00F1\u00ED\u00A6[\x0F\u00DA\u00AA\u00D9\x1D\u00B3\u00FF\u00E2h\u00EFT\u00B7\u0087\u00DB%\u00C2\u00B5\u00CF]\u00D4#\u00C2\u00F3\u00817\u00C6\u00C7\x7Fo\u008D\u00EFW?\u00A2\u00FF\u00D1\u0080\u00FE@n\u00B2\x13\u00E5D\u00D0\u00F3\x10\u00F6P3j\\X]\u00F8d$\x7F\u0094Et\x02\u00ED\u00FA\u00FE\u00B71\u00A8XB\u009C\x7F|^\u00C2\u00FD\u00C4\u00F9d\u00DE\x14\u00E3T\u00DA\u0081\u00F2\u00B4\u00EE\u00F4\u00B1\u008C\u00A9\u0083\u00B3\u0087\x16\x0E/g\u00AEd\u00ADgo\u00FD\u0085\u00CA\u00E1<\u00CA\u009B+\u0090'~L!_\u00B3\u00C0\u00F0\u00B8Y\u00A1\u00F5\u0089='=N\u00F9\u009C\u00F6;C.\u00A2\x16\u0087\u0097\u0084\u009F\u00A5\u009E\u00A3\u0096\u0086\u0095\u0085\u009E'\u0095\u00FBT\u00B8^\u00B0\u00AB4\u00BD\u00A8~I\u00B1J\u00BEz\u00C7e\u00E9\x1A\u00FC\x15\u00F1\u00AB\u00C2\u00D7\x04\u00AE\u00F3\u00D6\u00F2\u00D4q\u00DE`\u00BE\u00F1\u00EB\u00E6f\u00FD\u00EA\u00AD\u00C5\u00DB\u00B3\r\u00A3w\x06\x1B\u009F\u00DE\u00EDjjn\u00AEo\u00B9~\u00EF\u00CA\u00FD\x0B\u00ADg\x1E\u00E4\u00B7\x1Dm\u00CF\u00EC8\u00D8\u0099\u00DCE\x7F\x18\u00F5(\u00EAqD7\u00A9\u0087\u00D8\u008B\u00EB\u009D\u00EA\u00BB\u00F5$\u00FD\u00A9m\u00BF`\u00FF\u00DC\u00B3\u0086\u00E7\u0099\x03.\u0083\u0092\u0083\u008B/\u00DA_\x16\u00BE\u00F2\x1FR\x19\u00FA\u00FE\u00FA\u00C9p\u00D1\b\u00E9\u008D\u00CA\u009Boo\x1F\u008F\x16\u008Cy\u008C\u008B\u008F\u00CFL\u00D4\u00FEM\x7F\u00A7\u00F3\u00EE\u00DBd\u00CBT\u00CA\u00B4\u00C1\u00F4\u00FAL\u00E3l\u00EA\u009C\u00D9{\u00A6\u00F7\u00BD\u00F3y\x1F\x1C?\u00F2||\u00F9\u00A9h\u00C1kQhqd\u00A9\u00F8\u00B3\u00D7\u00B2\u00D0\u00F2\u00D0\u0097\u00C2\x15\u00C7U\u00AE\u00D5\u00DE\u00AF\u0099kfk\u008C\u00F5\x07\x1B\u00C9\u009B\u00DA\u009B\u00CB\u00DFj\u00BF\u0087\u00FFP\u00FC1\u00F7\u00B3r+\u00E0\u0097\u00E4\u00AF\u00B7\u008C\u00FD\f\x06\x00\x12\u00C5\u00C4\u0087\u00C21c\u00D1\x02,\u00DC\u00AC\x1Cl\u00ACl[\u00EC\u00DF8>s\u00CEp\u00BD\u00C1\u00F4sw\u00F0\u00D4\u00F3V\u00F2\u009D\u00E2\u00CF\u00C2&\b\u0084\u00E3\u00F6\t:\t\x11\u0085\u00F5EtD\u0095\u00C5\u00D4\u00C4U%t$\u008D\u00F1\u0096R&\u00D2z2*\u00B2\u00CA;\u0094\u00E5v\u00CA\x13\x14\u0094\x15\t;u\u0094\u0088\u00CA\u00B6*^\u00AAT\u00B5$B\u008Ez\u0099F\u00A3\u00E6s\u00AD%\x1D^]-=W\u00FDd\u0083\u00CB\u0086\u00C3F\u00AC\u00C6\u00DA&\u00FBMk\u00CD\u00E6\u0089J\x16\u00E1\u00967\u00AC6\u00AD-mrmG\u00EC\u00D5\x1DR\x1D\x07\u009DE\u00F7\u0084\u00B84\u00BA!\u00DC\x1D<Nx\u008Ey+\u00FA\u00D0\u00F6\u00DE\u00F2\u00DD\u00F0\u00D3\u00F3?\x10\u00D0F\u00DA\"\x1BR\u00E2\u0083\u00EE\x06\u00AF\u0086\u00AAR\u00C3\u00C2\u00AE\u0086\x7F\u008C\u0094\u008B\u00F2\u008D.\u00A6\u00BD\u00A6\u00F3\u00C7\u00B8\u00C5\x16\u00C6\u00F5%\u00B0&\u00DA'\u00E5'?J\u0099N\u00FDt\u00E0s\u00DAZ\u00FA\u00B7\u008C\u00EF\x07\x7F\x1Df\u00CE\u00E4\u00CC\u00E2\u00CF\x16>\"\u00FE\u0097l\x0E\u00E1\u00A8A\u00AEy\u009E\u00CD1\u00A7|\u00AF\x02\u00DF\u00E3\x01\u0085\u0094\x13a'\u00A3O\u00D1N\u00D3\u00CFD\x17E\x15\u00D3J\"\u00CF\x06\u009F\x0B(\u00F5*s>oY\u00AES\u00A1rA\u00A5R\u00F9\u00A2\u00E2%\u00C5*\u0085j\u00B9\u00CB\u00B252Wd\u00AF\u00CA\\\u0093\u00BC.V+R'|C\u00E8\u00A6@=\u00DF-\u00EE\u00DB\u00DC\r\u0098;\\\u008D\\wy\u009Bp\u00CDB-B\u00F7D\u00EF\u00E3[\u00E5\x1F\u00A8\u00B6i\u00B7\u00EBw\u0098w:v\u00F9<\u00DC\u00FBh\u00F7c\u00FC\u00E3\u0095\u00EE\u00DE\u009E\u00D2\u00DE\u00C8>\u00B3'\u0082O\x16\u009F>\u00EA/y\x16\u00F9\u009C8 >\u00B0>\u00D8\u00FF\u00A2\u00F2e\u00C2+\u00C7!\u00E9\u00A1\u00B5\u00D7\u00BD\u00C3\u00A5#\u00D1o\u00CC\u00DE\u00F2\u00BE\x1D\x1F\u00BD>\u0096:n=\u00C1;1\u00FAw\u00E5\u00BB\u00B0I\u00D5\u00C9\u00E5\u00A9\u00A6\u00E9\u00E33\u00A1\u00B3&s\u0082s\u008B\u00EF\x1F\u00CE\u0097|\u0088\u00FAh\u00F9I\u00F8\u00D3\u00C7\u0085\u00FB\u008B\u00C7\u0096\u00F6}V\u00FD\u00FCc\u00B9\u00FB\u00CB\u0089\x15\u00BFU\u00C5\u00D5\u0095\u00AF\u00F7\u00D6\u00B2\u00D7\u009D7\u00846\u00C66+\u00BFQ\u00BF\x13\u00BEo\u00FE\u00B8\u00FF3c\u00CB\u00F2\x17\u00E6\u00D7sF\u00E4v\u00FF\u0091\x1BL\u00CB\u00A8\u00AF\u00CC\u009F\u00D1\u008B,\u008B\u00AC\u008Bl\x13\u00EC\u00A3\x1C\u00AF8\u009Fp\u00B5b\u00EA\u00B8\u00CByry\x13\u00F8(\u00FC\u00F6X\u0082\x00\u00B7\u00C0*nP\u00F0\u009AP\u00A6\u00B0\u00AF\bA\u0094YtX\u00ACJ<N\u00C2R\u0092[r\x1C_%\x15)m \u0083\u0096y-{eG\u009A\u009C\u00BB\u00BC\u00B2\x02\u00AB\u00C2{\u00C5\u00EE\u009D5J\u00C7\u0094cU\u00F6\u00AA\u009A\u00AB\u00A9\x12\u00C4\u00D4\u00D9\u00D474f5\x07\u00B5\u00DA\u00B5o\u00EA\u0094\u00E9\u00E6\u00E8\u00C5\u00EB\u0093\f\u00EC\rw\u00ED\u00C2\x1B\u00A1\u008D\u0096\u008D\u0087L\u00EE\u0098\u009E4\u008B7\u00A7\x12=-\u00AC,\u00F5\u00AC\u00E4v\x0BY3[\u00AF\u00DB|\u00B0}c\u00D7c\u00DF\u00E8P\u00EDX\u00EC\u0094\u00E3\u009C\u00B8'\u00C4\u00C5\u00C3\u00D5\u00DE\u00CD\u00D0]\u00D9C\u00D2\x13\u00E7\u00C5\u00E5\u008D\u00F4\u00FE\u00EA\u00F3a\u00EF\u0094\u00EF\u00DB}\u00AF\u00FC\u00FA\u00FD\u00BB\x02\x1E\u0090Z\x03[\u00C8\u00B7(\x17\u0083r\u0082\u00E9!\u00FE\u00A1\u00D6T\u00B50\u0091p\u0096\u00F0\u00B5\u0088\u0099\u00C8\u00C1\u00A8\x07\u00D1u\u00B4\u00CA\u00FDg\u00E8\x7F\u00C5$\u00C6\u0086\u00C6\u00F9\u00C5;&\x18'\u00AA%I%cSP)\u00AB\u00A9\u00EF\x0E<K{\u0090~-\u00E3\u00D4\u00C1\u00F4C\u00C1\u0087\u009D2\u00B5\u00B2p\u00D9\u0088\u00EC\u008D#\u008B\x7FM\u00E7\u00BC=:\u0090\u00DB\u009D\u00D7r\u00ECF~MA\u00E9\u00F1\u00DC\u00C2\u00F4\x13\u00B4\u0093\u0094S\u00EE\u00A7\u00AD\u00CEh\x15\u00C9\x16\x0B\u00940\u0097|=;{n\u00A4\u00B4\u00BF\u00EC\u00C1\u00F9\u00EB\u00E5e\x15'/dU\u00A6^\u008C\u00BED\u00AA\u00F2\u00AC\u00DEs\u00D9\u00A6\u00C6\u00F0\u008A\u00F4U\u00B8:v\u00ED\u00FE\u00F5\u00E2Zz\u009D\u00D3\r\u00D5\u009B\u0098\u009BK\u00F5\u00FD\u00B7\u00AE\u00DC\u00CEm\u0088\u00BE\u00E3\u00DA\u00A8}\x17ww\u00A3i\u00AC\u00B9\u00B5\u00A5\u00EC^\u00DA}R+\u00F1\u00C1\u008E6\u00E6\u00B6\u00E9\u00F6\u00AE\u008E\u00EA\u00CE\u00CC.\u00D2C\u00A3G\"\u008F\u00D6\x1F\x0FtW\u00F5\u00E4\u00F6\u0096\u00F6u<\u0099z\u00CAx&\u00F2\\\x7F\u00C0g0\u00F5E\u00E9\u00CB\u009EW\u008B\u00AF\u00C5\u0086\u009DFr\u00DF<\x1D\u00E5\x1F\x0B\x18o\u00FE\u009B\u00FF]\u00FA\u00E4\u00D7\u00E9\u0083\u00B3\u0098\u00B9\u00CB\u00F3\u00CE\x1Fy?\u00BD^\u00AC\u00FB|\u00E6K\u00E1j\u00D9Z\u00FD\u00C6\u00DCw\u00FC\u00CF\u0080_i\f\x06\u00C0\u00F6\u00EC\x03\x00@\u00EB\x00\x14\u00C7\x01xM\x02\u00B8T\x01\x14l\x01(p\x02\u00E0j\x00\u009C\u00B9\x00\u00DC\u00F4\x01\u00D1Y\x00\u0088kY\u00800/\u00F8g~\x00\x00\x12X\u0081\x17$@\x05L\u00C0\r\" \x1B.\u00C2C\u0098E\u00B0#4\x10\u00BE\u0088\u00BF\x10M\u0088\x0FHq\u00A4;2\x1F\u00D9\u00C7\u00C4\u00CAd\u00CD\u0094\u00CB4\u0088\x12AQP\u00F5(\x06\u00B3\x13\u00F3E\u00E6ohg\u00F4U\x16\x14\x0B\u0089\u00A5\u009DU\u008A\u00F50\u00EB<\u009B\x03[=\u00BB\b{&\u00FB\x02\u0087'G'\u00A7\x06g\x19\x17\x0BW\x1C\u00D7\x14\u00C6\t\u00D3\u00CA\u00AD\u00C4]\u00CC\u00C3\u00C2\x13\u00C33\u00C9\u00EB\u00CC\u00DB\u00CA\u00A7\u00C4W\u00CC\u00CF\u00CC\x1F\u00C7?