2 Replies Latest reply on Jul 22, 2008 5:44 AM by ssvacha
    swc textfield not working in tabnavigator
    ssvacha
      Has anyone else run into this, I have a Flash component that has been saved as a swc and imported into Flex. The component contains a textfield, however if the component is attached to a canvas in the tabnavigator, the textfield stops working. Once I remove the tabnavigator mx tags, it works fine.
      For simplicity sake, here are the minimum steps to recreate this issue:
      Create a new ActionScript 3 Flash file
      Create a new MovieClip called "Note" making sure Export for Actionscript and Export in first frame are checked
      Add a Input Text textfield (w:300, h:100, x:0, y:0)
      Convert the symbol to a Flex component
      Import it into your mxml file
      The basic mxml code is as follows:
