5 Replies Latest reply on Oct 20, 2009 10:35 AM by David_F57
    Map MySQL to ArrayCollection in PHP
    Powder77 Level 1
      Hi Guys
      I have had great success in passing data to flex using Zend AMF as an array of objects and using the result to populate Flex Charts.
      The problem is I want to use FusionCharts for Flex, this require me to pass an ArrayCollection to the FusionChart. The problem I am have having is building the the ArrayCollection in PHP.
      Eg
      $sql ="select label,value from table";
      $result = mysq_query($sql);
      while($row=mysql_fetch_object($result)
      What code do I put here to build the arraycollection to pass back to flex
      Here is what I am trying to mirror in flex
      private var chartData:ArrayCollection=new ArrayCollection([
                       { label:'Jan', value:'17400' },
                       { label:'Feb', value:'19800' },
                       { label:'Mar', value:'21800' },
                       { label:'Apr', value:'23000' },
                       { label:'May', value:'29000' },
                       { label:'Jun', value:'27600' }
      Thanks in advance
      Chris
