2 Replies Latest reply on Oct 21, 2009 2:57 PM by Seglespaan
    combo box with v-slider inside?
    Seglespaan
      can anyone tell me if this is possible, I want to create a text size control, the off state is to look like a combo box displaying the current size, but when the user clicks it I want a slider to appear so that they can then control the size of the text using the slider?
      Is this possible?
      Cheers
      Tim
        • 1. Re: combo box with v-slider inside?
          Andrew Rosewarn Level 3
          Hi there
          Certainly is, probably want a custom component there.  Here's a really quick example which needs tidying up.  I;ve just used the popupbutton which looks like a combo and a custom canvas with a vslider in it and bound up the property.
          Main App
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute">
          <mx:Script>
          <![CDATA[
          [Bindable] private var pop:PopUPSlider = new PopUPSlider()
          </mx:Script>
          <mx:PopUpButton x="420" y="23" label="{pop.fontSize}" popUp="{pop}"/>
          </mx:Application>
          Custom Comp
          <mx:Canvas xmlns:mx="http://www.adobe.com/2006/mxml" width="34" height="88" borderStyle="solid" backgroundColor="#FFFFFF">
          <mx:Script>
          <![CDATA[
          [Bindable] private var _fontSize:int;
          [Bindable]
          public function set fontSize(value:int):void {
          _fontSize = value;
          public function get fontSize():int {
          return _fontSize;
          private function setFontSize():void {
          fontSize = vslide.value;
          </mx:Script>
          <mx:VSlider x="8" y="4" height="76" id="vslide" minimum="10" maximum="18" snapInterval="2" liveDragging="true" change="setFontSize()"/>
          </mx:Canvas>
          Hope this helps
          Andrew
          • 2. Re: combo box with v-slider inside?
            Seglespaan Level 1
            exactly what I'm after, Thanks loads! Worked a treat!
