2 Replies Latest reply on Oct 23, 2009 12:15 AM by ckisthebest
    Dynamic width of text area
    Seglespaan Level 1
      I'm using the rogue development object handles plugin to allow me to resize and drag n drop elements,
      I want to be able to create a text area that automatically resizes to the same size as the object handle, which is ok if I code the element on th stage from the off and would do so like this
      <oh:ObjectHandles id="object_handle" width="20" height="20">
              <mx:TextArea width="{object_handle.width}" height="{object_handle.height}" text="test">
              </mx:TextArea>
      </oh:ObjectHandles>
      However I want to create an oobject handle with a text area on the fly as and when the user requires, but I can't work out how to bind the width and height of the text area to that of the object handle so that it resizes with it!
      I've tried this
                     ohNew = new ObjectHandles();
                     ohNew.id = "oh";
                     ohNew.width = 10;
                     ohNew.height = 20;
                     taNew = new TextArea();
                     taNew.id = "ta";
                     taNew.width =    ohNew .width;
                     taNew.height = ohNew.height;
                     ohNew.addChild(taNew);
      but it doesn't seem to work, any help would be appreciated,
      Cheers
      Tim
        • 1. Re: Dynamic width of text area
          Subeesh Arakkan Level 4
          Try   taNew.percentWidth = 100; instead of taNew.width =    ohNew .width;
          • 2. Re: Dynamic width of text area
            ckisthebest
            The code below will allow you to increase dynamic height of text area, you can not increase width dynamically.
            You need to include import mx.core.mx_internal in project. If you look at any application like power point, word and so many they increase height based on text not width.
                           ohNew.id = "oh";
                           ohNew.width = 10;
                           ohNew.height = 20;
                           taNew.id = "ta";
                           taNew .addEventListeber(TextEvent.TEXT_INPUT,textinputEvent);
            private function textinputEvent(event:TextEvent):void
            ta.callLater( resizeText);
            public function resizeText():void
            taNew .mx_internal::getTextField().autoSize = TextFieldAutoSize.LEFT;
            taNew .height = taNew .mx_internal::getTextField().height;
            taNew .parent.height = taNew .height;
