7 Replies Latest reply on Oct 21, 2009 11:23 PM by www.cpguru.com
    Captivate 3 vs. 4
    JennyVM Level 1
      My health care organization currently uses version 3, and we are considering upgrading to 4.
      Can anyone offer pros/cons for 4?  Is the right-click functionality bug-free?  That is really important to us.  We currently have custom publishing code and a right-click animation that work beautifully.
      Any info greatly appreciated.
      Jenny
        • 1. Re: Captivate 3 vs. 4
          Hi Jenny
          Let's see. If all you wanted was Right-Click, you might be well advised to hold back on the upgrade. You have other things to consider.
          For example, in C3 some folks rely on the situation whereby you coax the playback controls up onto the main part of the movie by clearing the Borders check box. If you are doing that, it changes for the worse in C4 and it's no longer possible.
          The TOC behavior changes in C4. If you used the Menu/TOC in C3 you could link to resources outside the project. (Word, PDF, etc.) Now you cannot. On the flip side, the TOC is much easier to maintain.
          If you have C3 you have MenuBuilder available. C4 replaces that with the Aggregator. MB comes in handy for other things. Aggregator isn't as customizable as some would like it to be.
          C4 has more output options. There is the Reviewer functionality where it outputs as AIR. And there is an ability to publish as AVI for YouTube.
          C4 has drawing objects (Arrows, Circles, Rectangles & Polygons). C3 doesn't have that.
          C4 offers widgets. C3 doesn't have widgets.
          C4 offers more control over how the movie elements are published. Whether things are separate SWFs or are combined.
          That's probably enough for now. In order to be fully informed, you should download the trial for C4 and kick the tires to see for yourself.
          Cheers... Rick
          Helpful and Handy Links
          Captivate Wish Form/Bug Reporting Form
          Adobe Certified Captivate Training
          SorcerStone Blog
          Captivate eBooks
          • 2. Re: Captivate 3 vs. 4
            JennyVM Level 1
            Thanks for the info.  Just to confirm, does right-click function bug-free in 4?
            • 3. Re: Captivate 3 vs. 4
              Lilybiri MVP & Adobe Community Professional
              Right-click works all right, but you cannot have accessibility options combined with it. When published to a LMS, and working with FP9 or above, normally there are no problems. BTW: you also have double-click as an option besides left and right click.
              Another feature of CP4 I like personally very much is that you can edit captions in place. And last (but not least) the ability to use system variables and create user variables. You can p.e. use this in a very simple way to ask the name of the user and use this name in captions to address the user.
              Lilybiri
              • 4. Re: Captivate 3 vs. 4
                Hi there
                Sorry, but I have to answer that with a question. How long is a piece of string?
                Nothing in this world is totally bug free. While I'm not sure it's a "bug", right-click will not function if you have Section 508 options enabled.
                Cheers... Rick
                SorcerStone Blog
                Captivate eBooks
                • 5. Re: Captivate 3 vs. 4
                  Thanks for the additional info Lilybiri!
                  However, what one finds attractive others find distasteful. Personally, I *HATE* the in-place editing. Dangit, when I double-click a caption I want to see the dialog!
                  The workaround is to double-click on a sizing handle. But I still wish it were an option we could choose. How the double-clicking behaves.
                  Since I forgot to mention the variables (and scripting) capabilities (which are quite nice) I'll also have to share the good and bad points of each.
                  If you use variables in your Captions, you may notice that the actual variable appears briefly before updating with the actual content. This can become a bit unsettling and distracting. And with the scripting, it's cool that you can create advanced actions. Not so cool the way you have to do it. The editor leaves a lot to be desired. And there is no copy/paste to transfer really cool scripts to other users.
                  Cheers... Rick
                  SorcerStone Blog
                  Captivate eBooks
                  • 6. Re: Captivate 3 vs. 4
                    Hello Rick,
                    Fine that different features get different reactions, this makes it all more interesting, not too annoying. For me in place editing has been a great timesaver, perhaps because I'm editing quite a lot. If I want the dialog box, I got used to choose Properties in the Quick menu.
                    Totally agree that the editor for Advanced Actions is somehow clumsy, but .. at least we have the abililty to control some variables without having to be script-savvy. And since there is this little baby (advanced actions) it only can get better (grow up) in the future.
                    Have a fine day (here it is almost sleeping time),
                    Lilybiri
                    • 7. Re: Captivate 3 vs. 4
                      www.cpguru.com Level 4
                      The number 1 reason to upgrade to Captivate 4 for me is the speed. Things are just happening alot quicker than with CP3. In CP3 you had alot of waiting time when working with big projects because when you clicked a slide or an object it always took a little while before it opened. In CP4 this is alot better so you will save quite a bit of time creating your projects in CP4 instead.
                      Also the variables and advanced actions are worth upgrading for in my opinion.
                      /Michael
                      Visit my Captivate blog with tips & tricks, tutorials and Widgets.
