0 Replies Latest reply on Oct 21, 2009 9:13 AM by jmurphy67
    [svn:fx-trunk] 11050: Merged 3.x revisions 10953,10964,10974,11007, 11026 to Trunk
    jmurphy67 Level 1
      Revision: 11050
      Author:   jimurphy@adobe.com
      Date:     2009-10-21 09:12:53 -0700 (Wed, 21 Oct 2009)
      Log Message:
      Merged 3.x revisions 10953,10964,10974,11007,11026 to Trunk
        r10953 | aharui@adobe.com | 2009-10-09 13:50:37 -0400 (Fri, 09 Oct 2009) | 11 lines
        Get rid of a try/catch block that was generating a lot of noise on the heap.
        QE Notes: None
        Doc Notes: None
        Bugs: SDK-23563
        Reviewer: Ryan
        API Change: no
        Is noteworthy for integration: No
        tests: checkintests mustella/Managers/DragManager
      r10964 | rfrishbe@adobe.com | 2009-10-09 19:23:26 -0400 (Fri, 09 Oct 2009) | 8 lines
        In DividedBox we mutate a child?\195?\134s percentWidth/percentHeight values.  This is so we can utilize the default BoxLayout algorithm.  However, after the algorithm has finished running, we should reset the values to what they were so when children get added it works correctly.
        QE notes: -
        Doc notes: -
        Bugs: SDK-15876
        Reviewer: Alex
        Tests run: checkintests, mustella DividedBox
        Is noteworthy for integration: no
        r10974 | pfarland@adobe.com | 2009-10-12 17:56:48 -0400 (Mon, 12 Oct 2009) | 9 lines
        Submitting customer patch for SDK-19188. Correcting XSD scope lookup while decoding wrapped style document literal responses.
        QE notes: Please add a regression test for this scenario.
        Doc notes: N/A
        Bugs: SDK-19188
        Reviewer: Pete
        Tests run: Checkintests, webtier mxunit, flexunit
        r11007 | pfarland@adobe.com | 2009-10-19 14:26:21 -0400 (Mon, 19 Oct 2009) | 17 lines
        Adding support for <xsd:any /> deserialization to include attributes as properties in addition to child elements.
        Just as with multiple child elements of the same name, an attribute and child element sharing the same name will be promoted to an Array of values (or ArrayCollection if makeObjectsBindable is true).
        Since dynamic ActionScript objects can only have public properties added at runtime, attribute namespaces will be ignored and only the localName will be used for the property name.
        Simple values that have attributes are supported - a special dynamic SimpleContent type is used to hold the value (the simple content value can be retrieved using toString() or valueOf()) and attributes become dynamic properties on this instance.
        Mixed content is still not supported and the cdata content is ignored.
        QE notes: Yes, please add a test case that uses attributes in the SOAP response data for <xsd:any> deserialization.
        Doc notes: We may want to add a release note that fixing this bug includes attributes during generic SOAP deserialization for the <xsd:any> scenario.
        Bugs: SDK-23140 - No data while using "Object" as "resultFormat" for Sharepoint WebService
        Reviewer: Svetlin, Tom J
        Tests run: Checkintests, bug test case
        r11026 | jimurphy@adobe.com | 2009-10-20 11:47:03 -0400 (Tue, 20 Oct 2009) | 8 lines
        update 3.x with most recent release of AIR: 1.5.2.8900
        QE notes:
        Doc notes:
        Bugs: no
        Reviewer: n/a
        Tests run: yes
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-23563
          http://bugs.adobe.com/jira/browse/SDK-15876
          http://bugs.adobe.com/jira/browse/SDK-19188
          http://bugs.adobe.com/jira/browse/SDK-23140
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/DividedBox.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/dragClasses/DragProxy.as
          flex/sdk/trunk/frameworks/projects/rpc/src/mx/rpc/soap/SOAPDecoder.as
          flex/sdk/trunk/frameworks/projects/rpc/src/mx/rpc/xml/XMLDecoder.as
          flex/sdk/trunk/in/air/mac/AIR Integration Kit.tbz2
          flex/sdk/trunk/in/air/win/AIR Integration Kit.zip
      Property Changed:
          flex/sdk/trunk/
