5 Replies Latest reply on Oct 22, 2009 8:47 PM by xavierpayne
    Camera shake works in preview but not in final render.
    xavierpayne
      Hi there. I've tried googling and searching the forums and come up empty handed so here goes.
      I am using After Effects from CS4 with the latest updates.
      I have a project with a single comp which contains one AVCHD clip parented to an adjustment layer.
      I have used the wiggler to keyframe some faux camera shake by manipulating the "Transform->Position" field of the adjustment layer at key moments in the footage. If I scrub through or do a preview (hit the 0 key and let it pre render) it looks fantastic with the clip shaking exactly how I like.
      But when I save the project and add it to my render queue the final output has *none* of the camera shake!!!
      I am completely baffled as to why this might be. That said I've only been using AE for about a month so it's possible I am making a simple noob mistake.
      The adjustment layer and footage are both set to visible. I can clearly see the keyframes in the timeline and like I said previewing and scrubbing shows the effect in action... But the final renders (no matter what the format or resolution) have no shake in them whatsoever.
      Help!?
        • 1. Re: Camera shake works in preview but not in final render.
          Adolfo Rozenfeld Adobe Employee
          I just tried doing exactly the same thing and it works fine here.
          If you want, e-mail me your project file (minus source video file) and I'll take a look: arozenfe(©)adobe.com
          • 2. Re: Camera shake works in preview but not in final render.
            xavierpayne Level 1
            While Cleaning up my project to send to you without the video I noticed an additional effect I was applying to the avchd video layer itself (not the adjustment layer).
            Motion Tile.
            I was using it in mirror mode to fill the 25-100 pixels worth of black edges from where my video goes out of frame at the edges when it shakes.
            With Motion Tile disabled (I check off the "FX" box in the timeline.) It seems to render the shakes in both the preview and final render but I get black borders (as expected).
            With Motion Tile Enabled the shake renders in the preview without borders but seems to be lost completely in the final output render.
            Motion Tile seems to be the culprit. Perhaps it does not do what I think it does?
            Still want me to send you my project?
            • 3. Re: Camera shake works in preview but not in final render.
              Motion Tile is about replicating a source image multiple times.
              If the wiggler's magnitude is not too wide, you could just apply it directly to the video layer's position, and just increase Scale to 103-105 per cent. It shouldn't degrade quality too drastically at those values, right?
              • 4. Re: Camera shake works in preview but not in final render.
                xavierpayne Level 1
                That's what I thought motion tile did. This was fine as the footage I shot replicated rather well and it wasn't too obvious.
                With the crop technique I have to zoom to %115 to clear the black borders (the shake is for explosions in the footage).
                The video is at 1080p so quality degredation isn't so much an issue. Rather the issue is the subject is very close to the camera and already falling outside of safe. So zooming exacerbates the amount of the subject (eyes, mouth) that are outside the viewing area.
                I read two seperate tutorials for creating camera shake and both mentioned using motion tile to buy back a few pixels. In the preview it seems to work well. It just doesn't render it out like it appears in the preview.
                I have another render going with zoom at %115 and motion tile off. I'll let you know how it comes out. Thanks for the help. I'm blown away someone (from Adobe) was on here that late a night to answer my question. I hadn't expected that.
                • 5. Re: Camera shake works in preview but not in final render.
                  xavierpayne Level 1
                  Many thanks to Adolfo Rozenfeld at Adobe.
                  After looking over my project file we uncovered 2 things.
                  First the difference between my RAM Preview and the Final render was that I had my workspace configured to ALWAYS use OPEN GL. For certain effects the hardware accelerated open gl preview and the software renderer (used by default in the render queue) can yeild different results. The software renderer is more feature complete but slower.
                  Second he discovered that I had inadvertently applied a keylight effect to one of my adjustment layers. In this particular case I didn't need the keylight and removing it allowed my project to render as expected.
                  Thanks again Adolfo!
