2 Replies Latest reply on Oct 22, 2009 4:46 AM by Wade_Zimmerman
    is there a way to use a path as a selection marquee?
    oompal
      Is there a way to take path, closed, and select everything that falls inside? or crosses it?
        • 1. Re: is there a way to use a path as a selection marquee?
          JETalmage Level 6
          Nope. I've been suggesting that for years as a better interface for both "lasso" selections and cutting paths.
          If Illustrator's Javascript model provided a function for path intersection and "collision", (similar to FlashScript's ability to detect path collisions) scripting such a solution would probably be trivial. But there is no such function provided.
          Such a function could be leveraged for other features, too. For example, imagine integrating it with Symbols. You're drawing a map. You have a Symbol of a tree. You draw a path in the shape of the forest, and issue a command to randomly position any desired number of Instances of the Symbol.within the path. (Compare the speed and ease of that to the tedious and difficult-to-control Symbolism tools.)
          You can do cumbersome workarounds, but so far, any I've come up with proove too sluggish. For example, you could semi-automate this with a combination of Script and Actions:
          1. Draw a path.
          2. Fill it with a Pattern Swatch (or Create Object Mosaic)
          3. Expand the fill (or Ungroup the Object Mosaic)
          4. Replace the resulting Groups (or Object Mosiac paths) with Instances of a Symbol.
          5. Use the Random setting of Transform Each to somewhat "randomize" the placements.
          But even that does not guarantee intersection with the original path.
          I have used similar routines to script the creation of pseudo halftones and diffusion dithers. But for much detail the scripts are very slow.
          JET
          • 2. Re: is there a way to use a path as a selection marquee?
            Wade_Zimmerman Level 6
            Selection Options could be improved.
