4 Replies Latest reply: Oct 21, 2009 8:56 PM by John.Kordas RSS
    JS CS3 Fastest way to create a group
    John.Kordas Community Member
      I have a selection of about 1050 elements and to create a group I'm using:
      var myNewGroup = new Array;
      for (i=app.selection.length-1; i>=0; i--) {
          myNewGroup.push (app.selection[i]);
        var myGroup = app.activeDocument.groups.add(myNewGroup);
      This works but it's very slow. I have tried the following:
      var myNewGroup = app.selection;
      The app.selection approach gives me an Invalid parameter error. What I don't understand is that the working code creates an array and adds each element to the array then a group is created from that array.
      With the second approach app.selection is an array so why does this group?
        • 1. Re: JS CS3 Fastest way to create a group
          RorohikoKris-u5pUJw Community Member
          Hmm... Try
          var myNewGroup = app.selection.slice(0);
          AFAIK app.selection is a 'pseudo-array' - it tastes and smells like an array, but it ain't one. The .slice(0) trick is something I tend to use to force these to convert to a 'real' array.
          Let us know whether it works!
          Cheers,
          Kris
          • 2. Re: JS CS3 Fastest way to create a group
            Thanks Kris for the quick reply. Unfortunately I'm still getting an Invalid parameter on the
            Any other suggestions?
            • 3. Re: JS CS3 Fastest way to create a group
              I had a quick check - your initial attempt with app.selection seems to work for me - no .slice(0) needed.
              But one thing to be aware of: don't run the same script twice in quick succession. What happens is this:
              a) you run the script -> all is well; selection becomes a group
              b) you run the script again -> invalid parameter (because now your selection only has a single element in it - the group)
              Could this be the issue you see? Re-select and make sure your selection is not already grouped before trying.
              I'd change it so it becomes a variation of:
              if (myNewGroup.length > 1)
              • 4. Re: JS CS3 Fastest way to create a group
                Thanks again Kris,
                The document I'm trying this on is supplied not created by me so I should of run a test on a doc a created first, so I did. I made a new A4 doc and place a number of text elements on the page then selected them and ran the script again. Sure enough the selection became a group.
                So I went back to the supplied doc and selected a couple of the frame and check under the Object menu , Content and to my surprise the options Graphic, Text, and Unassigned were all grayed out (could not select any).
                Yet when I ran:
                $.write(app.selection[1].constructor.name+"\n");
                the console returns TextFrame and for
                $.write(app.selection[1].contentType+"\n");
                the console returns 1952412773 (TEXT_TYPE).
                So there seems to be an issue with the file not the script. Thanks for you help Kris much appreciated.
