4 Replies Latest reply on Oct 20, 2009 11:00 AM by yevri
    Dynamic URL with JavaScript
    yevri Level 1
      I use this script to launch a url in a pop-up window:
      getURL("javascript:openNewWindow('contact.html','thewin','width=700,height=400,toolbar=yes ,scrollbars=yes') ");
      I want to be able to make the URL dynamic, but when I try it with the JavaScript sizing the window, I can't get it to work. What should I be doing?
      This one works, but not sizing the window:
      getURL("contact/" +_root.agent+ ".html","_blank");
      Brian
        • 1. Re: Dynamic URL with JavaScript
          Adamcbrz
          You need to look at flash's ExternalInterface Documentation (http://help.adobe.com/en_US/AS2LCR/Flash_10.0/help.html?content=00001036.html)
          With ExternalInterface you could do something like:
          import flash.external.*;
          var url = "contact/" +_root.agent+ ".html";
          ExternalInterface.call("openNewWindow", url);
          This will call your javascript function and you can do the rest in javascript.
          An alternate solution is to continue to use the getURL function:
          getURL("javascript:openNewWindow('contact/" +_root.agent+ ".html"','thewin','width=700,height=400,t oolbar=yes,scrollbars=yes') ");
          That would accomplish the same thing.
          If that is not what you are trying to accomplish let me know and I we can try to figure the miscommunication.
          Adam
          • 2. Re: Dynamic URL with JavaScript
            yevri Level 1
            Thanks for the help. Makes sense. Trying to continue to use the getURL function using:
            on (release) {
            getURL("javascript:openNewWindow('contact/" +_root.agent+ ".html"','thewin','width=700,height=400,toolbar=yes,scrollbars=yes') ");
            I get an error saying unexpected ")" and it says syntax error.
            the ); and } at the end are green, which tells me something is wrong - as if the quotes are set up wrong because of single quotes, etc.
            That's what was happening to me from the start. What in that line of code is wrong?
            • 3. Re: Dynamic URL with JavaScript
              Adamcbrz Level 2
              You have an extra " after .html
              You can see where the quote in red below:
              getURL("javascript:openNewWindow('contact/" +_root.agent+ ".html"','thewin','width=700,height=400,toolbar=yes,scrollbars=yes')");
              • 4. Re: Dynamic URL with JavaScript
                yevri Level 1
                Thanks. That did it. I appreciate the help.
