8 Replies Latest reply on Oct 20, 2009 6:42 AM by vertmonkee
    Stopping animation in a popup when it closes
    vertmonkee Level 1
      I have created a component which is added as a pop up to create a modal window when the user is waiting for data from the server. This is all working fine, the problem I am having is when the pop up is removed.
      To rotate the loading image I increment an int by 5 then rotate the image and then call the function again so it continually spins.
      Using a trace statement I have seen that the animation continues to get called even when the pop up has been removed.
      How do I stop this happening when the pop up is removed?
      This is my code from the pop up window component.
      <!--Used to display a modal window with a loading image-->
      <mx:VBox xmlns:mx="http://www.adobe.com/2006/mxml" width="166" height="200" creationComplete="rotateLoadingImage()">
          <mx:Script>
              <![CDATA[
                  import mx.controls.Alert;
                  [Bindable]
                  public var angle:int = 0;
                  private function rotateLoadingImage():void {
                      rotate.end();
                      angle += 5;
                      rotate.play();
                      trace("Rotate image function");
          </mx:Script>
          <mx:Rotate id="rotate" angleFrom="{angle - 5}" angleTo="{angle}" duration="20" effectEnd="rotateLoadingImage();" easingFunction="null" target="{loadingImage}"/>
          <mx:Image source="@Embed('loading.png')" width="166" height="166" id="loadingImage"/>
          <mx:Label text="LOADING..." width="166" height="25" textAlign="center" fontSize="20"/>
      </mx:VBox>
      This is the code in my Main file
      <mx:WindowedApplication xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" xmlns:ns1="components.*">
          <!-- main.mxml -->
          <mx:Script>
              <![CDATA[
                  import components.ProgressWin;
                  import mx.rpc.events.ResultEvent;
                  import mx.managers.PopUpManager;
                  //private var waitWin:ProgressWin;
                  private function init():void {
                      srv.send()
                      waitWin = new ProgressWin();
                      PopUpManager.addPopUp(waitWin, this, true);
                      PopUpManager.centerPopUp(waitWin)
                  private function onResult(event:ResultEvent):void {
                      PopUpManager.removePopUp(waitWin);
                      out.text = "event.result = " + event.result;
                  private function testAlert():void {
                      Alert.show("This is the test alert function");
          </mx:Script>
          <mx:HTTPService id="srv" url="http://www.myserver.com/test.php" result="onResult(event)" />
          <mx:TextArea id="out" width="400" height="300"/>
          <mx:Button id="myButton" click="testAlert()" label="Test alert"/>
          <mx:Button id="openWindow" click="init()" label="Open window" x="88" y="-1"/>
      </mx:WindowedApplication>
        • 1. Re: Stopping animation in a popup when it closes
          Subeesh Arakkan Level 4
          In the result handler, stop the effect before closing the popup
                        waitWin.rotate.stop();
          • 2. Re: Stopping animation in a popup when it closes
            vertmonkee Level 1
            Thanks for the idea but adding that does not stop it.
            Any other ideas are gratefully recieved.
            Thank you.
            • 3. Re: Stopping animation in a popup when it closes
              I think event listener is not removed after stopping the effect. Remove the event listener before stopping the effect.
              public function stopEffect():void
                               rotate.removeEventListener(EffectEvent.EFFECT_END,rotateLoadingImage);
                               rotate.stop();
                           private function rotateLoadingImage(event:EffectEvent):void
                               rotate.end();
                               angle += 5;
                               rotate.play();
                  </mx:Script>
                  <mx:Rotate id="rotate" angleFrom="{angle - 5}" angleTo="{angle}" duration="20" effectEnd="rotateLoadingImage(event);" easingFunction="null" target="{loadingImage}"/>
              Modify the rotateLoadingImage to accept effect event as argument.
              In the result handler modify the code like this
                             waitWin.stopEffect();
              • 4. Re: Stopping animation in a popup when it closes
                vertmonkee Level 1
                Thanks for taking the time to help out but I'm still getting the same result
                • 5. Re: Stopping animation in a popup when it closes
                  this worked for me
                  popup code
                      creationComplete="onCreationComplete()">
                      <mx:Script>
                          <![CDATA[
                              import mx.events.EffectEvent;
                              [Bindable]
                              private function onCreationComplete():void
                                  rotate.addEventListener(EffectEvent.EFFECT_END,rotateLoadingImage);
                                  rotateLoadingImage(null);
                              private function rotateLoadingImage(event:EffectEvent):void {
                                  rotate.end();
                                  angle += 5;
                                  rotate.play();
                                  rotate.stop();
                      </mx:Script>
                      <mx:Rotate id="rotate" angleFrom="{angle - 5}" angleTo="{angle}" duration="20" easingFunction="null" target="{loadingImage}"/>
                  </mx:VBox>
                  in the result handler stop the effect before removing the popup
                  • 6. Re: Stopping animation in a popup when it closes
                    vertmonkee Level 1
                    If I put a trace statment in the onResult function below like below
                                    trace("Image has stopped rotating");
                    I get the following output
                    Rotate image function keeps printing out until I close the whole application.
                    Does this not happen for you?
                    • 7. Re: Stopping animation in a popup when it closes
                      No, I am attaching my test application
                      • 8. Re: Stopping animation in a popup when it closes
                        vertmonkee Level 1
                        Excellent that is working for me.
                        I'll see if I can adapt this code into what I have.
                        Thanks for your help I really appreciate it.