\u008Bu\u00C5v\b\x10\x04*p|\u00B8,\u00DC7\u00C1\b\u00C1wB\u00DEB\u00CF\u0085w\x0B\u00B7\u008B\u00EC\x12i\x14\u00D5\x11m\x113\x16\u00EB\x14\u00B7\x16\x1F\u0090\u00F0\u0092\u0098\u0095\u00A4K2\u00F0yR\x12R\u00B7\u00A5m\u00A4'eRd\u00B1\u00B2\u00F5;\u009Cw\u00AC\u00C8\x15\u00C9\x1B\u00CBO+\u00E4)\u00EA+\u00CE\u00ED<\u00ADd\u00A1\u00B4\u00AA\\\u00AD\u00E2\u00A7*\u00A4:\u00A0\u0096C\u00B0T\x07\u00F5V\u008DtMs-&\u00ADN\u00ED,\x1D{]\t=\u00A4\u00DE\u0092\u00FE\u00B0A\u00A7\u00E1\u00ED]UF\u00A7\u008C\u00B3L\x12L\u00C3\u00CC\u00C8\u00E6\u00FB\u0088\u00AE\x16\u00D6\u0096\u00E6V&\u00BBM\u00ADMmLmw\u00DB9\u00DB\u00FB8\x049\u00D2\u009C\x0E;\x17\u00ED\u00A9w\u00E9u\u009DtGx\u00C8{:x%xW\u00FA\f\u00FBr\u00EF3\u00F0#\u00FB\u009F\n\u00E8$\u00AD\u0092\u00E5)~AE\u00C1\u00FD\u00A1h\u00EA\u00EE\u00B0\u009C\u00F0\u00FEH\u009E(\u008F\u00E8\n\u00DAg\u00BAYLn\u00EC\u00DF\u00F1Z\t9\u0089c\u00C9*)GR\u00E7\u00D3,\u00D2\u00CB2~\x1C\u00F28\u00DC\u009C%\u0099\u009Dv\u00E4m\u008E\u00C9\u00D1;y\u00BE\u00F9b\x05C\u0085%'\x03O\u00CB\u009C\u00F9X\\w6\u00AD\u00D4\u00E1<\x7F\u00F9\u00E4\u0085\u00C6\u008B\u0085U\u0094\u00CB\u00D6WT\u00AFa\u00AF\u00FF\u00A8[\u00BA\u00F9\u00FE\u00D6L\u00C3D\u00E3|\u00D3\u00DA=\u00CEV\u00996\u00C7\u008E\u00E8\u00AE\u00F4G\x15\u00DD-\u00BD\x13OY\u009E\x11\x06\u00BC^\x1C\x7F\u00D53\u008C~C\x1C\u00CD\x1D\x1F{'7\u0095:3\u00F4~\u00E7\u0087\x03\u009F\u00A6\u0097l\u0097\u00AF\u00ACr\u00AC\u00C5l\u00CC|\u00B7\u00FAy\u009F\u00C1\u00D8\u00FEI\x00;\b\u0080,\u00E8\u0080=\x04\u00C1A\u00B8\x00]\u00F0\x01\u00C1\u00870FD\"\u00CA\x11CH.\u00A452\x1B\u00F9\u0098\u0089\u008D\u00C9\u0089\u00A9\u0088i\x12\u00A5\u0084JFu3\x0B1\u00872\u00B7\u00A01h*\u00BA\u009BE\u0091%\u0087\u00E5\x13\u00AB3k\x03\u009B\x04\u00DB\x11\u00B6/\u00EC>\u00EC=\x1C\u00DA\x1C\u0095\u009C|\u009C\u00879\u00D7\u00B9B\u00B8\u00DEb\u009C0\x1D\u00DC\u00DA\u00DCWydx\u00CE\u00F2\u00F2\u00F0\x1E\u00E1\u00FD\u00C5\x17\u00CF\u00B7\u00C2O\u00E5\u009F\u00C4\u00EE\u00C5\u00BE\x16p\x14\u00E8\u00C3Y\u00E1:\x04\u008D\x04\u009B\u0084t\u0085\u00EE\nk\n\u00D7\u0089\u00A8\u008B\u00DC\x10U\x17m\x123\x16\u00EB\x12\u00B7\x13\x1F\u0092\u00F0\u0097X\u0092L\u00C5\u00B3\u00E1\u008B\u00A5vJ\u00B5K\u00BBK/\u00C8d\u00CBJ\u00C86\u00EF\u00F0\u00D8\u00B1.W$o(?\u00AA\u0090\u00A1(\u00AF\u00F8|g\u00A2\x12^\u00A9G9FEJ\u00E5\u0095j\u00A6\u009A\u00A6\u00DA\f\u00A1H\u00DDZ}K\u00A3Q3JKVkD\u00FB\u00B8\u008E\u0083.Nw]oJ\u00FF\u0089A\u00A3\u00E1\u00E5]g\u008Dr\u008C\u0093M\"L\u00FD\u00CD<\u00CD\u00F7\x10\u00AD-\u008C,u\u00AD\u00B4vkY\u00EB\u00D8h\u00DB\x1A\u00D9Y\u00D9;;\u00F88\x06;%9\u00E7\u00ED\u00A9vis\x1Dv\u00DB\u00F0\x10\u00F74\u00F7\u008A\u00F4.\u00F6y\u00EA\u00CB\u00BC\u008F\u00E0\u00E7\u00E9\x7F$\u00A0\u00814E\u00C6R\u00AC\u0083\u00D2\u0082\u00EBC\u00E6\u00A82a\u00A4\u00F0\u00F2\u0088\u0089(\u00B1h\x7FZ\u00D5\u00FE\u00A5\x18\u008D\u00D8\u00A4\u00B8\u0087\t\u0098D\u008F\u00A4\u00D2\u00E4\u00D9T\u009D\x03\u00D9i/2$\x0FF\x1Cj\u00CE\u00E4\u00CA\"e\u00D7\x1D\u00F9\u009E\u00E3p\u00F4V\u009E\u00CD\u00B1\u00AD\u0082\u009AB\u00BF\u0093\u00C2\u00A7\u009E\u009E9\\\u00AC[\u00B2v\u00AE\u00B1,\u00AA\\\u00A1b\u00BE\u00F2\u00E6\u00A5\u0084j\u00D3\x1A\u00FE+\u00EF\u00AF\u00DD\u00AF=}#\u00BE>\u00F0\u00B6\u00DD\x1D\u009D\u00BB\u00EA\u00CD\u00AA\u00F7\u00B4Z\u008D\u00DA\u00BC:(]f\u008F\u00D4\u00BBEz9\u00FB\u00B6\u009En>[\x1A\u00F8\u00F0\u00E2\u00EB\u00AB\u009F\u00C3\x1CoDF\u00B5\u00C6=\u00FFN\u0099\u00AC\u009C~9\u0087\u009A\u00D7\u00FA\x18\u00BE\u00D0\u00B0\u00B4\u00F1\u00C5h\u00F5\u00E0\u00DA\u008BM\u00C5\u00EF\u00F4\u009F\u00AF\u00FE\u00F4\u009F\x03\x04A\x0E\u00F4\u00C1\tB!\x13\u00AA\u00A0\x1B\x16\x118\x04\x11\x11\u0083\u00A8FL \x05\u0091\u00EE\u00C8\"\u00E4\x04\u0093\x1CS,\u00D3c\u0094\x18*\x015\u00C4\u00AC\u00C7\\\u0081fG\u00A7\u00A0\x17YBY\u00A6X\x03X'\u00D8\u00F6\u00B1M\u00B0\x07\u00B2\u00CFrP9\u00969\x138\x19\\9\x18\x1C\u00A6\u0092[\u008D\u00BB\u008Dg\x0F\u00CF,\u00EF\x01>,_\x1D\u00BF\x03\u00FF\"\u00B6P@W`\f\u0097'\u00B8KpA\u00E8\u0092p\u00A0\u0088\u00AC\u00C8\u0090h\u00BE\u0098\u00B58B\u00BC]\"M\u00D2\x1C\u008F\u00C2wK\x1D\u0097\u00DE+\u00A3 \u00B3&\u00DB\u00B5\u00E3\u008C\\\u00B8<Q\x01\u00A7\u00F0E\u00F1\u00E9\u00CE\u00CBJ\x07\u0095}U\u008CU\u00A5\u00D5\u0098\u00D4f\t\u00BD\u00EA\u00B5\x1AE\u009A\x07\u00B5\u0082\u00B5\x1Duv\u00E9\u00AA\u00EB\u00E9\u00EA\x1B\x19\u0098\x1A\u00DA\u00EC\u00F24\"\x19\u0087\u009B\u00C4\u009B\x1E6;m~\u0099x\u00DB\u00A2\u00D3r\u00C8\u00EA\u00935\u00CAF\u00C8V\u00DB\u00CE\u00CD>\u00C6\u00E1\u0084c\u0083\u00D3\u00E8\x1E\u00B4\u008B\u0096\u00AB\u00BF[\u0081{\u00AF'\u00C2\u00CB\u00CC;\u00DD\u00A7\u00DBW`\u009F\u00BD_\u009A\x7FS\u00C0R\u00A0\"\u0099B\u00A9\x0E\u009A\x0F\u0091\x0B\u008D\u00A0\u00B6\u0084\u00A3\"\u00DC\"/D}\u00A5\u00D9\u00ED\u00AF\u00A63b\u00BD\u00E3\u009A\x13\u0084\x13\x13\u0092^\u00A4h\u00A5\u0096\u00A7\u00A1\u00D3C3\x06\x0Ei\x1D.\u00CF\u00C2d\u00C7\x1F\x19\u00CD\u00D9}\u00B4#\u00CF\u00E3\u00D8FAa\u00A1\u00E6\u0089\u00F1S\u00E9g\u00A4\u008B\x1E\u0095\u0084\u009F\x13-\u00ED8O\u00AE\u00E0\u00B8\u00D0|1\u00AC\n[\u00DDS\u0093qU\u00E7\u00DABm\u00D5\rJ\u00BD\u00E2\u00AD\u00A5\u0086\u00DA\u00C6\u00A4&\u00BB\x16\u0089{+\u00AD\u00CF\u00DA\u00EEv$u\u00CE?t|t\u00BF\u009B\u00D0s\u00B5O\u00E2\u00C9\u00C9~\u00F4\u00B3\u00A4\u00E7\u00AB\u0083\u00DE/\u009E\u00BD\u00D2\x1B*\x1F\u0086\x11\u00EF77GQc\u00EE\u00E3\u00E7'&\u00DE\u00C9N\u00FAN\x1D\u009B\u00BE732\u00BB\u00F6\x1E;\u00AF\u00F4\u00C1\u00F4\u00A3\u00E3'\u0097\x05\u00A7E\u0087%\u00DB\u00CF&\u00CB\x1A_\u00F0+\u00EC+\u009FW\x07\u00BF\u00D6\u00AD\u00E5\u00ADS7\u00CC7y6'\u00BE]\u00FF\u009E\u00FC\u00C3\u00E6\u00A7\u00E0\u00CF\u00F1\u00AD\u00B2_]\f\x06\u00C0\u00F6\u00BE\x04\x00\x00\u00EC\u00C4\u00E8\u0088h:\u00DE\u009Eh\x01\u00FF\u00BF\x12\x19\x11\u00F7\x0F\x07\x0F\x00pRcm\u00DC\x00\x00\x0B\x00\x03\u00C1t+\x17\x000\x07\u0080\u0099\u00A8@G'\x00\u00E0\x03@\u00C8\x05\u00C5X\u00BA\u00FE\u00C6z\u00C1T+\u009B\u00EDX\u0084--\u00D6\u00D9\r\x00\u0084\x00\x10>\u00C9\u00A1n\u009E\x00\u0080\x01@\u00D0\u00C3H\u00B6\u00CE\u00BFqFT\u0084\u00A3=\x00\u00E0\x00\x10\u00F9\u0094 \x0B\u00CB\u00DF\u00B1\u0097\u00E8q.\u00EE\x00 \x0B\u0080h\b\u008F\u00B6s\x01\x00N\x00\u00C4HP\u0094\u00FB?\\31\u00F1\u00AE\u00FF\u00F8\u00AFSH\x16v\x00 \x06\u0080D'\u0087\x12\x1D\u00B7\u00FD\u0091\u00D2`\x0FD\u00B0\x00<\u0090!\x1A\" \x1A\u00E8@\u0085^ \x03\x1DH\x10\x05xx\x07x \x03\x1D\u00A8\x10\x03\u00B1@\u00828H\x04<D\x00\x15\u00F6C\x1CP\u0081\x02A\x10\u00F3;>\x0E\" \b\u00E2\u0080\x0EV@\x02:\u0084@\x10\u00A8\u00FCf\u00F8\u00EF<\x1E0\x03t\u00A0\u00FE/\x1ET\u00A0@\u00B4?