1 Reply Latest reply on Oct 25, 2009 6:44 AM by Gregory Lafrance
    How acess data after retrieving it from a web service
    BastiaanWilderom
      I am a newbie
      I suceed in geting data from a web service am puting it in an arraycollection using the following code
      The data comes from a SQL table with 10 rows and 5 collumns.
      public mydata : ArrayColection;
      Private function datadandler(event:ResultEvent):void
      mydata=event.result.Tables.table.rows;
      My doubt now is how can I extract the data from each collumn and row of the ArrayCollection.
      I need to access one specific collumn and use the value from that collumn
      thanks in advance
        • 1. Re: How acess data after retrieving it from a web service
          Gregory Lafrance Level 6
          It depends on how the data is formed when it comes back and is put in the ArrayCollection.
          In general, you can access the 6th row of an ArrayCollection lilke this:
          myAC.getItemAt(5);
          You can loop through ab ArrayCollection like this:
          for each(var obj:Object in myAC){
            trace(obj);
          But then the question becomes how are the fields in each row of data formed?
          If the rows of data are objects, you could access the data like this:
          myAC.getItemAt(5).custName or sometimes like this:myAC.getItemAt(5)[custName]
          So it depends how you data is coming back.
          If this post answers your question or helps, please mark it as such.
