1 Reply Latest reply on Oct 23, 2009 7:52 AM by logeye
    as2 fscommand not working
    CannotCompute
      Basically I want to use fscommand to write a local file. I think there may be some issues --
      variable = "1235";
      path = "file.txt";
      fscommand ("save", path);
      textbox1.text = "HI"; //just so i know it is getting to this point.
      One, does this work on vista? I am running vista so that may be why its not working.
      Two, I also heard rumors about it not working in IE7 or higher, is that true?
      Three, I also have read that it only works when running the swf file in flash projector, is that true?
        • 1. Re: as2 fscommand not working
          logeye Level 1
          If I understand you correctly, I think the 'shared object' might be what you need.
          The AS2 Language Reference in F8 starts off like this:
          "The SharedObject class is used to read and store limited amounts of data on a user's computer. Shared objects offer real-time data sharing between objects that are persistent on the user's computer. Local shared objects are similar to browser cookies. ....."
          hope that helps.
