0 Replies Latest reply on Oct 20, 2009 11:55 AM by Paul Reilly
    [svn:fx-trunk] 11031: * A batch of compiler bug fixes.
    Paul Reilly Level 1
      Revision: 11031
      Author:   preilly@adobe.com
      Date:     2009-10-20 11:55:17 -0700 (Tue, 20 Oct 2009)
      Log Message:
      • A batch of compiler bug fixes.  The fix for SDK-18954 adds Embed
        support for smoothing, compression and quality.  For example:
          [Embed(source='foo.png',smoothing="false",compression="true",quality="80")]
          private var bar:Class;
        smoothing and compression are booleans and quality is a percentage
        between 0 and 100.  quality requires that compression be true.  The
        actual smoothing is implemented by the player at runtime.
      QE notes: We need some new mxunit and mxmlcunit tests for the new
                Embed attributes.
      Doc notes: See notes above
      Bugs: SDK-18954, SDK-23607, SDK-23513, SDK-22471, SDK-21116
      Reviewer: pfarland
      Cycloner: me, Gaurav
      Tests run: full cyclone
      Is noteworthy for integration: yes
      Code-level description of changes:
        frameworks/flex-config.xml
          Added default theme to match what is now in DefaultsConfigurator.
        modules/swfutils/src/java/flash/swf/tools/SwfxPrinter.java
          Flushed out defineBitsJPEG3().
        modules/compiler/src/java/flex2/compiler_en.properties
          Modified css.StylesContainer.InvalidStyleProperty by removing the
          themes.
          Modified css.StylesContainer.InvalidStyleTheme by adding the type.
          Added media.LosslessImageTranscoder.InvalidQuality and
          media.LosslessImageTranscoder.QualityRequiresCompression.
          Modified mxml.builder.ComponentBuilder.InvalidStyleThemeError and
          mxml.builder.ComponentBuilder.InvalidStyleThemeWarning by added the
          type.  This fixes SDK-23607.
        modules/compiler/src/java/flex2/compiler/media/LosslessImageTranscoder.java
          Applied Joa's patch, then reformatted, renamed some variables and
          methods, added some comments, added some error checking, and fixed
          bufferedImageToJPEG() by setting the destination type and bands.
          This fixes SDK-18954.
        modules/compiler/src/java/flex2/compiler/media/ImageTranscoder.java
          Added support for smoothing by adding buildSmoothingSprite() and
          generateSmoothingShape() and modifying doTranscode() to call them,
          when smoothing="true".
          Added some comments.
        modules/compiler/src/java/flex2/compiler/as3/reflect/NodeMagic.java
          Modified checkForIdentifier() to no longer filter out the empty
          string attribute, because this means "public".
        modules/compiler/src/java/flex2/compiler/as3/As3Compiler.java
          Some code clean up.
        modules/compiler/src/java/flex2/compiler/css/StyleModule.java
          Updated addFontFaceRule() to use new AtEmbed.create() signature.
        modules/compiler/src/java/flex2/compiler/css/StyleDef.java
          Updated StyleProperty constructor calls to pass in the path.
        modules/compiler/src/java/flex2/compiler/css/StylesContainer.java
          Updated warning reporting to use styleProperty.getPath() instead of
          getPathForReporting(styleDef).  This fixes SDK-23513.
          Added themeNames to InvalidStyleProperty class and constructor.
        modules/compiler/src/java/flex2/compiler/mxml/rep/AtEmbed.java
          Modified create() to include a Source arg and to call
          tokenizeAndResolveSource().  This ensures that Transcoder.SOURCE is
          defined in the args.  Transcoder.SOURCE is required when exporting a
          SWC.  This fixes SDK-22471.
        modules/compiler/src/java/flash/css/StyleProperty.java
          Added path variable, constructor arg and getter.
        modules/compiler/src/java/flash/css/Descriptor.java
          Added an assert for a null path to the constructor.
        modules/thirdparty/batik/sources/org/apache/batik/css/parser/Parser.java
          Modified parseSimpleSelector() to report an error for an unresolved
          namespace.  This fixes SDK-21116.
        modules/thirdparty/batik/resources/org/apache/batik/css/parser/resources/Messages.propert ies
          Added message for unresolved.namespace.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-18954
          http://bugs.adobe.com/jira/browse/SDK-23607
          http://bugs.adobe.com/jira/browse/SDK-23513
          http://bugs.adobe.com/jira/browse/SDK-22471
          http://bugs.adobe.com/jira/browse/SDK-21116
      Modified Paths:
          flex/sdk/trunk/frameworks/flex-config.xml
          flex/sdk/trunk/lib/batik-all-flex.jar
          flex/sdk/trunk/modules/compiler/src/java/flash/css/Descriptor.java
          flex/sdk/trunk/modules/compiler/src/java/flash/css/StyleProperty.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/TranscoderException.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/As3Compiler.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/reflect/NodeMagic.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/MxmlConfiguration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StyleDef.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StyleModule.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StylesContainer.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/media/ImageTranscoder.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/media/LosslessImageTranscoder.jav a
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/AtEmbed.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_en.properties
          flex/sdk/trunk/modules/swfutils/src/java/flash/swf/tools/SwfxPrinter.java
          flex/sdk/trunk/modules/thirdparty/batik/resources/org/apache/batik/css/parser/resources/M essages.properties
          flex/sdk/trunk/modules/thirdparty/batik/sources/org/apache/batik/css/parser/Parser.java
