3 Replies Latest reply on Aug 11, 2006 8:14 AM by whyitsme
    on (release) help
      I am real new to Flash. I have been working on a site http://d9wc.com on of many problems I am currently having difficulty in figuring out is - when you click on a button you can send it to a particular frame number (for this instance frame 99. I want it to play 99 through159. I then want it to play frame 160. The problem is that I have 4 additional buttons I also want to play those same frames 99 through 159, but then jump to 161, 162, 163 or 164. There is probably and easy way to do this but I am stuck. to see what I am tring to do got to http://d9wc.com/servicetest.html then click on special wallcoverings you will see the menu move over to the left and then expand out sub menu Items. What I want is when they click on another item not in the sub menu for everything to repack and go back to original place then the info appear below. I am sure that my file organization method is all messed up, but it is working so far. And Like I said I am new to flash (This is my first project) so any help would be great.
      the fla file is located at http://d9wc.com/service menu.fla 2,448 kb
      the swf file is located at http://www.d9wc.com/images/buttons/services menu.swf 92 kb
        • 1. Re: on (release) help
          Level 7
          For something like this, I would use a variable in the main timeline.
          Use the var statement to declare a variable, then set the value of that
          variable with your buttons. Later on, you can check the variable's value
          and use an if() statement to decide which frame to send the playhead to.
          // In frame 1 of the main timeline
          var guidePost:String = "";
          Here, we have an arbitrarily named variable, guidePost, that will ...
          well, that will lead the way, like a guide post. ;) If you're publishing
          to ActionScript 2.0, the next part -- :String -- means that this variable is
          a string (as opposed to a number, for example). If you're publishing to
          ActionScript 1.0, leave that part off. Then there's an assignment operator
          (the equals sign), and finally an empty string, "". Because this is
          declared in frame 1, the variable now exists for all other frames after it;
          in other words, for the whole timeline.
          // On each of your buttons
          // Button A
          on (release) {
          guidePost = "a";
          // Button B
          on (release) {
          guidePost = "b";
          // etc.
          You with me? Each button sends the playhead to frame 99, and yet each
          button sets that variable to something different.
          Now, on frame 159, you'll put another frame script:
          // In frame 159 of the main timeline
          if (guidePost == "a") {
          if (guidePost == "b") {
          // etc.
          Not too hard, right? Notice that the operator has changed. This time,
          it's the equality operator (two equals signs), rather than the assignment
          operator. Don't confuse those.
          That's the most basic approach I can think of. If you want to get
          fancy, you can use a switch() statement instead. Just for grins ... erase
          the series of if() statements and use this intead:
          switch(guidePost) {
          case "a":
          case "b":
          // etc.
          Similar approach. Maybe that one makes more sense to you.
          It's always bewildering at first, but if you get yourself grounded, and
          if you get comfortable reading the built-in documentation, you'll find that
          things begin to fall into place.
          David Stiller
          Adobe Community Expert
          Dev blog, http://www.quip.net/blog/
          "Luck is the residue of good design."
          • 2. Re: on (release) help
            each button can set a variable (say yourVar =161 for your first button) that indicates the frame to goto after 159. attached to frame 159 you can use a _root.gotoAndPlay(yourVar) statement.
            • 3. Re: on (release) help
              whyitsme Level 1
              Thank you very very much, your assistance helped alot. Once I figured out what you were saying was able to imput the strings you mentioned and it worked. I did not do it in the first frame as suggested as those particular buttons when clicked on in the first part of movie they behave differently (no need to play the frames 99 through 159, but jump directly to the later frame.
              So thanks again for your assistance
              Keith Drevecky
