1 Reply Latest reply on Oct 21, 2009 7:04 AM by the_wine_snob
    NO PLAYBACK IN PREMIER PRO CS 4
    GinaRS
      I recently upgraded to CS4 and somtimes the timeline freezes. Playback only works if I "scrub" the playhead across the timeline. Anyone have any fixes for this?
        • 1. Re: NO PLAYBACK IN PREMIER PRO CS 4
          the_wine_snob Level 9
          Gina,
          Many of us have encountered "pauses" in playback, since at least PrPro 2.0. For most, there seems to be no rhyme, or reason that has been found - no commonality.
          That said, these pauses can be very specific to one's Assets. If this is the case for you, please let us know about your source footage, and also your Project/Sequence Preset. There might be an issue there. Also, does you playback stop at the same point, or is it totally random?
          In the situations I mentioned above, the total randomness negated all efforts to pin-point the why. Sometimes it would be at a Transition, and the next time in the middle of a Clip. Sometimes it would be on a tiny Timeline with only one Clip and others would get it with long Timelines and many Clips. In these cases, the source footage would be DV-AVI Type II's and it didn't seem to matter if any Effects were added, and Rendering (when necessary) had no common result. In my cases, a Timeline would sometimes play perfectly a half-dozen times, only to halt at random points the next.
          Good luck, and please let us know more about your Assets and your Project/Sequence. Also, a bit about your system will possibly help, especially the I/O sub-system, i.e. your HDD's, their size, speed, free space, controller type(s) and how they are allocated.
