4 Replies Latest reply on Oct 21, 2009 9:36 PM by Phoenix_Guru
    Hiding the Item Renderer???
    Phoenix_Guru
      I have a datagrid with checkboxes in a column:
      <mx:DataGridColumn dataField="dValue" editable="false">
      <mx:itemRenderer>
      <mx:Component>
      <mx:CheckBox selected="{data.dValue == 'true'}"/>
      </mx:Component>
      </mx:itemRenderer>
      </mx:DataGridColumn>
      Now what I want is to hide the checkBox when the dValue is false. How do i do that? I tried visible="{data.dValue=='false'}" but it did not work.
      How do I hide my checkbox when dValue is false??
      Please Help!!
      Saurabh
        • 1. Re: Hiding the Item Renderer???
          JeffryHouser Level 4
          Will set the visible property to true when data.DValue is false.  Is that your problem?
          That said, using binding in an itemRenderer is generally frowned upon for performance reasons.  Write some ActionScript and respond to the dataChange event
          <mx:itemRenderer>
          <mx:Component>
          <mx:CheckBox selected="{data.dValue == 'true'}" creationComplete="init()>
             <mx:Script>
              public function init():void{  this.addEventListener(FlexEvent.DATA_CHANGE,onDataChange) }
            public function onDataChange(e:FlexEvent):void{
              if(data.dValue == false){
              this.visible = false;
          </mx:Script>
             </mx:CheckBox>
          </mx:Component>
          </mx:itemRenderer>
          I wrote this code off the top of my head, it is untested.
          • 2. Re: Hiding the Item Renderer???
            Phoenix_Guru Level 1
            Hi Jeff,
            I tried you approach of using data change event but it still does not seem to work. Can you please check your code once. I corrected my condition to check data.dValue==true for visibility. The selection part of is working like a charm. Its just the visiblity part that I am not able to get working.
            Saurabh
            • 3. Re: Hiding the Item Renderer???
              Flex harUI Adobe Employee
              You can't use visible to hide renderers.  The recycling system use visible to control off-screen renderers.  Try using alpha instead, but keep in mind that having a blank cell is sort of strange.
              Alex Harui
              Flex SDK Developer
              Adobe Systems Inc.
              Blog: http://blogs.adobe.com/aharui
              • 4. Re: Hiding the Item Renderer???
                I solved the problem by using an external itemrenderer. The code is below:
                <mx:HBox
                xmlns:mx="http://www.adobe.com/2006/mxml">
                    <mx:Script>
                          <![CDATA[
                              override public function set data(value:Object):void
                                    super.data = value;
                                    if(value.vis == true)
                                         cb.visible =
                true;
                                         cb.selected =
                true;
                                    else
                                         cb.visible =
                false;
                                         cb.selected =
                false;
                </mx:Script>
                <mx:CheckBox id="cb"/>
                </mx:HBox>
                Do you see any possible issues with this code?
                Saurabh
