3 Replies Latest reply on Oct 23, 2009 8:17 PM by ZeKid
    Data comboBox
    RosieGp Level 1
      I have the follwoing:
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
        creationComplete="addRecord();" width="100%" height="100%">
        <mx:Script>
          <![CDATA[
            import mx.controls.*;
            private function addRecord():void{
              var vb:VBox = new VBox();
              vb.setStyle("backgroundColor", "0xFFFFFF");
              var infoLbl:Label = new Label();
              infoLbl.text="Information"
              infoLbl.setStyle("fontWeight", "bold");
              vb.addChild(infoLbl);
              var selectCbx:ComboBox = new ComboBox();
              selectCbx.prompt = "Make a Selection";
               ISSUE 1
              selectCbx.dataProvider="{rhdata}";
              vb.addChild(selectCbx);
              var selectCbx2:ComboBox= new ComboBox();
              selectCbx2.prompt = "New/Existing";
                ISSUE 2
              //// how to add an arraycollection here something like so that it display data in ComboBox
             ////  <mx:ArrayCollection> <mx:String>New</mx:String> <mx:String>Existing</mx:String> </mx:ArrayCollection>
             ////  OR can I do something like
             ////  var RHarray:Array = ["New", "Existing"];
              vb.addChild(selectCbx2);
              var partA_Lbl:Label = new Label();
              partA_Lbl.text = "Part A";
              partA_Lbl.setStyle("fontWeight", "bold");
              vb.addChild(partA_Lbl);
              var recordA_Rte:RichTextEditor = new RichTextEditor();
              recordA_Rte.title="Record A"
              recordA_Rte.height=249;
              recordA_Rte.width=454;
              vb.addChild(recordA_Rte);
              var recordB_Rte:RichTextEditor = new RichTextEditor();
              recordB_Rte.title="Record B"
              recordB_Rte.height=249;
              recordB_Rte.width=518;
              vb.addChild(recordB_Rte);
              var partB_Lbl:Label = new Label();
              partB_Lbl.text = "Part B";
              partB_Lbl.setStyle("fontWeight", "bold");
              vb.addChild(partB_Lbl);
              var hr:HRule = new HRule();
              hr.setStyle("strokeWidth", 2);
              hr.setStyle("strokeThickness", 2);
              hr.percentWidth = infoVB.width;
              infoVB.addChildAt(hr, 0);
              infoVB.addChildAt(vb, 0);
        </mx:Script>
      [Bindable] public var rhdata:ArrayCollection;
      private function resultNR(event:ResultEvent):Void{
          rhdata=ArrayCollection(event.result);
      <mx:RemoteObject id="cf" destination="ColdFusion" source="cfc.CR">
      <mx:method name="getNR" result="resultNR(event)" fault="Alert.show(event.fault.message)"/>
      </mx:RemoteObject>
        <mx:Button x="878" y="625" label="Add New Record" click="addRecord();"/>
        <mx:VBox id="infoVB" verticalGap="15" horizontalAlign="center"/>
      </mx:Application>
      The issue 1 is when I run this, all I see in the combobox is {rhdata} as result... and nothing else. Please let me know if I'm missing anything.
      Thanks...
        • 1. Re: Data comboBox
          ZeKid
          Hello RosieGp,
          See modifications below ...  The syntax is a bit different in AS and mxml.
          <mx:Application
          creationComplete="resultNR();addRecord();" width="
          <!--creationComplete="addRecord();" width="100%" height="100%">-->
          <mx:Script>
          <![CDATA[
          import
          mx.controls.*;
          import
          mx.collections.ArrayCollection;
          var vb:VBox = new
          VBox();
          vb.setStyle(
          Label();
          infoLbl.text=
          "Information"
          infoLbl.setStyle(
          ComboBox();
          selectCbx.prompt =
          "Make a Selection"
          //ISSUE 1
          //selectCbx.dataProvider="{rhdata}";
          selectCbx.dataProvider=rhdata;
          ComboBox();
          selectCbx2.prompt =
          "New/Existing"
          //ISSUE 2
          var myArrayCollection:ArrayCollection = new ArrayCollection( [{label:'New'},{label:'Existing'}] );
          selectCbx2.dataProvider = myArrayCollection;
          Label();
          partA_Lbl.text =
          "Part A"
          partA_Lbl.setStyle(
          RichTextEditor();
          recordA_Rte.title=
          "Record A"
          RichTextEditor();
          recordB_Rte.title=
          "Record B"
          Label();
          partB_Lbl.text =
          "Part B"
          partB_Lbl.setStyle(
          var hr:HRule = new
          HRule();
          hr.setStyle(
          "strokeWidth"
          , 2);
          hr.setStyle(
          "strokeThickness"
          , 2);
          Bindable
          public var
          /*private function resultNR(event:ResultEvent):void {
          // I don't have your cfc ...
          // Called from creationComplete ...
          private function resultNR():void
          rhdata =
          new ArrayCollection( [{label:'2009-10'},{label:'2010-11'},{label:'2011-12'
          </mx:Script>
          <!--<mx:RemoteObject id="cf" destination="ColdFusion" source="cfc.CR">
          </mx:RemoteObject>-->
          </mx:Application>
          • 2. Re: Data comboBox
            RosieGp Level 1
            //ISSUE 1
            this is still not working....
            • 3. Re: Data comboBox
              ZeKid Level 1
              Hello Rosie,
              If the line:   selectCbx.dataProvider = rhdata;   is not working, my guess would be that it's your remote call that is not working.  But I really don't know, you have to be more specific ...
              If you copy and paste the code of my previous post into a new project and compile it, you'll see that it's working ...  but I'm not using the result of a remote call as the dataProvider for the comboBox ...  which is why I think it could be the remote call ...
              By the way, in your original code, there is no place where you actually call your remoteCall method getNR ...   i.e.    cf.getNR();
              I'm not sure if your "Make a Selection" comboBox must contains the same values for all the records that you add, but if it's the case, you only have to call your remote call once, at the beginning.
              Remote calls are asynchronous, which means you must wait for the results before continuing the processing, unless that processing has nothing to do with the result of the remote call.  In your case, you can not create your 1st record until you've received the result of your remoteCall, because you need it to fill up the comboBox in the records.  So instead of calling addRecord() from creationComplete(), I would call the remoteCall  cf.getNR() , and then, inside resultNR() , right after you've received rhdata , you would create the first record by calling addRecord().
              Also, note that in order to be able to compile your code, I had to move the following bit of code inside the </mx:Script> tag and rename "Void" to "void".
              Let me know how it's going ...
