0 Replies Latest reply on Oct 20, 2009 8:50 AM by Darrell Loverin
    [svn:fx-trunk] 11027: Changes to enable using multiple style managers.
    Darrell Loverin Level 4
      Revision: 11027
      Author:   dloverin@adobe.com
      Date:     2009-10-20 08:50:09 -0700 (Tue, 20 Oct 2009)
      Log Message:
      Multiple style managers are not the default yet. Can be enabled by compiling with -create-style-manager.
      QE notes: None.
      Doc notes: None.
      Bugs:
      Reviewer: Alex, Paul
      Tests run: checkintests, all mustella
      Is noteworthy for integration: Yes.
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/FormItem.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/DateField.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/dataGridClasses/DataGridColu mn.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/dataGridClasses/DataGridItem Renderer.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/Application.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/events/FlexChangeEvent.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/CursorManagerImpl.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/DragManagerImpl.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/dragClasses/DragProxy.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/BusyCursor.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/CSSStyleDeclaration.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/StyleManager.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/StyleManagerImpl.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/StyleProtoChain.as
          flex/sdk/trunk/frameworks/projects/halo/src/mx/skins/halo/BusyCursor.as
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/AbstractSyntaxTreeUtil.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/DataBindingExtension. java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/CompilerConfiguration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StyleDef.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StyleDef.vm
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StyleModule.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StylesContainer.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/InterfaceGenerator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/MxmlConfiguration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/gen/ClassDefLib.vm
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/StandardDefs.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/MxmlDocument.java
          flex/sdk/trunk/tools/dependencychecker/flex/tools/dependencychecker/FrameworkSwcDependenc yRules.java
      Added Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/CSSMergedStyleDeclaration.as
