3 Replies Latest reply on Oct 22, 2009 12:04 AM by Noel01543-4QDIk6
    Cannt hear audio in playback - CP4
    Level 1
      I have recently upgraded to CP4. I have added audio to slides, which I can hear OK when I review the slide (F3), but when I run the project - there is no audio.
      Must be a simple setting somewhere, but I cannt find anything to help..
      Noel
      England
        • 1. Re: Cannt hear audio in playback - CP4
          mvlele Level 3
          If i get you correctly, once you insert audio inside Captivate, you are able to play it using F3. But it does not play when you preview / publish and run your movie.
          - Can you double click on the slide carrying audio and go to audio tab
          - Check if you can play the audio file in this dialog.
          Can you also tell us your system configuration?
          Regards,
          Mukul
          • 2. Re: Cannt hear audio in playback - CP4
            Level 1
            Thanks for fast reply.
            Correct - I can hear audio OK when I preview using F3 option, but not then
            I preview "full slide".
            I can hear the audio when I run it in the "audio tab".
            System details as below
            Noel Griffiths, Bhm MV-TI
            Corporate Customer Solutions, eLearning
            Tel:    +44 (0) 121 352 2540  (Direct)
            Mob:  +44 (0) 7785 388 336
            @:  noel.griffiths@kuehne-nagel.com
            KNet: http://knet.int.kn/bu/cs/sales_support_training/
            Spark ID: noel.griffiths
            “If you don't know where you are going, any road will get you there.”
            THE GLOBAL LOGISTICS NETWORK - 54,000 STRATEGICALLY LOCATED SPECIALISTS -
            850 LOCATIONS - 100 COUNTRIES
        forums@adobe.com
            22/10/2009 07:43                                           To
        cc
                         Please respond to
                         clearspace-153621                                     Subject
                         3438-119379-2-233         Cannt hear audio in
                         1458@mail.forums.         playback - CP4
                             adobe.com
            and run your movie.
            • 3. Re: Cannt hear audio in playback - CP4
              Level 1
              The problem has fixed itself! I re-booted the PC and now all is OK.
              Thanks for your prompt reply and offer of help.
        forums@adobe.com
              22/10/2009 07:43                                           To
        cc
                           Please respond to
                               adobe.com
              and run your movie.
