3 Replies Latest reply on Feb 11, 2017 7:49 PM by lf.corullon
    Sort by Name via script
    edsonfurman
      Hi everybody,
      I would appreciate if someone could give some clue to sort by name the
      Paragraph Styles, Character Styles, Object Styles and Swatches panels
      via script.
      Thank you all in advance.
      Edson Furman
      edsonfurman@terra.com.br
        • 1. Re: Sort by Name via script
          Peter Kahrel Adobe Community Professional & MVP
          For sorting styles I have used the script listed below -- works in CS3 and CS4 though it's been a while since I last tried. It could be coded more elegantly but it always worked fine as it is. It doesn't take into account any style groups -- I don't know what happens if your documents contain any so you'd better not try.
          As to swatches, these are not so easy to sort. There was some discussion about this at either of these sites:
          http://www.hilfdirselbst.ch/gforum/gforum.cgi?jump=forum%3D4
          http://indesign-faq.de/
          Peter
          #target indesign
          sort_par_styles (app.documents[0]);
          sort_char_styles (app.documents[0]);
          sort_obj_styles (app.documents[0]);
          function sort_par_styles (doc)
              var string_array = sort_par_names (doc);
              for (var i = 0; i < string_array.length; i++)
                  doc.paragraphStyles.item (string_array[i]).move (
                      LocationOptions.after, doc.paragraphStyles[i+2])
          function sort_par_names (doc)
            var array = doc.paragraphStyles.everyItem().name;
            array.shift (); array.shift ();  // exclude [No p.] and [Basic p/]
            return array.sort (case_insensitive);
          function sort_char_styles (doc)
              var string_array = sort_char_names (doc);
                  doc.characterStyles.item (string_array[i]).move (
                      LocationOptions.after, doc.characterStyles[i+1])
          function sort_char_names (doc)
            var array = doc.characterStyles.everyItem().name;
            array.shift ();  // exclude [None]
          function sort_obj_styles (doc)
              var string_array = sort_obj_names (doc);
                  doc.objectStyles.item (string_array[i]).move (
                      LocationOptions.after, doc.objectStyles[i+4])
          function sort_obj_names (doc)
            var array = doc.objectStyles.everyItem().name;
            array.shift (); array.shift (); array.shift ();  array.shift (); // exclude  [None], [Basic Graphics Frame], [Basic Text Frame], [Basic Grid]
          function case_insensitive (a, b)
            return a.toLowerCase() > b.toLowerCase()
          • 2. Re: Sort by Name via script
            edsonfurman Level 1
            Great, Peter! Very thank you!
            Edson
            • 3. Re: Sort by Name via script
              lf.corullon Level 3
              An easiest way to do that...
              app.menuActions.itemByID(8505).invoke();
              app.menuActions.itemByID(8511).invoke();
              app.menuActions.itemByID(113168).invoke();
              app.menuActions.itemByID(132113).invoke();
              app.menuActions.itemByID(132133).invoke();
              It will sort styles (character, paragraph, object, cell and table) by name.
