0 Replies Latest reply on Oct 22, 2009 5:48 AM by Zolotoj
    Combobox acting as textbox
    Zolotoj Level 3
      I am trying to use a combobox as an itemrenderer in the DataGrid. But for some rows I want to have the combo acting as a textbox. I am able to achieve the visual effect: some rows have comboboxes with different  dataProviders and one row has an editable texbox. The comboboxes are working fine. I can select different values without any problem. But I do have a problem with the textbox. Here is some code:
      1. In order to show a combo as a textbox I am using the following:
      setStyle("arrowButtonWidth", "0");
      2. I am assigning a dataProvider to combo/textbox anyway because if I dont then after entering any data into combo/textbox dataGrid's selectedItem for the row and column where the textbox is in will be dropping a field. Another words, lets say that selectedItem looks like this:
      <a1>
           <f1>1234</f1>
           <f2>5678</f2>
      </a1>
      then in combo's change event after typing a single character in grid's selectedItem will look like this:
      <a1>
           <f1>1234</f1>
      </a1>
      that makes kind of hard to track changes and everything.
      3. I am then assigning dataProvider to my combo/textbox. That in turn creates another problem. When I type into the textbox it does not accept any entry. Just single characters typed over. But if I check the change event the grid does not drop a field.
      Any idea how to get this working?
