0 Replies Latest reply on Oct 20, 2009 4:49 PM by GordonSmith
    [svn:fx-trunk] 11040: Integrated today's TLF Build 531.
    GordonSmith Level 4
      Revision: 11040
      Author:   gosmith@adobe.com
      Date:     2009-10-20 16:49:22 -0700 (Tue, 20 Oct 2009)
      Log Message:
      Integrated today's TLF Build 531. This integration required no modifications to the Flex framework.
      Changes since the last integration:
      Build 531
      • Fix for 2458403 - TLF default TextLayoutFormat fontFamily is now Arial rather than Times New Roman.
      Build 530
      • Fixing bug in how link formats are exported, so colors will be exported in "#" format.
      Build 527
      • Additional fix for 2447819 - ComposeState was also holding onto references - now fixed
      • Performance improvement for flows with multiple containers.  StandardFlowComposer now quickly skips to the first damaged container during compose.
      Build 525
      • Redefined IMEStatus constants from simple, raw, converted, etc, to compounds such as SELECTED_RAW, NOT_SELECTED_RAW, SELECTED_CONVERTED and NOT_SELECTED_CONVERTED.
      QE notes: None
      Doc notes: None
      Bugs: None
      Reviewer: None
      Tests run: ant checkintests
      Is noteworthy for integration: No
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/textLayout/ReleaseNotes.txt
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_conversion/src/flashx/textLayout /conversion/BaseTextLayoutExporter.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_conversion/src/flashx/textLayout /conversion/TextLayoutExporter.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/Build Info.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/compo se/BaseCompose.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/compo se/ComposeState.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/compo se/SimpleCompose.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/compo se/StandardFlowComposer.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/conta iner/ColumnState.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/conta iner/ContainerController.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/FlowLeafElement.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/facto ry/TextLineFactoryBase.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/IMEStatus.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/ITextLayoutFormat.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/TextLayoutFormat.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/TextLayoutFormatInc.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/TextLayoutFormatValueHolder.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flash/text/ime/Composit ionAttributeRange.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flash/text/ime/IIMEClie nt.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/edit/ EditManager.as
          flex/sdk/trunk/frameworks/projects/textLayout/tlf.properties