\u00F5\x10=\u00F2Vp|qt\u0092\u0081G(\u00E1\x1A\u00E1\x03\u00E1'\u00E0\x7F{\u00DB\u00FDa\f\u0082\u00A8?\u0099\u00B6\u00D9\x03\u00FF\u00D1Qr(\r\u00946\u00CA\x1Ce\u00842F\u00E9\x03\x1E\u0085C\u0089\u0080\nJ\x0B\u00A5\u00872C\u0099\u00A0\fQ\u00DA(\u00FDg\x0Bw\x17\u00FEd%\u00FE\u00A9\x00\u00FF'\u00E3\f\u00D0!\u00E4?jU\u0081` \x01\x1D\u00E2!\bb \x1C\u00E6\u0080\x0E\u0091\u00FE\u00D4C\u00FF\u00C6\u00C1\u00F6\u00AE\x0E\x00\u0080\u00E6\x01(\r\x00\x00h\u00DBL\u00C9\u00F8\u00CFw\x15\x1B\u0094\x18\x0B\x00@\u008C\u00A6%\u00D1\u00A9!\u00A1\u00B1x3\x1A-\"\bO\u008C\u008E\u00A4\u00C5\u00C5\x06\u00D1\u0095\u00F16QdUe\u00BC\x06\u0081\u00A0\r\x00\u00F0_\x14\u00F7T\u00A9\u00D4J\u008B\u00F2\x00\x00\x00 cHRM\x00\x00m\u0098\x00\x00s\u008E\x00\x00\u00E2\u00F9\x00\x00\u0086\u0099\x00\x00x\u0083\x00\x00\u00D4N\x00\x003\u00BC\x00\x00\x1Cyc\u00E1\x1F,\x00\x00\x00\u00A2IDATx\u00DA\u0094\u0091\u00B1\r\u00840\x10\x04\u00C7>\x07\u00D0\n=P\x07\x05\u0090\"\u008AA\u00A4\u00D4@\x05n\u00C3]\\\u008C\x03l\x7F\u00F0\x12\u00C9\x0B\u00F0_x\u00BA\u00DB\u00DD\u00D1\x1AU-)%D\x04\x11!\u00E7L)\u0085\u00DAq\x00\"\u0082\u00B5\u0096\u0094\u00D2\u00CF\u00C14M\u00B7\u00CF\u00EB\u00BAbT\u00B5\x18cn]\u009B\u00A6\u00B9\x15\u00881~\x13<E\u008E1\u00BE#\u00EC\u00FB\u008E\u00F7\u00FEZ\u00F6}\u00CF0\f\u00F5\b\u00CE9\u0096e!\u0084@\u00D7u\u00CC\u00F3\u00CCy\u009EU\bFU\x0B@\u00CE\u0099m\u00DB\x18\u00C7\x11kmu\x0B\u0097\x00@\u00DB\u00B6\x1C\u00C7\u00F1\x7F\x0BO\x0Eo\b\u009F\x01\x00\u009B\u00FDU\u00A2t\u00A1Hz\x00\x00\x00\x00IEND\u00AEB`\u0082"));
                      // create a data folder for your script in the user's application data
                      var myDataFolder = new Folder( Folder.userData.absoluteURI + "/SampleScripts" );
                      // make certain the folder exists
                      myDataFolder.create();
                      // write the image file
                      var myFile = new File( myDataFolder.absoluteURI + "/myFile.png" );
                      myFile.open( "w" );
                      myFile.write( myBinary );
                      myFile.close();
                      // there is now a valid png image in your script's user data folder
                 // example of using ScriptUI's drawing api to make a dropdownlist draw as an icon (until the user clicks it, then it's a menu)
                 myFlyout = function( palette ) {
                      palette.myFlyout = palette.add( "dropdownlist", [ ( palette.frameSize.width - 20 ), 0, palette.frameSize.width, 20 ] );
                      palette.myFlyout.onDraw = function() {
                           this.graphics.drawImage( ScriptUI.newImage( myIconFile ), 0, 0 );
                      if ( !palette.onShow ) {
                           palette.onShow = function() {
                                this.myFlyout.draw( this );
                 // A slightly more complex example putting it all together where you can pass a callback function and an array of menu items
                // this function will add a flyout menu to the top-right corner of any ScriptUI window. It does not need to be a palette.
                 addFlyout = function( palette, menuItems, callback ) {
                      // create a script data folder to contain resources such as the flyout icon
                      var myScriptDataFolder = new Folder( Folder.userData.absoluteURI + "/SampleScripts" );
                      myScriptDataFolder.create();
                      // point a file to the expected location of the icon image
                      var myFlyoutIcon = new File( myScriptDataFolder.absoluteURI + "/flyoutIcon.png" );
                      if ( !myFlyoutIcon.exists ) { // if it's not there, then create the file
                           var binData = (new String("\u0089PNG\r\n\x1A\n\x00\x00\x00\rIHDR\x00\x00\x00\x10\x00\x00\x00\t\b\x06\x00\x00\x00;*\u00AC2\x00\x00\x00\tpHYs\x00\x00\x0B\x13\x00\x00\x0B\x13\x01\x00\u009A\u009C\x18\x00\x00\x0FciCCPPhotoshop ICC profile\x00\x00x\u00DA\u00ADWi8\x14\u00EC\u00D7?3\u00C6\u00D8\u00C76\u00C6\u00CEX\u00B2d\x1B\u00FB\u0096u\u0090\u009D\u00EC$\u008C\x19\u00CBX\u00A7\u00B1/\u00A1B\u008F\u0088\u00B4\u00A1\u0088\x14i\u00A1\u0094\u0084\u0092\u00AD\u00B2\u0094\u00A2\x12ey\u00B2\u00A6B\"K\u008B\u00E6\u00FD\u00A0\u00A7\u00E7\u00BA\u00FE\u00EF\u00F5\u00BE\u00EF\u0097\u00F7|\u00FA\u009Ds\u009Ds~\u00E7\u00BE\u00CF}]\u00E7>\x00\u00BCB$\x1A-\x02\t\x00\u0091Q\u00B1t\u0097\u00DD\u00E6x/o\x1F<\u00CBk\u00E0\x04~\u00C0\u0082>H\u0092\u00C8143gg{\u00F8\x1Fe\u00FD5 \x00\x00^\u00AA\u0090h\u00B4\u0088|\u00F6\x00J\u00DF\u00D4\u00D9\u0092z\u00C3\x15\u00E7/\u00B2\u0087d\u00E1\x7F\x17\f\u00DD\u00CB\u00DB\x07\x00\u00A1\f\x00\u00D8\u0090ml\n\x00\u00D8\u00C0m\u00EC\x06\x00\u00D8\u0084XZ,\x00\"\x14\x00\u00B0\u00E4P\x12\x05\x00\u0091\n\x00\u00CAt7\x17\"\x00\u00A2\x06\x000!\u00DB\u00B8\t\x000\u0081\u00DB\u00B8\x07\x000\u00F1\u00E4\u0090X\x00\u00C4\b\x00\u009A/\u008AB\u008D\x02`Y\x00@\x1BS\u0082b\u00C8\x00\x18e\x00\u00A0Pb\u00C8\u0091\x00\u0098\u00E3\x00H\u00D5\u00C8\u00C8h\n\x00O;\x00(\u0090i\u00F4X\x00\u009Ey\x00P\u00F1\u00F2\u00F6\u00C1o\u0097L\u00D9\x000@\x01\u00A0\u00DF\u00FEk\x0B\u0093\x02\u00A8\u00BD\x03 &\u00F5\u00AFM\u00FE\x01\u0080\x10\t\u00E0\u00E6\u00CE\x7Fm\u00AB.\u0080\x00\x00\x04\u00EEyL\u00B0\u00A6\x06\x00\x00 8\u00CD\x01\u0098'\x18\u008CU9\x00\u0096\x13\x00[\u0085\f\u00C6\u008FJ\x06c\u00EB\"\x00\u00D3\x18@{\x049\u008E\x1E\u00FF\u00FB\u00BE\x10\u0088~\u0080\u00FFK\u00DF>\u00F3oaB\x00 \x01\u0090jL\u008E\u00A8P\u00E6\x03\u00E8\x12\u0096\u009B\u00AC\u009Dl#\u00EC\u009F8V\u00B8\u00D81\u0082\u00DCR<*\u00BC\x06|f\u00FC\u00F6X7\x01O\u009C\u009F Y\u0088*L\x13\u0089\x11\u008D\x15\u008B\x13O\u0094H\u0091\u00CC\u00C0gJeJ\x1F\u00919*\u009B\u00BF\u00E3\u00B4\u00DC9\u00F9\n\u0085\x1A\u00C5\x1B;\u009B\u0094\u00BA\u0095\u0087T&U\u00D7\t\u00EC\u00EA\u00D2\x1A\u009A\u009A\u00EEZ)\u00DA\x15:}\u00BA\u009B\u00FA\u008A\x06$\u00C3s\u00BB\u00C6\u008D%M\u00A8\u00A6w\u00CD9\u0089\u00FB,n[\u00F1\u00ED\u00A6[\x0F\u00DA\u00AA\u00D9\x1D\u00B3\u00FF\u00E2h\u00EFT\u00B7\u0087\u00DB%\u00C2\u00B5\u00CF]\u00D4#\u00C2\u00F3\u00817\u00C6\u00C7\x7Fo\u008D\u00EFW?\u00A2\u00FF\u00D1\u0080\u00FE@n\u00B2\x13\u00E5D\u00D0\u00F3\x10\u00F6P3j\\X]\u00F8d$\x7F\u0094Et\x02\u00ED\u00FA\u00FE\u00B71\u00A8XB\u009C\x7F|^\u00C2\u00FD\u00C4\u00F9d\u00DE\x14\u00E3T\u00DA\u0081\u00F2\u00B4\u00EE\u00F4\u00B1\u008C\u00A9\u0083\u00B3\u0087\x16\x0E/g\u00AEd\u00ADgo\u00FD\u0085\u00CA\u00E1<\u00CA\u009B+\u0090'~L!