2 Replies Latest reply on Oct 27, 2009 8:07 AM by Wiouou
    Cannot connect to named destination (webservice)
    Wiouou Level 1
      I'm trying to add a named destination to proxy-config.xml for a webservice but I'm getting this error when trying to send a message:
      'my-http' fault handler called. [IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2032: Stream Error. URL: http://iveCycle.swf/lcds-samples/messagebroker/http" errorID=2032]
      'my-http' channel polling stopped.
      'my-http' channel connect failed.
      'my-amf' channel endpoint set to http://iveCycle.swf/lcds-samples/messagebroker/amf
      'my-amf' channel settings are:
      <channel id="my-amf" type="mx.messaging.channels.AMFChannel"><endpoint uri="http://{server.name}:{server.port}/lcds-samples/messagebroker/amf"/><properties><polling-enabled> false</polling-enabled></properties></channel>
      '7A059B6D-AABB-EFF5-1E32-774CDF862EC3' producer channel faulted with Channel.Ping.Failed  url: 'http://iveCycle.swf/lcds-samples/messagebroker/http''
      'my-amf' pinging endpoint.
      'my-amf' channel got status. (Object)#0
        code = "NetConnection.Call.Failed"
        description = "HTTP: Status 502"
        details = "http://iveCycle.swf/lcds-samples/messagebroker/amf"
        level = "error"
      'my-amf' channel polling stopped.
      'my-amf' channel connect failed.
      '7A059B6D-AABB-EFF5-1E32-774CDF862EC3' producer channel faulted with Channel.Connect.Failed NetConnection.Call.Failed: HTTP: Status 502: url: 'http://iveCycle.swf/lcds-samples/messagebroker/amf'
      '7A059B6D-AABB-EFF5-1E32-774CDF862EC3' producer fault for 'E998C06C-CA6A-F0EA-ADE1-774CE05214D1'.
      The code in the proxy-config.xml is:
          <destination id="brailleWebService">
              <adapter ref="soap-proxy"/>
              <properties>
                  <wsdl>http://www.webservicex.net/braille.asmx?wsdl</wsdl>
                  <soap>http://www.webservicex.net/braille.asmx</soap>
              </properties>
          </destination>
      and in the mxml:
          <mx:WebService id="brailleDestination" destination="brailleWebService" fault="handleBrailleFault (event)" result="handleBrailleResult (event)" useProxy="true">
              <mx:operation name="BrailleText">
              </mx:operation>
          </mx:WebService>
      I'm wondering why there is an attempt to connect to http://iveCycle.swf/lcds-samples/messagebroker/http.  The servername here is the name of my project without its first letter.  Although the server config for my project (properties/flex server) point to localhost.  Any idea what's going on here?
      PS: the connection works fine when I work without a named destination.
