1 Reply Latest reply on Jul 22, 2008 6:45 AM by anoweb
    HibernateAssembler problem loading object
    anoweb Level 1
      I'm using LCDS (LiveCycle Data Services) 2.5.1 and I am trying to load a Java object using hibernate and have it given to my flex client.
      I followed this tutorial: http://blog.comtaste.com/2007/07/livecycle_data_services_and_hi.html
      Only issue is that when I attempt to use the DataService object (in flex client) to do a "getItem" I get the following error:
      Missing identity properties: id
      My "data-management-config.xml" has this:
      <destination id="hibernatePerson">
      <adapter ref="java-dao" />
      <channels>
      <channel ref="my-rtmp" />
      </channels>
      <properties>
      <source>flex.data.assemblers.HibernateAssembler</source>
      <scope>application</scope>
      <metadata>
      <identity property="id" />
      </metadata>
      <server>
      <hibernate-entity>foo.bean.Person</hibernate-entity>
      <update-conflict-mode>PROPERTY</update-conflict-mode>
      <delete-conflict-mode>OBJECT</delete-conflict-mode>
      <fill-configuration>
      <use-query-cache>false</use-query-cache>
      <allow-hql-queries>true</allow-hql-queries>
      </fill-configuration>
      </server>
      </properties>
      </destination>
      Any ideas?
        • 1. Re: HibernateAssembler problem loading object
          anoweb Level 1
          I got it. After reading some of the documentation on DataService.getItem I learned that the "ItemReference" object that is given back extends "AsyncToken". This means you should either bind to the "result" property of the ItemReference or add a responder to it (i.e. itemRef.addResponder).
          Then once the data is retrieved your "result" or "fault" methods (from the mx.rpc.IResponder interface) will be invoked.
