10 Replies Latest reply on Oct 26, 2009 8:53 AM by -==cfSearching==-
    onApplicationEnd() - are all server resources available?
    ciaranarcher Level 1
      Hi all
      I need to use onApplicationEnd() as part of Application.cfc to execute a call on a 3rd party Java object to close a connection to another device on the network.
      The code I have worked perfectly if I call it as a normal request, but when I place it in the onApplicationEnd() method I'm running into some errors. These errors suggest that CF might in fact be shutting down already to the point where I cannot access these 3rd party Java classes. Not good, but also unexpected.
      I then decided I'd create a parallel thread in the onApplicationEnd() and then rejoin to the main thread when I had closed by connection, but I get an obscure null pointer exception trying to create this thread from this function. Again, the same code works well if I use it in a normal request.
      Is there restrictions to what I can do in onApplicationEnd() and if so is there any work around?
      I am using CF 8 (8,0,1,195765) Developer Edition on a Windows XP machine.
      Many thanks in advance!
      Ciaran Archer
        • 1. Re: onApplicationEnd() - are all server resources available?
          -==cfSearching==- Level 4
          Can you provide more detail about the error messages?
          • 2. Re: onApplicationEnd() - are all server resources available?
            Adam Cameron. Level 5
            And I reckon the code for the onApplicationnd handler too.
            Adam
            • 3. Re: onApplicationEnd() - are all server resources available?
              Thanks for the replies so far. Here is the code:
               <cffunction name="onApplicationEnd" returnType="void">
              <cfargument name="appScope" required="true" />
              <cfset var logLocation = "test" />
              <cflog file="#logLocation#" text="*** [Application.cfc]  - **** START RUN ****" />
              <cflog file="#logLocation#" text="*** [Application.cfc]  - #timeformat(now(),'HH:mm:ss' )# - onApplicationEnd() called " />
              <cftry>
              <cfif structKeyExists(ARGUMENTS, "appScope")>
              <cflog file="#logLocation#" text="*** [Application.cfc]  - #timeformat(now(),'HH:mm:ss' )# - ARGUMENTS.appScope is defined" />
              <cfelse>
              <cflog file="#logLocation#" text="*** [Application.cfc]  - #timeformat(now(),'HH:mm:ss' )# - ARGUMENTS.appScope is undefined! " />
              </cfif>
              <!--- Check if we have a test crypto object in scope, and if so close it's connection --->
              <cfif structKeyExists(ARGUMENTS.appScope, "testCrypto")>
              <cflog file="#logLocation#" text="*** [Application.cfc]  - #timeformat(now(),'HH:mm:ss' )# - onApplicationEnd() - crypto object exists in app scope" />
              <cfset ARGUMENTS.appScope.testCrypto.closeConnection() />
              <cflog file="#logLocation#" text="*** [Application.cfc]  - #timeformat(now(),'HH:mm:ss' )# - onApplicationEnd() - closed crypto server connection" />
              <cfelse>
              <cflog file="#logLocation#" text="*** [Application.cfc]  - #timeformat(now(),'HH:mm:ss' )# - onApplicationEnd() - NO crypto server connection present to close" />
              </cfif>
              <cfcatch type="any">
              <cflog file="#logLocation#" text="*** [Application.cfc]  - #timeformat(now(),'HH:mm:ss' )# - onApplicationEnd() - Error - #cfcatch.message#" />
              </cfcatch>
              </cftry>
              <cflog file="#logLocation#" text="*** [Application.cfc]  - #timeformat(now(),'HH:mm:ss' )# - onApplicationEnd() ended " />
              </cffunction>
              The line to close the connection on my object is failing with the message: 'java.lang.IllegalStateException: Shutdown in progress'.
              Here are the full logs for one run:
              "Information","Thread-8","10/23/09","09:05:54",,"*** [Application.cfc]  - **** START RUN
              Information","Thread-8","10/23/09","09:05:54",,"*** [Application.cfc]  - 09:05:54 - onApplicationEnd() called "
              Information","Thread-8","10/23/09","09:05:54",,"*** [Application.cfc]  - 09:05:54 - ARGUMENTS.appScope is defined"
              Information","Thread-8","10/23/09","09:05:54",,"*** [Application.cfc]  - 09:05:54 - onApplicationEnd() - crypto object exists in app scope"
              Information","Thread-8","10/23/09","09:05:54",,"*** [Application.cfc]  - 09:05:54 - onApplicationEnd() - Error - Shutdown in progress"
              Information","Thread-8","10/23/09","09:05:55",,"*** [Application.cfc]  - 09:05:55 - onApplicationEnd() ended "
              I really hope there is a work-around. The same issue occurs when I run CF as a console window and stop it with CTRL-C or if I run cfstop.
              Cheers,
              Ciaran
              • 4. Re: onApplicationEnd() - are all server resources available?
                Because links have a way of disappearing, I am copying the response from stackoverflow.com :
                It sounds like this may be caused by the fact that the server is shutting down, rather than just the CF application. I am guessing that if the JVM is already in the process of shutting down, the resources your java class uses might not be available at that point. So onApplicationEnd might not be the correct place for that code.
                You might want to look into adding a ShutdownHook. I am not 100% positive, but I think placing the cleanup code there, instead of in onApplicationEnd might allow the java object to do its cleanup before the JVM enters its death throes stage.
                But having said all that, would not the "connection to another device on the network" be closed automatically once the server shuts down?
                • 5. Re: onApplicationEnd() - are all server resources available?
                  I think you're on the button here, -==cfSearching==- : onApplicationEnd() will not reliably run here.
                  I had a discussion elsewhere about why CF9 provides onServerStart() but not onServerEnd().  The fact of the matter this is no reliable way of hooking into a CF-service shutdown, even if it has been triggered by some action.
                  The same would apply for onApplicationEnd() here.
                  onApplicationEnd() is for when the application times out, or applicationStop() is called or something like that.
                  Adam
                  • 6. Re: onApplicationEnd() - are all server resources available?
                    Adam - Was it in a public forum or a private group? I would be interested to read the details, because I was just getting to the new OnServerStart feature today and found myself asking that same silly question..  Just trying to learn more about the nuances and ins and outs of server.cfc
                    -Leigh
                    • 7. Re: onApplicationEnd() - are all server resources available?
                      BKBK Adobe Community Professional & MVP
                      Before we proceed, get the typo <<cflog out of the way. Any changes?
                      • 8. Re: onApplicationEnd() - are all server resources available?
                        Sorry mate, it was a private forum.  But there wasn't much/any info beyond what I said anyway: it wasn't the main topic under discussion.
                        Adam
                        • 9. Re: onApplicationEnd() - are all server resources available?
                          In any case,  it's better to store the object in local scope, as follows
                                 <!---  local scope marks testObject for garbage collection when onApplicationEnd returns --->
                                 <cfset var testObject = "">
                                  <cftry>
                                          <cfelse>
                                          </cfif>
                                                  <cfset testObject = ARGUMENTS.appScope.testCrypto>
                                                 <cfset testObject.closeConnection() />
                                          <cfelse>
                                          </cfif>
                                                  </cfcatch>
                                          </cftry>
                          </cffunction>
                          • 10. Re: onApplicationEnd() - are all server resources available?
                            Adam
                            Okay.  Thanks anyway.
                            -Leigh
