3 Replies Latest reply on Oct 23, 2009 10:22 PM by Techi Panda
    Grouping labeled textframes
    Techi Panda
      Hi scripters
      i cant group two labeled textframes, where i am wrong in the below script
      x = app.activeDocument.textFrames.item("Fig");
      y = app.activeDocument.textFrames.item("Cap");
      g = app.activeDocument.groups.add([x,y]);
      ERROR
      Adobe InDesign
      JavaScript Error!
      Error Number: 30477
      Error String: Invalid value for parameter 'groupItems' of event 'add'. Expected Array of PageItems, but received nothing.
      Line: 21
      Source: g = app.activeDocument.groups.add([x,y]);
      OK
      thanks in advance
      regards
      a r u l
        • 1. Re: Grouping labeled textframes
          Hi Arul!
          The error report states Line 21.
          You did not post the whole code. The 3 lines of code which are available work as expected. Tested this with CS3 and CS4. To investigate further we definitively need to see more code ;-) and/or a description of the InDesign text frames you‘re working with. Maybe one or all of the text frames you want to group are locked?
          Regards,
          Uwe Laubender
          • 2. Re: Grouping labeled textframes
            AdobeScripts Level 3
            ERROR
            Adobe InDesign
            JavaScript Error!
            Error Number: 30477
            Line: 21
            are you sure that x and y "contains" TextFrames ?
            InDesign's message is clear - Expected Array of PageItems, but received nothing - x or y or both are "empty"
            robin
            www.adobescripts.co.uk
            • 3. Re: Grouping labeled textframes
              Techi Panda Level 2
              Hi rabin
              thanks for your suggestion i will try it
              thanks again
              regards
              a r u l