_\u00B3\u00C0\u00F0\u00B8Y\u00A1\u00F5\u0089='=N\u00F9\u009C\u00F6;C.\u00A2\x16\u0087\u0097\u0084\u009F\u00A5\u009E\u00A3\u0096\u0086\u0095\u0085\u009E'\u0095\u00FBT\u00B8^\u00B0\u00AB4\u00BD\u00A8~I\u00B1J\u00BEz\u00C7e\u00E9\x1A\u00FC\x15\u00F1\u00AB\u00C2\u00D7\x04\u00AE\u00F3\u00D6\u00F2\u00D4q\u00DE`\u00BE\u00F1\u00EB\u00E6f\u00FD\u00EA\u00AD\u00C5\u00DB\u00B3\r\u00A3w\x06\x1B\u009F\u00DE\u00EDjjn\u00AEo\u00B9~\u00EF\u00CA\u00FD\x0B\u00ADg\x1E\u00E4\u00B7\x1Dm\u00CF\u00EC8\u00D8\u0099\u00DCE\x7F\x18\u00F5(\u00EAqD7\u00A9\u0087\u00D8\u008B\u00EB\u009D\u00EA\u00BB\u00F5$\u00FD\u00A9m\u00BF`\u00FF\u00DC\u00B3\u0086\u00E7\u0099\x03.\u0083\u0092\u0083\u008B/\u00DA_\x16\u00BE\u00F2\x1FR\x19\u00FA\u00FE\u00FA\u00C9p\u00D1\b\u00E9\u008D\u00CA\u009Boo\x1F\u008F\x16\u008Cy\u008C\u008B\u008F\u00CFL\u00D4\u00FEM\x7F\u00A7\u00F3\u00EE\u00DBd\u00CBT\u00CA\u00B4\u00C1\u00F4\u00FAL\u00E3l\u00EA\u009C\u00D9{\u00A6\u00F7\u00BD\u00F3y\x1F\x1C?\u00F2||\u00F9\u00A9h\u00C1kQhqd\u00A9\u00F8\u00B3\u00D7\u00B2\u00D0\u00F2\u00D0\u0097\u00C2\x15\u00C7U\u00AE\u00D5\u00DE\u00AF\u0099kfk\u008C\u00F5\x07\x1B\u00C9\u009B\u00DA\u009B\u00CB\u00DFj\u00BF\u0087\u00FFP\u00FC1\u00F7\u00B3r+\u00E0\u0097\u00E4\u00AF\u00B7\u008C\u00FD\f\x06\x00\x12\u00C5\u00C4\u0087\u00C21c\u00D1\x02,\u00DC\u00AC\x1Cl\u00ACl[\u00EC\u00DF8>s\u00CEp\u00BD\u00C1\u00F4sw\u00F0\u00D4\u00F3V\u00F2\u009D\u00E2\u00CF\u00C2&\b\u0084\u00E3\u00F6\t:\t\x11\u0085\u00F5EtD\u0095\u00C5\u00D4\u00C4U%t$\u008D\u00F1\u0096R&\u00D2z2*\u00B2\u00CA;\u0094\u00E5v\u00CA\x13\x14\u0094\x15\t;u\u0094\u0088\u00CA\u00B6*^\u00AAT\u00B5$B\u008Ez\u0099F\u00A3\u00E6s\u00AD%\x1D^]-=W\u00FDd\u0083\u00CB\u0086\u00C3F\u00AC\u00C6\u00DA&\u00FBMk\u00CD\u00E6\u0089J\x16\u00E1\u00967\u00AC6\u00AD-mrmG\u00EC\u00D5\x1DR\x1D\x07\u009DE\u00F7\u0084\u00B84\u00BA!\u00DC\x1D<Nx\u008Ey+\u00FA\u00D0\u00F6\u00DE\u00F2\u00DD\u00F0\u00D3\u00F3?\x10\u00D0F\u00DA\"\x1BR\u00E2\u0083\u00EE\x06\u00AF\u0086\u00AAR\u00C3\u00C2\u00AE\u0086\x7F\u008C\u0094\u008B\u00F2\u008D.\u00A6\u00BD\u00A6\u00F3\u00C7\u00B8\u00C5\x16\u00C6\u00F5%\u00B0&\u00DA'\u00E5'?J\u0099N\u00FDt\u00E0s\u00DAZ\u00FA\u00B7\u008C\u00EF\x07\x7F\x1Df\u00CE\u00E4\u00CC\u00E2\u00CF\x16>\"\u00FE\u0097l\x0E\u00E1\u00A8A\u00AEy\u009E\u00CD1\u00A7|\u00AF\x02\u00DF\u00E3\x01\u0085\u0094\x13a'\u00A3O\u00D1N\u00D3\u00CFD\x17E\x15\u00D3J\"\u00CF\x06\u009F\x0B(\u00F5*s>oY\u00AES\u00A1rA\u00A5R\u00F9\u00A2\u00E2%\u00C5*\u0085j\u00B9\u00CB\u00B252Wd\u00AF\u00CA\\\u0093\u00BC.V+R'|C\u00E8\u00A6@=\u00DF-\u00EE\u00DB\u00DC\r\u0098;\\\u008D\\wy\u009Bp\u00CDB-B\u00F7D\u00EF\u00E3[\u00E5\x1F\u00A8\u00B6i\u00B7\u00EBw\u0098w:v\u00F9<\u00DC\u00FBh\u00F7c\u00FC\u00E3\u0095\u00EE\u00DE\u009E\u00D2\u00DE\u00C8>\u00B3'\u0082O\x16\u009F>\u00EA/y\x16\u00F9\u009C8 >\u00B0>\u00D8\u00FF\u00A2\u00F2e\u00C2+\u00C7!\u00E9\u00A1\u00B5\u00D7\u00BD\u00C3\u00A5#\u00D1o\u00CC\u00DE\u00F2\u00BE\x1D\x1F\u00BD>\u0096:n=\u00C1;1\u00FAw\u00E5\u00BB\u00B0I\u00D5\u00C9\u00E5\u00A9\u00A6\u00E9\u00E33\u00A1\u00B3&s\u0082s\u008B\u00EF\x1F\u00CE\u0097|\u0088\u00FAh\u00F9I\u00F8\u00D3\u00C7\u0085\u00FB\u008B\u00C7\u0096\u00F6}V\u00FD\u00FCc\u00B9\u00FB\u00CB\u0089\x15\u00BFU\u00C5\u00D5\u0095\u00AF\u00F7\u00D6\u00B2\u00D7\u009D7\u00846\u00C66+\u00BFQ\u00BF\x13\u00BEo\u00FE\u00B8\u00FF3c\u00CB\u00F2\x17\u00E6\u00D7sF\u00E4v\u00FF\u0091\x1BL\u00CB\u00A8\u00AF\u00CC\u009F\u00D1\u008B,\u008B\u00AC\u008Bl\x13\u00EC\u00A3\x1C\u00AF8\u009Fp\u00B5b\u00EA\u00B8\u00CByry\x13\u00F8(\u00FC\u00F6X\u0082\x00\u00B7\u00C0*nP\u00F0\u009AP\u00A6\u00B0\u00AF\bA\u0094YtX\u00ACJ<N\u00C2R\u0092[r\x1C_%\x15)m \u0083\u0096y-{eG\u009A\u009C\u00BB\u00BC\u00B2\x02\u00AB\u00C2{\u00C5\u00EE\u009D5J\u00C7\u0094cU\u00F6\u00AA\u009A\u00AB\u00A9\x12\u00C4\u00D4\u00D9\u00D474f5\x07\u00B5\u00DA\u00B5o\u00EA\u0094\u00E9\u00E6\u00E8\u00C5\u00EB\u0093\f\u00EC\rw\u00ED\u00C2\x1B\u00A1\u008D\u0096\u008D\u0087L\u00EE\u0098\u009E4\u008B7\u00A7\x12=-\u00AC,\u00F5\u00AC\u00E4v\x0BY3[\u00AF\u00DB|\u00B0}c\u00D7c\u00DF\u00E8P\u00EDX\u00EC\u0094\u00E3\u009C\u00B8'\u00C4\u00C5\u00C3\u00D5\u00DE\u00CD\u00D0]\u00D9C\u00D2\x13\u00E7\u00C5\u00E5\u008D\u00F4\u00FE\u00EA\u00F3a\u00EF\u0094\u00EF\u00DB}\u00AF\u00FC\u00FA\u00FD\u00BB\x02\x1E\u0090Z\x03[\u00C8\u00B7(\x17\u0083r\u0082\u00E9!\u00FE\u00A1\u00D6T\u00B50\u0091p\u0096\u00F0\u00B5\u0088\u0099\u00C8\u00C1\u00A8\x07\u00D1u\u00B4\u00CA\u00FDg\u00E8\x7F\u00C5$\u00C6\u0086\u00C6\u00F9\u00C5;&\x18'\u00AA%I%cSP)\u00AB\u00A9\u00EF\x0E<K{\u0090~-\u00E3\u00D4\u00C1\u00F4C\u00C1\u0087\u009D2\u00B5\u00B2p\u00D9\u0088\u00EC\u008D#\u008B\x7FM\u00E7\u00BC=:\u0090\u00DB\u009D\u00D7r\u00ECF~MA\u00E9\u00F1\u00DC\u00C2\u00F4\x13\u00B4\u0093\u0094S\u00EE\u00A7\u00AD\u00CEh\x15\u00C9\x16\x0B\u00940\u0097|=;{n\u00A4\u00B4\u00BF\u00EC\u00C1\u00F9\u00EB\u00E5e\x15'/dU\u00A6^\u008C\u00BED\u00AA\u00F2\u00AC\u00DEs\u00D9\u00A6\u00C6\u00F0\u008A\u00F4U\u00B8:v\u00ED\u00FE\u00F5\u00E2Zz\u009D\u00D3\r\u00D5\u009B\u0098\u009BK\u00F5\u00FD\u00B7\u00AE\u00DC\u00CEm\u0088\u00BE\u00E3\u00DA\u00A8}\x17ww\u00A3i\u00AC\u00B9\u00B5\u00A5\u00EC^\u00DA}R+\u00F1\u00C1\u008E6\u00E6\u00B6\u00E9\u00F6\u00AE\u008E\u00EA\u00CE\u00CC.\u00D2C\u00A3G\"\u008F\u00D6\x1F\x0FtW\u00F5\u00E4\u00F6\u0096\u00F6u<\u0099z\u00CAx&\u00F2\\\x7F\u00C0g0\u00F5E\u00E9\u00CB\u009EW\u008B\u00AF\u00C5\u0086\u009DFr\u00DF<\x1D\u00E5\x1F\x0B\x18o\u00FE\u009B\u00FF]\u00FA\u00E4\u00D7\u00E9\u0083\u00B3\u0098\u00B9\u00CB\u00F3\u00CE\x1Fy?\u00BD^\u00AC\u00FB|\u00E6K\u00E1j\u00D9Z\u00FD\u00C6\u00DCw\u00FC\u00CF\u0080_i\f\x06\u00C0\u00F6\u00EC\x03\x00@\u00EB\x00\x14\u00C7\x01xM\x02\u00B8T\x01\x14l\x01(p\x02\u00E0j\x00\u009C\u00B9\x00\u00DC\u00F4\x01\u00D1Y\x00\u0088kY\u00800/\u00F8g~\x00\x00\x12X\u0081\x17$@\x05L\u00C0\r\" \x1B.\u00C2C\u0098E\u00B0#4\x10\u00BE\u0088\u00BF\x10M\u0088\x0FHq\u00A4;2\x1F\u00D9\u00C7\u00C4\u00CAd\u00CD\u0094\u00CB4\u0088\x12AQP\u00F5(\x06\u00B3\x13\u00F3E\u00E6ohg\u00F4U\x16\x14\x0B\u0089\u00A5\u009DU\u008A\u00F50\u00EB<\u009B\x03[=\u00BB\b{&\u00FB\x02\u0087'G'\u00A7\x06g\x19\x17\x0BW\x1C\u00D7\x14\u00C6\t\u00D3\u00CA\u00AD\u00C4]\u00CC\u00C3\u00C2\x13\u00C33\u00C9\u00EB\u00CC\u00DB\u00CA\u00A7\u00C4W\u00CC\u00CF\u00CC\x1F\u00C7?