1 Reply Latest reply on Oct 20, 2009 10:35 AM by Flex harUI
    How to make sure override public function set data(item:Object) is called on vertical scroll
    mfsiddiq Level 1
      Hi
      I am facing an issue with my datagrid with renderers on all its columns.I need to enable or disable the render components based on values in different columns in the row.Its works fine in most of the places .But in some places which is not visible without the scroll,it seems the set data function is not called,because of which the component will be enabled when it has to be disabled.How do i ensure it works fine all the time.
      Regards
      Sidd
