0 Replies Latest reply on Jul 21, 2008 9:28 AM by mjhjap
    ItemRenderer
    mjhjap
      Having a problem with using an itemRenderer in datagrid column, the custom column appears correctly but whenever I dynamically change the dataProvider I get a repeat of the custom column and as I'm potentially using a dataProvider with a different schema to the initially loaded schema I then get a mixture of the old schema and current schema fields. It all appears to work correctly though if I don't create the custom column.
      See attached code for creating custom column which is created when I get the data result(onResult) and also the code for the itemRenderer (ButtonAddToPlaylist).
      Mike