\u008Bu\u00C5v\b\x10\x04*p|\u00B8,\u00DC7\u00C1\b\u00C1wB\u00DEB\u00CF\u0085w\x0B\u00B7\u008B\u00EC\x12i\x14\u00D5\x11m\x113\x16\u00EB\x14\u00B7\x16\x1F\u0090\u00F0\u0092\u0098\u0095\u00A4K2\u00F0yR\x12R\u00B7\u00A5m\u00A4'eRd\u00B1\u00B2\u00F5;\u009Cw\u00AC\u00C8\x15\u00C9\x1B\u00CBO+\u00E4)\u00EA+\u00CE\u00ED<\u00ADd\u00A1\u00B4\u00AA\\\u00AD\u00E2\u00A7*\u00A4:\u00A0\u0096C\u00B0T\x07\u00F5V\u008DtMs-&\u00ADN\u00ED,\x1D{]\t=\u00A4\u00DE\u0092\u00FE\u00B0A\u00A7\u00E1\u00ED]UF\u00A7\u008C\u00B3L\x12L\u00C3\u00CC\u00C8\u00E6\u00FB\u0088\u00AE\x16\u00D6\u0096\u00E6V&\u00BBM\u00ADMmLmw\u00DB9\u00DB\u00FB8\x049\u00D2\u009C\x0E;\x17\u00ED\u00A9w\u00E9u\u009DtGx\u00C8{:x%xW\u00FA\f\u00FBr\u00EF3\u00F0#\u00FB\u009F\n\u00E8$\u00AD\u0092\u00E5)~AE\u00C1\u00FD\u00A1h\u00EA\u00EE\u00B0\u009C\u00F0\u00FEH\u009E(\u008F\u00E8\n\u00DAg\u00BAYLn\u00EC\u00DF\u00F1Z\t9\u0089c\u00C9*)GR\u00E7\u00D3,\u00D2\u00CB2~\x1C\u00F28\u00DC\u009C%\u0099\u009Dv\u00E4m\u008E\u00C9\u00D1;y\u00BE\u00F9b\x05C\u0085%'\x03O\u00CB\u009C\u00F9X\\w6\u00AD\u00D4\u00E1<\x7F\u00F9\u00E4\u0085\u00C6\u008B\u0085U\u0094\u00CB\u00D6WT\u00AFa\u00AF\u00FF\u00A8[\u00BA\u00F9\u00FE\u00D6L\u00C3D\u00E3|\u00D3\u00DA=\u00CEV\u00996\u00C7\u008E\u00E8\u00AE\u00F4G\x15\u00DD-\u00BD\x13OY\u009E\x11\x06\u00BC^\x1C\x7F\u00D53\u008C~C\x1C\u00CD\x1D\x1F{'7\u0095:3\u00F4~\u00E7\u0087\x03\u009F\u00A6\u0097l\u0097\u00AF\u00ACr\u00AC\u00C5l\u00CC|\u00B7\u00FAy\u009F\u00C1\u00D8\u00FEI\x00;\b\u0080,\u00E8\u0080=\x04\u00C1A\u00B8\x00]\u00F0\x01\u00C1\u00870FD\"\u00CA\x11CH.\u00A452\x1B\u00F9\u0098\u0089\u008D\u00C9\u0089\u00A9\u0088i\x12\u00A5\u0084JFu3\x0B1\u00872\u00B7\u00A01h*\u00BA\u009BE\u0091%\u0087\u00E5\x13\u00AB3k\x03\u009B\x04\u00DB\x11\u00B6/\u00EC>\u00EC=\x1C\u00DA\x1C\u0095\u009C|\u009C\u00879\u00D7\u00B9B\u00B8\u00DEb\u009C0\x1D\u00DC\u00DA\u00DCWydx\u00CE\u00F2\u00F2\u00F0\x1E\u00E1\u00FD\u00C5\x17\u00CF\u00B7\u00C2O\u00E5\u009F\u00C4\u00EE\u00C5\u00BE\x16p\x14\u00E8\u00C3Y\u00E1:\x04\u008D\x04\u009B\u0084t\u0085\u00EE\nk\n\u00D7\u0089\u00A8\u008B\u00DC\x10U\x17m\x123\x16\u00EB\x12\u00B7\x13\x1F\u0092\u00F0\u0097X\u0092L\u00C5\u00B3\u00E1\u008B\u00A5vJ\u00B5K\u00BBK/\u00C8d\u00CBJ\u00C86\u00EF\u00F0\u00D8\u00B1.W$o(?\u00AA\u0090\u00A1(\u00AF\u00F8|g\u00A2\x12^\u00A9G9FEJ\u00E5\u0095j\u00A6\u009A\u00A6\u00DA\f\u00A1H\u00DDZ}K\u00A3Q3JKVkD\u00FB\u00B8\u008E\u0083.Nw]oJ\u00FF\u0089A\u00A3\u00E1\u00E5]g\u008Dr\u008C\u0093M\"L\u00FD\u00CD<\u00CD\u00F7\x10\u00AD-\u008C,u\u00AD\u00B4vkY\u00EB\u00D8h\u00DB\x1A\u00D9Y\u00D9;;\u00F88\x06;%9\u00E7\u00ED\u00A9vis\x1Dv\u00DB\u00F0\x10\u00F74\u00F7\u008A\u00F4.\u00F6y\u00EA\u00CB\u00BC\u008F\u00E0\u00E7\u00E9\x7F$\u00A0\u00814E\u00C6R\u00AC\u0083\u00D2\u0082\u00EBC\u00E6\u00A82a\u00A4\u00F0\u00F2\u0088\u0089(\u00B1h\x7FZ\u00D5\u00FE\u00A5\x18\u008D\u00D8\u00A4\u00B8\u0087\t\u0098D\u008F\u00A4\u00D2\u00E4\u00D9T\u009D\x03\u00D9i/2$\x0FF\x1Cj\u00CE\u00E4\u00CA\"e\u00D7\x1D\u00F9\u009E\u00E3p\u00F4V\u009E\u00CD\u00B1\u00AD\u0082\u009AB\u00BF\u0093\u00C2\u00A7\u009E\u009E9\\\u00AC[\u00B2v\u00AE\u00B1,\u00AA\\\u00A1b\u00BE\u00F2\u00E6\u00A5\u0084j\u00D3\x1A\u00FE+\u00EF\u00AF\u00DD\u00AF=}#\u00BE>\u00F0\u00B6\u00DD\x1D\u009D\u00BB\u00EA\u00CD\u00AA\u00F7\u00B4Z\u008D\u00DA\u00BC:(]f\u008F\u00D4\u00BBEz9\u00FB\u00B6\u009En>[\x1A\u00F8\u00F0\u00E2\u00EB\u00AB\u009F\u00C3\x1CoDF\u00B5\u00C6=\u00FFN\u0099\u00AC\u009C~9\u0087\u009A\u00D7\u00FA\x18\u00BE\u00D0\u00B0\u00B4\u00F1\u00C5h\u00F5\u00E0\u00DA\u008BM\u00C5\u00EF\u00F4\u009F\u00AF\u00FE\u00F4\u009F\x03\x04A\x0E\u00F4\u00C1\tB!\x13\u00AA\u00A0\x1B\x16\x118\x04\x11\x11\u0083\u00A8FL \x05\u0091\u00EE\u00C8\"\u00E4\x04\u0093\x1CS,\u00D3c\u0094\x18*\x015\u00C4\u00AC\u00C7\\\u0081fG\u00A7\u00A0\x17YBY\u00A6X\x03X'\u00D8\u00F6\u00B1M\u00B0\x07\u00B2\u00CFrP9\u00969\x138\x19\\9\x18\x1C\u00A6\u0092[\u008D\u00BB\u008Dg\x0F\u00CF,\u00EF\x01>,_\x1D\u00BF\x03\u00FF\"\u00B6P@W`\f\u0097'\u00B8KpA\u00E8\u0092p\u00A0\u0088\u00AC\u00C8\u0090h\u00BE\u0098\u00B58B\u00BC]\"M\u00D2\x1C\u008F\u00C2wK\x1D\u0097\u00DE+\u00A3 \u00B3&\u00DB\u00B5\u00E3\u008C\\\u00B8<Q\x01\u00A7\u00F0E\u00F1\u00E9\u00CE\u00CBJ\x07\u0095}U\u008CU\u00A5\u00D5\u0098\u00D4f\t\u00BD\u00EA\u00B5\x1AE\u009A\x07\u00B5\u0082\u00B5\x1Duv\u00E9\u00AA\u00EB\u00E9\u00EA\x1B\x19\u0098\x1A\u00DA\u00EC\u00F24\"\x19\u0087\u009B\u00C4\u009B\x1E6;m~\u0099x\u00DB\u00A2\u00D3r\u00C8\u00EA\u00935\u00CAF\u00C8V\u00DB\u00CE\u00CD>\u00C6\u00E1\u0084c\u0083\u00D3\u00E8\x1E\u00B4\u008B\u0096\u00AB\u00BF[\u0081{\u00AF'\u00C2\u00CB\u00CC;\u00DD\u00A7\u00DBW`\u009F\u00BD_\u009A\x7FS\u00C0R\u00A0\"\u0099B\u00A9\x0E\u009A\x0F\u0091\x0B\u008D\u00A0\u00B6\u0084\u00A3\"\u00DC\"/D}\u00A5\u00D9\u00ED\u00AF\u00A63b\u00BD\u00E3\u009A\x13\u0084\x13\x13\u0092^\u00A4h\u00A5\u0096\u00A7\u00A1\u00D3C3\x06\x0Ei\x1D.\u00CF\u00C2d\u00C7\x1F\x19\u00CD\u00D9}\u00B4#\u00CF\u00E3\u00D8FAa\u00A1\u00E6\u0089\u00F1S\u00E9g\u00A4\u008B\x1E\u0095\u0084\u009F\x13-\u00ED8O\u00AE\u00E0\u00B8\u00D0|1\u00AC\n[\u00DDS\u0093qU\u00E7\u00DABm\u00D5\rJ\u00BD\u00E2\u00AD\u00A5\u0086\u00DA\u00C6\u00A4&\u00BB\x16\u0089{+\u00AD\u00CF\u00DA\u00EEv$u\u00CE?t|t\u00BF\u009B\u00D0s\u00B5O\u00E2\u00C9\u00C9~\u00F4\u00B3\u00A4\u00E7\u00AB\u0083\u00DE/\u009E\u00BD\u00D2\x1B*\x1F\u0086\x11\u00EF77GQc\u00EE\u00E3\u00E7'&\u00DE\u00C9N\u00FAN\x1D\u009B\u00BE732\u00BB\u00F6\x1E;\u00AF\u00F4\u00C1\u00F4\u00A3\u00E3'\u0097\x05\u00A7E\u0087%\u00DB\u00CF&\u00CB\x1A_\u00F0+\u00EC+\u009FW\x07\u00BF\u00D6\u00AD\u00E5\u00ADS7\u00CC7y6'\u00BE]\u00FF\u009E\u00FC\u00C3\u00E6\u00A7\u00E0\u00CF\u00F1\u00AD\u00B2_]\f\x06\u00C0\u00F6\u00BE\x04\x00\x00\u00EC\u00C4\u00E8\u0088h:\u00DE\u009Eh\x01\u00FF\u00BF\x12\x19\x11\u00F7\x0F\x07\x0F\x00pRcm\u00DC\x00\x00\x0B\x00\x03\u00C1t+\x17\x000\x07\u0080\u0099\u00A8@G'\x00\u00E0\x03@\u00C8\x05\u00C5X\u00BA\u00FE\u00C6z\u00C1T+\u009B\u00EDX\u0084--\u00D6\u00D9\r\x00\u0084\x00\x10>\u00C9\u00A1n\u009E\x00\u0080\x01@\u00D0\u00C3H\u00B6\u00CE\u00BFqFT\u0084\u00A3=\x00\u00E0\x00\x10\u00F9\u0094 \x0B\u00CB\u00DF\u00B1\u0097\u00E8q.\u00EE\x00 \x0B\u0080h\b\u008F\u00B6s\x01\x00N\x00\u00C4HP\u0094\u00FB?\\31\u00F1\u00AE\u00FF\u00F8\u00AFSH\x16v\x00 \x06\u0080D'\u0087\x12\x1D\u00B7\u00FD\u0091\u00D2`\x0FD\u00B0\x00<\u0090!\x1A\" \x1A\u00E8@\u0085^ \x03\x1DH\x10\x05xx\x07x \x03\x1D\u00A8\x10\x03\u00B1@\u00828H\x04<D\x00\x15\u00F6C\x1CP\u0081\x02A\x10\u00F3;>\x0E\" \b\u00E2\u0080\x0EV@\x02:\u0084@\x10\u00A8\u00FCf\u00F8\u00EF<\x1E0\x03t\u00A0\u00FE/\x1ET\u00A0@\u00B4?\u00F5\x10=\u00F2Vp|qt\u0092\u0081G(\u00E1\x1A\u00E1\x03\u00E1'\u00E0\x7F{\u00DB\u00FDa\f\u0082\u00A8?\u0099\u00B6\u00D9\x03\u00FF\u00D1Qr(\r\u00946\u00CA\x1Ce\u00842F\u00E9\x03\x1E\u0085C\u0089\u0080\nJ\x0B\u00A5\u00872C\u0099\u00A0\fQ\u00DA(\u00FDg\x0Bw\x17\u00FEd%\u00FE\u00A9\x00\u00FF'\u00E3\f\u00D0!\u00E4?jU\u0081` \x01\x1D\u00E2!