10 Replies Latest reply on Nov 2, 2009 12:03 PM by BKBK
    cfgrid and href attribute issue
    richardELeach Level 1
      HI Gang-
      I'm building a relatively simple query driven cfgrid, read-only for the most part but I need one of the columns to be a href value that will serve as a drilldown. Everything working fine except that the name/value pair I need appended to the url is being persnickety.
      The url I'd like to build and have effected in the cfgrid is something like "index.cfm?action=drilldown&orderid=#dynamicValue#"
      I finally got it to work, but not as I would like. Turns out both cfgrid and cfgridcolumn tags each have the "href" and the "hrefkey" attributes, which made for a confusing 45 minutes of trial and error.  The closest I could eventually come to my target url of:
      is actually
      index.cfm?action=drilldown&CFGRIDKEY=#dynamicValue#
      Not what I wanted but I can deal for now.
      Has anyone gotten a hold of building out hrefs in cfgrid using custom name/value pairs dynamically? Would love to know how you did it. Code postings would be even better!
      Many thanks,
      Rich
        • 1. Re: cfgrid and href attribute issue
          Adam Cameron. Level 5
          I think the CFGRIDKEY approach as documented is as good as it gets currently.  I googled about the place for a solution, and the "best" I found was this blog entry - http://www.danvega.org/blog/index.cfm/2008/3/21/ColdFusion-9-WishList-Calling-for-suggesti ons - in which someone requests more flexibility as per your requirement.
          There does not seem to be an E/R for it in the CF bug base (http://cfbugs.adobe.com/cfbugreport/flexbugui/cfbugtracker/main.html#), so perhaps you might like to raise one?  I'll vote for it too if you feed-back what the E/R number is.
          Adam
          • 2. Re: cfgrid and href attribute issue
            BKBK Adobe Community Professional & MVP
            Quite a challenge, that one. You can run the following example directly. Have a look at my use of the lastName column. You could also have a look at the ext library.
            <html>
            <head>
                 <title>Grid URL Demo</title>
                 function init(){
                     var grid = ColdFusion.Grid.getGridObject("ArtistGrid");
                     grid.addListener("rowclick",onRowClick);
                 function onRowClick(g,rowIndex,e){
                   var lastName = ColdFusion.getElementValue("ArtistGrid", "artistGridForm", "lastName");
                   var url = "index.cfm?action=drilldown&lastName="+lastName;
                   ColdFusion.navigate(url);
                 </script>
            </head>
            <body>
                 <cfquery name="getArtists" datasource="cfartgallery">
                 SELECT artistId, firstname, lastname, address, city, state, postalcode, email
                 FROM Artists
                 </cfquery>
                 <cfset args = structNew()>
                 <cfset args.name = "ArtistGrid">
                 <cfset args.format = "html">
                 <cfset args.query = "getArtists">
                 <cfset args.stripeRows = true>
                 <cfset args.selectColor = "##D9E8FB">
                 <cfset args.width = 600>
                 <h1>Artists Grid</h1>
                 <cfform name="artistGridForm" id="artistGridForm">
                    <cfgrid attributeCollection="#args#">
                       <cfgridcolumn name="artistid" display="false">
                       <cfgridcolumn name="firstname" header="First Name">
                       <cfgridcolumn name="lastname" header="Last Name">
                       <cfgridcolumn name="email" header="Email Address">
                       <cfgridcolumn name="address" header="Address">
                       <cfgridcolumn name="city" header="City">
                       <cfgridcolumn name="state" header="State">
                       <cfgridcolumn name="postalcode" header="Zip">
                    </cfgrid>
                 </cfform>
                 <cfset ajaxOnLoad("init")>
            </body>
            </html>
            • 3. Re: cfgrid and href attribute issue
              Actually, now that I have engaged my brain, this is quite easy.
              Add a column to your query that has your href in it, and then use the HREF attribute to use that for the HREF of the grid cells.
              EG:
              <!--- Query the database to fill up the grid. --->
              <cfquery name = "qCourses" dataSource = "cfdocexamples">
                  SELECT        Course_ID, Dept_ID, CorNumber, CorName, CorLevel
                  FROM        CourseList
                  ORDER by    Dept_ID ASC, CorNumber ASC
              </cfquery>
              <cfquery name="qCourses" dbtype="query">
                  select    *, '#CGI.script_name#?course_id=' || cast(Course_ID as varchar) || '&Dept_ID=' || cast(Dept_ID as varchar) as courseHref
                  from    qCourses
              </cfquery>
              Obviously this example is just reusing column data from the query, but the courseHref column could contain anything.
              Adam
              • 4. Re: cfgrid and href attribute issue
                In my opinion, this doesn't quite face the challenge head-on. For at least 3 reasons. First, it involves extra work on the server side. Second, it mixes presentation code(grid) with business code(query). Third, and most important, it is actually a static, not a dynamic, solution. The user clicks on a predetermined list of URLs and not, for example, on the course_id column as is required.
                • 5. Re: cfgrid and href attribute issue
                  Thanks everyone for your input. I actually went with something along the lines that Adam described, even though  it is not exactly as free and autonomous of a solution that I would like it still permitted enough of a dynamic workflow to handle my use case.
                  When the smoke clears from my deadline I'll be submitting to Adobe for a feature request, otherwise this CFGRID is a very useful tool for the CFML library.
                  Many thanks,
                  Rich
                  • 6. Re: cfgrid and href attribute issue
                    Indeed. I do believe it would be a straightforward addition, given that Coldfusion now has the ext library!
                    • 7. Re: cfgrid and href attribute issue
                      So? Fetching and manipulating data is the job of the server, not the client.  The client should simply be displaying what it's told to display, and how it's told to display it.
                      No it doesn't.  No more than having any other sort of URL in there.  Indeed your option is pushing business logic onto the client, in that it's down to client-side view code to build the URLs, which is definitely not the job of view code.
                      Anyway, doing it via the mechanism that CF actually provides to achieve the end is a much better approach that buggering about with client-side JS to hack something that one could instead do out-of-the-box.
                      It's definitely less than ideal that there is no way to suppress that column from outputting in the grid.  That is dumb.  However the HREF is appied to ALL the cells of the grid, not just the one displaying the HREF.  Anyway, that's easily solved by using <cfgridcolumn> tags to specify which columns to display.  And indeed then one can specify different URLs for each column that way, should one wish to.
                      Adam
                      • 8. Re: cfgrid and href attribute issue
                        ...FWIW, I'm using ModelGlue (2.0) and I call the cfgrid code in question in a view but reference the query from a call in the controller via code instantiated from the model. This debate has arisen in the ModelGlue Google group and is quite entertaining; I think the end result was that folks agreed to disagree and there was no concrete, undisputed right or wrong way to do it. Like a lot of the rest of the ColdFusion platform, they're are usually more than several ways to accomplish a task and this way seemed to work best for me.
                        But Adobe could make an enhancement or two with the cfgrid tags and make it even easier....
                        Thanks to all for your help and suggestions,
                        Rich
                        • 9. Re: cfgrid and href attribute issue
                          With Javascript presentation and onclick code?
                          You lost me there. Isn't the browser, that is, the client, part of the View?
                          • 10. Re: cfgrid and href attribute issue
                            I am sure it will happen. In fact, it already has in a way!
                            Coldfusion now includes the ext library. The solution to your problem is there somewhere. I bet it is more trivial than what we've been doing here, if only you know how.
