1. Re: monitor calibration and photoshop
John Joslin Oct 21, 2009 9:40 AM (in response to avpromedia)This is not unexpected. Only colour-managed applications will be correct.
2. Re: monitor calibration and photoshop
Scooby007 Oct 21, 2009 11:04 AM (in response to avpromedia)Apparently photoshop is applying additional color correction on top of what the monitor calibration software has already done. Is this necessary? If this step is necessary, then why doesn't the monitor calibration software do that, so that photoshop doesn't have to,
Photoshop doesn't apply any color correction to the images per se, it just operates in a selected color space, and takes into account your monitor profile.
The monitor calibration tells your video card - or the monitor itself for some high end monitors, how it should be set to meet chosen targets, and generates a profile for the monitor.
1. Caibrate your monitor and generate a profile
2. Tell your OS that that it your monitor profile
3. Set Photoshop to work in the space of your choice - sRGB, Adobe RGB, or ProPhoto 99% of the time
That takes you to a state where everything is in order more or less. If at this point your images look out of whack, it's almost certainly because they are, perhaps because they were previously corrected on a non-calibrated setup.
Photoshop and other color managed application should display them all more or less exactly the same, provided the files themselves have a color profile .