\bb \x1C\u00E6\u0080\x0E\u0091\u00FE\u00D4C\u00FF\u00C6\u00C1\u00F6\u00AE\x0E\x00\u0080\u00E6\x01(\r\x00\x00h\u00DBL\u00C9\u00F8\u00CFw\x15\x1B\u0094\x18\x0B\x00@\u008C\u00A6%\u00D1\u00A9!\u00A1\u00B1x3\x1A-\"\bO\u008C\u008E\u00A4\u00C5\u00C5\x06\u00D1\u0095\u00F16QdUe\u00BC\x06\u0081\u00A0\r\x00\u00F0_\x14\u00F7T\u00A9\u00D4J\u008B\u00F2\x00\x00\x00 cHRM\x00\x00m\u0098\x00\x00s\u008E\x00\x00\u00E2\u00F9\x00\x00\u0086\u0099\x00\x00x\u0083\x00\x00\u00D4N\x00\x003\u00BC\x00\x00\x1Cyc\u00E1\x1F,\x00\x00\x00\u00A2IDATx\u00DA\u0094\u0091\u00B1\r\u00840\x10\x04\u00C7>\x07\u00D0\n=P\x07\x05\u0090\"\u008AA\u00A4\u00D4@\x05n\u00C3]\\\u008C\x03l\x7F\u00F0\x12\u00C9\x0B\u00F0_x\u00BA\u00DB\u00DD\u00D1\x1AU-)%D\x04\x11!\u00E7L)\u0085\u00DAq\x00\"\u0082\u00B5\u0096\u0094\u00D2\u00CF\u00C14M\u00B7\u00CF\u00EB\u00BAbT\u00B5\x18cn]\u009B\u00A6\u00B9\x15\u00881~\x13<E\u008E1\u00BE#\u00EC\u00FB\u008E\u00F7\u00FEZ\u00F6}\u00CF0\f\u00F5\b\u00CE9\u0096e!\u0084@\u00D7u\u00CC\u00F3\u00CCy\u009EU\bFU\x0B@\u00CE\u0099m\u00DB\x18\u00C7\x11kmu\x0B\u0097\x00@\u00DB\u00B6\x1C\u00C7\u00F1\x7F\x0BO\x0Eo\b\u009F\x01\x00\u009B\u00FDU\u00A2t\u00A1Hz\x00\x00\x00\x00IEND\u00AEB`\u0082"));
                           myFlyoutIcon.encoding = "BINARY";
                           myFlyoutIcon.open( "w" );
                           myFlyoutIcon.write( binData );
                           myFlyoutIcon.close();
                       } // the above code to create the file should only execute once for each user on the machine
                      palette._flyoutMenu = {}; // this object will hold the menu related stuff - prefaced with an underscore to avoid naming collisions
                      palette._flyoutMenu.items = menuItems;
                      palette._flyoutMenu.callback = callback;
                      palette._flyoutMenu.draw = function( palette ) { // actually draw the menu
                           // add the dropdownlist object to the window
                           palette._flyout = palette.add( "dropdownlist", [ ( palette.frameSize.width - 20 ), 0, palette.frameSize.width, 20], palette._flyoutMenu.items );
                           // make sure nothing is selected
                           palette._flyout.selection = null;
                           // add the onDraw method that will draw the icon instead of the normal dropdownlist
                           palette._flyout.onDraw = function() {
                                this.graphics.drawImage( ScriptUI.newImage( myFlyoutIcon ), 0, 0 );
                           // add the onChange method to fire off the callback
                           palette._flyout.onChange = function() {
                                this.window._flyoutMenu.callback( this.selection );
                                this.selection = null;
                      // execute the draw function to place the flyout in the window
                      palette._flyoutMenu.draw( palette );
            // sample usage
                 // create the menu items
                 var menuItems = [ "One", "Two", "Three", "-", "Four", "Five" ];
                 // create the callback function
                 sampleCallback = function( selection ) {
                      // just letting all the menu items fall through for this demo
                      switch( selection.text ) {
                           case "One" :
                           case "Two" :
                           case "Three" :
                           case "Four" :
                           case "Five" : {
                                alert( selection.text );
                 // create the palette
                 var myPalette = new Window( "palette", "Fly Out Menu Demo" );
                 // adding some static text, just because
                 myPalette.add( "statictext", undefined, "Demonstration of using ScriptUI drawing to customize control appearance" );
                 //center and show the palette
                 myPalette.center();
                 myPalette.show();
                 // add the flyout menu
                 addFlyout( myPalette, menuItems, sampleCallback );
            • 3. Re: [JS CS3/4] ScriptUI How to color a button ?
              Hi Kasyan,
              Regarding to the background color of the button, you get the same result as mine :
              I can accept backroundColor is not a property of a button but why is it told as one of the properties in the scriptui model ? A mistery.
              For you next error :
              I buyed and use as a basis RapidUI. So I create my items on this soft, grab the code and modify them in ESTK.
              Very weirdly, it generates this kind of argument for the color :
              var pen = g.newPen( g.PenType.SOLID_COLOR, [0.7, 0.7, 0.7], 1 ); //-> [R,G,B],A
              Meanwhile the scriptUI precises [R,G,B,A].
              But [R,G,B,A] throws an error. [R,G,B],A runs but alpha seems to be ignored.
              I can't tell why use once graphics and other time scriptUI. Let's hope We get some more detailed informations on ScriptUI styling  (and ScriptUI in general) soon.
              If it can help ?
              Loic
              • 4. Re: [JS CS3/4] ScriptUI How to color a button ?
                A quick question :
                I was able to place an image as a button background.
                However I was concerned as the path to the image is an absolute path. What if we use the script in another environment where the image is not located ?
                What becomes this image if we export the script for using it somewhere else ?
                Loic
                • 5. Re: [JS CS3/4] ScriptUI How to color a button ?
                  Peter Kahrel Adobe Community Professional & MVP
                  For 26 Euros (http://www.scriptui.com/) or 50 Euros (http://www.scriptuibuilder.com/) you could save yourselves a lot of time!
                  Peter
                  • 6. Re: [JS CS3/4] ScriptUI How to color a button ?
                    At the top of that script are two functions that show you how to embed an image as a json string in your jsx file. It then converts the string to a file that you can write to a known position.
                    Regards
                    Bob
                    • 7. Re: [JS CS3/4] ScriptUI How to color a button ?
                      Oh yeah great input Bob !
                      Sorry I ask before looking at :-)
                      Loic
                      • 8. Re: [JS CS3/4] ScriptUI How to color a button ?
