4 Replies Latest reply on Oct 21, 2009 6:50 AM by the_wine_snob
    AVI File
    rtprtp Level 1
      Hi Folks,
      A client is goint to give me an AVI file of some footage to edit. Do I need to convert it to anything before editing it into the other HDV footage in PE7, or can I just bring it in?
      Thanks, Stan
        • 1. Re: AVI File
          It depends on what codec that AVI uses. You can find that out by opening the file in Windows MovieMaker and then going to File/Properties.
          If you're lucky, it will use the DV codec.
          In that case your only issue will be that it will be a standard definition video -- and you'll be putting it into an HDV project.
          Remember, standard DV has less than a fourth of the resolution of hi-def. You can blow it up to fit the video frame, but it's likely to look over-rezzed and fuzzy.
          • 2. Re: AVI File
            the_wine_snob Level 9
            Stan,
            This ARTICLE will give you some background on AVI files (and also many other "wrappers").
            • 3. Re: AVI File
              rtprtp Level 1
              Thanks fellas. Much appreciated, as always!!
              Stan
              • 4. Re: AVI File
                Stan,
                Good luck, and hope that you've gotten some help. When you get the .AVI, the first thing that I would do would be to run it through G-Spot, to check out its specs. completely. If you have any questions, specific to that file, a screen-cap of the G-Spot GUI with the file loaded, would go a very long way to help others help you with that file. Hint: use the little "camera" icon in the lower-middle of the editing screen's Toolbar to attach that screen-cap. Doing a screen-cap will also save you a bunch of typing - the adage that "a picture is worth a thousand words," is really ture in this case.
