1 Reply Latest reply on Jul 21, 2008 9:37 AM by Newsgroup_User
    Member copying performance
    TJW-dev
      As part of a program, I have the need to copy a large amount of bitmap cast members between 2 casts.
      (MX2004)
      I was hoping someone would know the performance implications, and which one of the following were better:
      Option 1: Create the bitmap member, then copy the image of the member
      repeat with foo = 1 to numOfImagesInCast
      new(#bitmap, member(foo, "destinationCast"))
      member(foo, "destinationCast").image = member(foo, "originalCast").image
      end repeat
      Option 2: Just copy the member
      member(foo, "destinationCast") = member(foo, "originalCast")
      end repeat
      If option 2 is better, that should I also be using duplicate() i.e. member(foo, "destinationCast") = duplicate(member(foo, "originalCast"))
        • 1. Re: Member copying performance
          Level 7
          In the first case, the player has to:
          - read the original member data
          - decompress the data, if compressed
          - set the data as the content of an image object
          - create the new member, and set it's image data to a copy of the new image.
          In the second case you just duplicate the original member data (header +
          {compressed} image data)
          Creating 'empty' cast members on the fly should be a light process - not
          very slower than from creating sprites. Haven't benchmared it, hence the
          'should'.
          For duplicating the member, according to the above, the second method should
          be faster, since it performs a data copy rather than read/decompress/write.
          It also uses less ram, and retains the original format.
          "TJW-dev" <webforumsuser@macromedia.com> wrote in message
          news:g629bd$cuk$1@forums.macromedia.com...
          > Hi,
          > cast
          > one of
          > end repeat
          > end repeat