                        Hi Peter,
                        I buyed and use pleasantly Rapid ScriptUI. It's clearly a great help.
                        However some behaviours disturb me. If you switch a color of a item, the dialog sometimes disappear but I can't tell if it's connected to rapiUI or Adobe ScriptUI errors.
                        I don't use http://www.scriptuibuilder.com/ but would be glad to hear comments on it.
                        Loic
                        • 9. Re: [JS CS3/4] ScriptUI How to color a button ?
                          Thank you for your example, Bob.
                          Loic,
                          Take a look at these lines:
                               var binData = (new String("\u0089PNG\r\n\x1A\n\x00\x00 ...
                          If the image file doesn't exist in the user data folder, it will be created by reading binary data right from the script — the image (binary data) is 'hidden' inside the script (text data). Very elegant!
                          Kasyan
                          • 10. Re: [JS CS3/4] ScriptUI How to color a button ?
                            Hi Peter,
                            I am incorrigible :-)
                            That's a great news anyway. Don't need it right now but now I know it's possible !
                            Tx for all !
                            Loic
                            • 11. Re: [JS CS3/4] ScriptUI How to color a button ?
                              > If the image file doesn't exist in the user data folder, it will be created by. . .
                              Very nifty indeed!
                              Peter
                              • 12. Re: [JS CS3/4] ScriptUI How to color a button ?
                                Steven.. Level 3
                                The reasor Rapid ScriptUI doesn't have background color for button is because of the mentioned error. IconButtons in CS4 have Title Layout which can have the text of the button in any color, also an image can be added without using onDraw
                                Steven Bryant
                                www.scriptui.com
                                • 13. Re: [JS CS3/4] ScriptUI How to color a button ?
                                  Steven.. Level 3
                                  A quick question :
                                  I use Dave Saunders function to get path to current script file folder (allows debugging)
                                  function getScriptFolder(){
                                       try {
                                            var activeScript = File(app.activeScript);
                                       } catch(e) {
                                            // running from ESTK ...
                                            var activeScript = File(e.fileName);
                                       return activeScript.parent;
                                  and reference to it
                                  getScriptFolder() + "\\mypic.png"
                                  • 14. Re: [JS CS3/4] ScriptUI How to color a button ?
                                    Steven.. Level 3
                                    Sorry to hear about this issue, please see if you can duplicate and contact us at http://scriptui.com/contact.aspx
                                    Steven
                                    www.scriptui.com
                                    • 15. Re: [JS CS3/4] ScriptUI How to color a button ?
                                      Dirk Becker  Level 4
                                      If you just accept that the background color property is readonly and meant for your reference, it becomes pretty easy.
                                      Extending the example of above, this works for me:
                                      var pnl = dlg.add('panel', undefined, 'My Panel');
                                      var btn2 = pnl.add('iconbutton', undefined, undefined, {name:'orange', style: 'toolbutton'});
                                      btn2.size = [100,20];
                                      btn2.onDraw = function()
                                      { with( this ) {
                                           try {
                                                var orange = graphics.newBrush( g.BrushType.SOLID_COLOR, [1, 0.7, 0, 1] );
                                                graphics.newPath();
                                                graphics.rectPath(0,0,bounds[2]-bounds[0],bounds[3]-bounds[1]);
                                                graphics.fillPath(orange);
                                           } catch( ex ) {
                                                $.writeln(ex);
                                      }} // onDraw
                                      dlg.show();
                                      Cheers ;-)
                                      Dirk
                                      • 16. Re: [JS CS3/4] ScriptUI How to color a button ?
                                        Dirk Becker  Level 4
                                        Sorry to follow up on my own post, but this one is even shorter.
                                        function fillRect()
                                        { with( this ) {
                                        graphics.rectPath(0,0,size[0],size[1]);
                                        graphics.fillPath(fillBrush);
                                        btn2.fillBrush = btn2.graphics.newBrush( g.BrushType.SOLID_COLOR, [1, 0.7, 0, 1] );
                                        btn2.onDraw = fillRect;
                                        dlg.show();
                                        Dirk
                                        • 17. Re: [JS CS3/4] ScriptUI How to color a button ?
                                          Hi Dirk, really great input.
                                          I will have a closer look on this.
                                          Thank you a lot.
                                          Loic
                                          • 18. Re: [JS CS3/4] ScriptUI How to color a button ?
                                            Steven.. Level 3
                                            { with( this ) {
                                                 try {
                                                      graphics.newPath();
                                                 } catch( ex ) {
                                                      $.writeln(ex);
                                            }} // onDraw
                                            dlg.show();
                                            Cheers ;-)
                                            Dirk
                                            The problem with using onDraw is that it makes it necessary to repaint the entire Button Including the click effect the text and the round edges of the button, since we are overriding the default drawing.
                                            Correct me if I'm mistaken, but thats how it seems on Win xp CS4
                                            Steven
                                            • 19. Re: [JS CS3/4] ScriptUI How to color a button ?
                                              Dirk Becker Level 4
                                              Steve,
                                              you're right if you want to recolor Apple's fancy, rounded, gradiented(?) and eventually pulsating Aqua buttons. For that, take a screen shot, recolor it in PhotoShop and draw an image! ScriptUI is a cross platform compromise anyway, I like the rectangular icon button because I need not go thru the headache to match curves. Furthermore, ScriptUIGraphics is missing a curveto() method.
                                              Next version of the script below - it uses 0.5 alpha to let the original control shine thru.
                                              Besides it fixes a bug where I fell victim to a global variable "g" that stayed around from earlier on - unlike InDesign the ESTK as target does not zap the main session after completion.
                                              function fillRect()
                                              { with( this ) {
                                              graphics.drawOSControl();
                                              btn2.fillBrush = btn2.graphics.newBrush( btn2.graphics.BrushType.SOLID_COLOR, [1, 0.7, 0, 0.5] );
                                              dlg.show();
                                              • 20. Re: [JS CS3/4] ScriptUI How to color a button ?
                                                Harbs. Level 6
                                                Nice work Dirk,
                                                The problem with icon buttons becomes apparent which you want them to
                                                have some text. To get that to work, you need to stack three objects
                                                like I've done here:
                                                function namedButton (container,name,size,color){
                                                     color = color || [0.1, 0.4, 0.9, 0.3];
                                                     size = size || [100,20];
                                                     var grp = container.add('group');
                                                     grp.orientation = 'stack';
                                                     var btn = grp.add('iconbutton', undefined, undefined, {style:'toolbutton'});
                                                     btn.size = size;
                                                     grp.add('statictext',undefined,name);
                                                     btn.fillBrush=btn.graphics.newBrush( btn.graphics.BrushType.SOLID_COLOR, color );
                                                     btn.onDraw = function (){
                                                          this.graphics.drawOSControl();
                                                          this.graphics.rectPath(0,0,this.size[0],this.size[1]);
                                                          this.graphics.fillPath(this.fillBrush);
                                                     var clickButton = grp.add('iconbutton', undefined, undefined, {style:'toolbutton'});
                                                     clickButton.size = size;
                                                     clickButton.fillBrush=clickButton.graphics.newBrush( clickButton.graphics.BrushType.SOLID_COLOR,[0,0,0,0] );
                                                     clickButton.onDraw = function (){
                                                          //this.graphics.drawOSControl();
                                                     return clickButton;
                                                var btn = pnl.add('button', undefined, 'Standard Button', {name:'ok'});
                                                var btn2 = new namedButton(pnl,"Cool Button");
                                                btn2.onClick = function(){
                                                     alert("Yep. This is cool!");
                                                dlg.show();
                                                Harbs
                                                http://www.in-tools.com
                                                Innovations in Automation
                                                • 21. Re: [JS CS3/4] ScriptUI How to color a button ?
                                                  Steven.. Level 3
                                                  Harbs. wrote:
                                                  Nice work Dirk,
                                                  have some text.
                                                  I assume you mean if you want text when custom drawing the color, or on top of the color. Otherwise the Icon Button has no issue showing text to the side of the image using text property. (CS3?)
                                                  Steven
                                                  • 22. Re: [JS CS3/4] ScriptUI How to color a button ?
                                                    Harbs. Level 6
                                                    Yes. I mean using icon buttons instead of the standard ones (which
                                                    have a text property which displays inside the button).
                                                    Icon buttons do not have a text property.
                                                    Harbs
                                                    • 23. Re: [JS CS3/4] ScriptUI How to color a button ?
                                                      Dirk Becker  Level 4
                                                      > To get that to work, you need to stack three objects like I've done here:
                                                      or add three lines, like I've done here ...
                                                      function customDraw()
                                                      { with( this ) {
                                                      if( text ) graphics.drawString(text,textPen,(size[0]-graphics.measureString (text,graphics.font,size[0])[0])/2,3,graphics.font);
                                                      btn2.size = [200,20];
                                                      btn2.text = "Hello, Harbs";
                                                      btn2.textPen = btn2.graphics.newPen (btn2.graphics.PenType.SOLID_COLOR,[0,0.5,0,1], 1);
                                                      btn2.onDraw = customDraw;
                                                      dlg.show();
                                                      • 24. Re: [JS CS3/4] ScriptUI How to color a button ?
                                                        Mucho bravo, congrats,
                                                        I wish I saw your post a week ago. This is exactly the kind of aspect I was looking at.
                                                        Thanks a lot for all of you guys, the infos you dropped here shine like a gold mine !
                                                        Let me say it in french 'MERCI MILLE FOIS !!!'
                                                        Take care,
                                                        Loic
                                                        • 25. Re: [JS CS3/4] ScriptUI How to color a button ?
                                                          Harbs. Level 6
                                                          Hi Dirk,
                                                          Very nice. Much more elegant than mine!
                                                          Harbs
                                                          • 26. Re: [JS CS3/4] ScriptUI How to color a button ?
                                                            Steven.. Level 3
                                                            I'm pretty sure that iconbuttons have text property, at least in CS4.
                                                            Give it a try.
                                                            • 27. Re: [JS CS3/4] ScriptUI How to color a button ?
                                                              Harbs. Level 6
                                                              How 'bout you try it first!
                                                              Harbs
                                                              • 28. Re: [JS CS3/4] ScriptUI How to color a button ?
        Steven.. Level 3
        C'mon Harbs you know I can't type code blind like you. OK here's a sample, only works with CS4
        var rapidDlg = new Window('dialog',"Lets try",undefined);
        buildWindow();
        rapidDlg.show();
        function buildWindow(){
        // Properties for rapidDlg.IconButton1
        rapidDlg.IconButton1 = rapidDlg.add('iconbutton',undefined,undefined);
        rapidDlg.IconButton1.text = 'Works for me';
        rapidDlg.IconButton1.onClick = function(){
        alert('Hurray!');
        rapidDlg.IconButton1.titleLayout = new Object ({alignment:['center','center']});
        GS
        Steven
        • 29. Re: [JS CS3/4] ScriptUI How to color a button ?
        Harbs. Level 6
        Hi Steven,
        Hmm. It looks like you are right that icon buttons have a text
        property. The OMV does not list it.
        I did try using the text property, but it doesn't work when you color
        in the button using Dirks method (i.e. the fill covers over the text).
        When coloring the button, I don't see how the text property would help.
        Harbs
        • 30. Re: [JS CS3/4] ScriptUI How to color a button ?
        Steven.. Level 3
        Using onDraw overrides the default drawing of the button, but using image doesn't override the drawing of the text.
        Here's an example using Bob Stucky's neat image trick. (image created in microsoft Paint to keep it small, since Photoshop inflates image with metadata etc.)
        Place in folder which doesn't need permission to create file and orange.jpg will be created for it
        var rapidDlg = new Window('dialog',"Orange Button",undefined);
        buildWindow();
        rapidDlg.show();
        createImage ();
        rapidDlg.IconButton1 = rapidDlg.add('iconbutton',undefined,getScriptFolder() + "/orange.jpg");
        rapidDlg.IconButton1.text = 'Orange';
        function createImage(){
        var myImageFile = new File(getScriptFolder() + "/orange.jpg");
        if(myImageFile.exists ==false|| myImageFile.constructor != File)
        var binS = new String("\u00FF\u00D8\u00FF\u00E0\x00\x10JFIF\x00\x01\x01\x01\x00`\x00`\x00\x00\u00FF\u00E1\x00\x16Exif\x00\x00II*\x00\b\x00\x00\x00\x00\x00\x00\x00\x00\x00\u00FF\u00DB\x00C\x00\b\x06\x06\x07\x06\x05\b\x07\x07\x07\t\t\b\n\f\x14\r\f\x0B\x0B\f\x19\x12\x13\x0F\x14\x1D\x1A\x1F\x1E\x1D\x1A\x1C\x1C $.' \",#\x1C\x1C(7),01444\x1F'9=82<.342\u00FF\u00DB\x00C\x01\t\t\t\f\x0B\f\x18\r\r\x182!\x1C!22222222222222222222222222222222222222222222222222\u00FF\u00C0\x00\x11\b\x00\x14\x00d\x03\x01\"\x00\x02\x11\x01\x03\x11\x01\u00FF\u00C4\x00\x1F\x00\x00\x01\x05\x01\x01\x01\x01\x01\x01\x00\x00\x00\x00\x00\x00\x00\x00\x01\x02\x03\x04\x05\x06\x07\b\t\n\x0B\u00FF\u00C4\x00\u00B5\x10\x00\x02\x01\x03\x03\x02\x04\x03\x05\x05\x04\x04\x00\x00\x01}\x01\x02\x03\x00\x04\x11\x05\x12!1A\x06\x13Qa\x07\"q\x142\u0081\u0091\u00A1\b#B\u00B1\u00C1\x15R\u00D1\u00F0$3br\u0082\t\n\x16\x17\x18\x19\x1A%&'()*456789:CDEFGHIJSTUVWXYZcdefghijstuvwxyz\u0083\u0084\u0085\u0086\u0087\u0088\u0089\u008A\u0092\u0093\u0094\u0095\u0096\u0097\u0098\u0099\u009A\u00A2\u00A3\u00A4\u00A5\u00A6\u00A7\u00A8\u00A9\u00AA\u00B2\u00B3\u00B4\u00B5\u00B6\u00B7\u00B8\u00B9\u00BA\u00C2\u00C3\u00C4\u00C5\u00C6\u00C7\u00C8\u00C9\u00CA\u00D2\u00D3\u00D4\u00D5\u00D6\u00D7\u00D8\u00D9\u00DA\u00E1\u00E2\u00E3\u00E4\u00E5\u00E6\u00E7\u00E8\u00E9\u00EA\u00F1\u00F2\u00F3\u00F4\u00F5\u00F6\u00F7\u00F8\u00F9\u00FA\u00FF\u00C4\x00\x1F\x01\x00\x03\x01\x01\x01\x01\x01\x01\x01\x01\x01\x00\x00\x00\x00\x00\x00\x01\x02\x03\x04\x05\x06\x07\b\t\n\x0B\u00FF\u00C4\x00\u00B5\x11\x00\x02\x01\x02\x04\x04\x03\x04\x07\x05\x04\x04\x00\x01\x02w\x00\x01\x02\x03\x11\x04\x05!1\x06\x12AQ\x07aq\x13\"2\u0081\b\x14B\u0091\u00A1\u00B1\u00C1\t#3R\u00F0\x15br\u00D1\n\x16$4\u00E1%\u00F1\x17\x18\x19\x1A&'()*56789:CDEFGHIJSTUVWXYZcdefghijstuvwxyz\u0082\u0083\u0084\u0085\u0086\u0087\u0088\u0089\u008A\u0092\u0093\u0094\u0095\u0096\u0097\u0098\u0099\u009A\u00A2\u00A3\u00A4\u00A5\u00A6\u00A7\u00A8\u00A9\u00AA\u00B2\u00B3\u00B4\u00B5\u00B6\u00B7\u00B8\u00B9\u00BA\u00C2\u00C3\u00C4\u00C5\u00C6\u00C7\u00C8\u00C9\u00CA\u00D2\u00D3\u00D4\u00D5\u00D6\u00D7\u00D8\u00D9\u00DA\u00E2\u00E3\u00E4\u00E5\u00E6\u00E7\u00E8\u00E9\u00EA\u00F2\u00F3\u00F4\u00F5\u00F6\u00F7\u00F8\u00F9\u00FA\u00FF\u00DA\x00\f\x03\x01\x00\x02\x11\x03\x11\x00?\x00\u00D7\u00A2\u008A+\u00F33\u00F4 \u00A2\u008A(\x00\u00A2\u008A(\x00\u00A2\u008A(\x00\u00A2\u008A(\x00\u00A2\u008A(\x00\u00A2\u008A(\x00\u00A2\u008A(\x00\u00A2\u008A(\x00\u00A2\u008A(\x00\u00A2\u008A(\x00\u00A2\u008A(\x00\u00A2\u008A(\x00\u00A2\u008A(\x03\u00FF\u00D9");
        myImageFile.open("w");
        myImageFile.encoding = "BINARY";
        myImageFile.write(binS);
        myImageFile.close();
        try {
        } catch(e) {
        One issue is that if default margin is left then there is a little border uncolored, however if margin is set to 0 then we lose the rounded edges unless they are part of the image.
        I attached file of code since copying code from forum created new error in code, so just test with code from text file
        • 31. Re: [JS CS3/4] ScriptUI How to color a button ?
        Hi all,
        I used with enjoyment, bob's script to encapsulate a png into a scriptui UI.
        I wanted to let you know that I was reported an error on Windows7 environment meanwhile on any other systems, it always have perfectly worked.
        Obviously, in this situation, the script didn't create the picture but understanding why is something out of my actual skills.
        I thoght about a specific encoding but ain't have a W7 at hand for test.
        Have any of you encountered such issue ?
        Loic
        • 32. Re: [JS CS3/4] ScriptUI How to color a button ?
        adrian.n
        Hi all,
        maybe I totally missed the point you are discussing here... but why not using the example provided in the scriptUI tutorial by Peter Kahrel?
        Does it do the thing you were looking for?
        var w = new Window ("dialog");
        var s = w.add ("statictext", undefined, "Static");
        var e = w.add ("edittext", undefined, "Edit");
        var b = w.add ("button", undefined, "Button");
        // The window's backround
        w.graphics.backgroundColor = w.graphics.newBrush (w.graphics.BrushType.SOLID_COLOR, [0.5, 0.0, 0.0]);
        // Font and its colour for the first item, statictext
        s.graphics.font = ScriptUI.newFont ("Helvetica", "Bold", 30);
        s.graphics.foregroundColor = s.graphics.newPen (w.graphics.PenType.SOLID_COLOR, [0.7, 0.7, 0.7], 1);
        // Font and colours for the second item, edittext
        e.graphics.font = ScriptUI.newFont ("Letter Gothic Std", "Bold", 30);
        e.graphics.foregroundColor = e.graphics.newPen (e.graphics.PenType.SOLID_COLOR, [1, 0, 0], 1);
        e.graphics.backgroundColor = e.graphics.newBrush (e.graphics.BrushType.SOLID_COLOR, [0.5, 0.5, 0.5]);
        // Font for the tird control, a button. Can't set colours in buttons
        b.graphics.font = ScriptUI.newFont ("Minion Pro", "Italic", 30);
        w.show ();
        • 33. Re: [JS CS3/4] ScriptUI How to color a button ?
        unless I am wrong, this amazing resource didn't exist at the time I asked this
        • 34. Re: [JS CS3/4] ScriptUI How to color a button ?
        adrian.n Level 1
        Oh... sorry, I did not recognize the date of the post
        • 35. Re: [JS CS3/4] ScriptUI How to color a button ?
        Alan_AEDScripts Level 2
        I have another way to tackle this-
        1.Use edittext control instead.
        2.Easy to set fg and bg.
        3.Instead of onClick, use onActivate as a callback to make it act like a button.
        4.Also use readonly creation paramater as it helps make it look like a button.
        Working for me...
        • 36. Re: [JS CS3/4] ScriptUI How to color a button ?
        Interesting idea. But onActivate is not compatible with readonly, though that needn't be too much of a problem. On the plus side, using your method you can do multi-line buttons on Windows, which you can't with standard buttons (on a mac that works fine).
        • 37. Re: [JS CS3/4] ScriptUI How to color a button ?
        Hi guys,
        As far as I am concerned, this problematic even has decided me to turn from scriptUI to ( what was then PatchPanel ) extensions. I still do ScriptUI once in a while but and it's really my humble opinion, I always found cumbersome to have so many lines of code for the simpliest UI behaviour. However I deeply admire how far Peter and Marc ( and a few others guy btw ) have pushed ScriptUI to the limits.
        But I realise how troll-ish this post could be and I apologize for that. I just wanted to share my experience and how this colored button consideration affected my poit of view
        Best to all,
        Loic
        • 38. Re: [JS CS3/4] ScriptUI How to color a button ?
        Loic,
        Could you give us an outline of what you can do in Extensions that you cannot do in ScriptUI?
        Peter
        • 39. Re: [JS CS3/4] ScriptUI How to color a button ?
        Marc Autret Level 4
        Hi Peter,
        As far as I am concerned too, Loïc is right in that Flex provides a huge collection of native and pre-built widgets and controls that would need a lot of code to be mimicked in ScriptUI: many kinds of buttons and containers, date controls, menus, repeaters, validators, formatters, effects, not to mention chart controls, advanced datagrids, media loaders and web-friendly components. There is no doubt that Flex-based UI is much easier to design. Cf. http://examples.adobe.com/flex3/componentexplorer/explorer.html
        However—as you know—I'm still a big supporter of ScriptUI despite its Spartan side. Its main advantage is to be instantly available to ExtendScript programmers, it does not require JS-AS bridge(s), does not relies on a Flash player, and does not involve complicated bricks and libraries when you need to interact with the DOM from your UI, which after all is our main purpose. Last point: ScriptUI is part of the basic Creative Suite, while FlashBuilder + CS ExtensionBuilder are additional products.
        My personal feeling is that Flash/Flex/ActionScript technologies in Adobe apps involve a high density of dependencies. As soon as we try to develop some advanced functionality, there are too many bricks to handle and connect, and too many constraints to be aware of. Dealing with both ActionScript, MXML, Flex compilation issues, CS ActionScript Wrapper Library (CSAWLib and/or csaw_indesign.swc), CS eXtensible Services (CSXSLibrary), and/or HostObject, and/or id_host_adapter, and/or ExternalInterface, and/or SWFLoader, etc., is simply too much for me, while my goal is just to make some “scripted plug-in” available to ID CS4/CS5/CS6 users. As I have a very limited memory, I just want to focus on the core of my project—which is basically to turn the InDesign DOM into a cultivated variety! ExtendScript-JS is an integrated module that offers all what I need and only what I need, including ScriptUI.
        Marc
        1 2 Previous Next
