3 Replies Latest reply on Oct 25, 2009 4:08 AM by Shivik
    Passing data to TabBar control from XML
    Shivik
      Hello all
      I am trying to pass xml data to a TabBar control. The data is being loaded from an external file using the URLLoader class. I tried using the dataProvider property but couldn't get the TabBar control to display. However, I tried doing the same on ComboBox control and it displayed the data correctly.
      Can somebody please help me out. Here's my XML structure.
      <items>
           <item position="1" label="Data 1" />
           <item position="2" label="Data 2" />
           <item position="3" label="Data 3" />
           <item position="4" label="Data 4" />
      </items>
      Here's the code I am trying to work out...
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" initialize="initializeHandler(event)">
           <mx:Script>
                <![CDATA[
                     private var _dataLoader:URLLoader;
                     private function initializeHandler(event:Event):void {
                          _dataLoader = new URLLoader();
                          _dataLoader.addEventListener(Event.COMPLETE, dataLoadingCompleteHandler);
                          _dataLoader.load(new URLRequest("data.xml"));
                          XML.ignoreWhitespace = true;
                     private function dataLoadingCompleteHandler(event:Event):void {
                          var xml:XML = new XML(_dataLoader.data);
                          dataComboBox.dataProvider = xml.item;
                          dataTabs.dataProvider = xml.item;
           </mx:Script>
           <mx:VBox>
                <mx:ComboBox id="dataComboBox" labelField="@label" />
                <mx:TabBar id="dataTabs" labelField="@label" />
           </mx:VBox>
      </mx:Application>
      Thanks and Regards
      Shivik
        • 1. Re: Passing data to TabBar control from XML
          Shivik Level 1
          I tried checking for some errors and its having the following problem...
          ERROR: The dataProvider of 'dataTabs' must not contain objects of type flash.display.DisplayObject.
          What is the correct way of sending the XML data to TabBar in this case?
          Thanks and Regards
          Shivik
          • 2. Re: Passing data to TabBar control from XML
            Subeesh Arakkan Level 4
            Tabbar's dataprovider can be either String, ViewStack, Array or IList . You can convert the xml to array and set it as tabbar dataprovider or use HTTPService to read the data from xml as objects. Check the code below which is using Httpservice
                 <mx:Script>
                      <![CDATA[
                          import mx.collections.ArrayCollection;
                          import mx.rpc.events.FaultEvent;
                          import mx.rpc.events.ResultEvent;
                              dataService.send();
                       private function resultHandler(event:ResultEvent):void
                               var dp:ArrayCollection = event.result.items.item as ArrayCollection;
                               dataComboBox.dataProvider = dp;
                               dataTabs.dataProvider = dp;
                       private function faultHandler(event:FaultEvent):void
                               //handle fault here
                 </mx:Script>
                 <mx:HTTPService id="dataService" url="data.xml" resultFormat="object"
                     result="resultHandler(event)" fault="faultHandler(event)"/>
                 <mx:VBox>
                      <mx:ComboBox id="dataComboBox" labelField="label" />
                      <mx:TabBar id="dataTabs" labelField="label" dataProvider="" />
                 </mx:VBox>
            </mx:Application>
            • 3. Re: Passing data to TabBar control from XML
              Shivik Level 1
              Hello Subeesh
              Your advice was very helpful. I successfully displayed the xml using the code you gave. However using URLLoader, I am still having problems.
              Here is the code I used this time...
              <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" width="100%" height="100%" initialize="initializeHandler(event)">
                   <mx:Script>
                   <![CDATA[
                        import mx.collections.XMLListCollection;
                        private var _filterLoader:URLLoader;
                             var xmlColl:XMLListCollection = new XMLListCollection(xml.items.item);
                             var resultArray:Array = xmlColl.toArray();
                             var dp:ArrayCollection = new ArrayCollection(resultArray);
                   </mx:Script>
                   <mx:VBox>
                        <mx:TabBar id="filterTabs" labelField="label" />
                   </mx:VBox>
              </mx:Application>
              It displays nothing. Debugging mode shows this error....
              TypeError: Error #1034: Type Coercion failed: cannot convert XMLList@17947f91 to Class.
                   at mx.controls::NavBar/createNavChildren()[C:\autobuild\galaga\frameworks\projects\framework\src\mx\controls\NavBar.as:904]
                   at mx.controls::NavBar/commitProperties()[C:\autobuild\galaga\frameworks\projects\framework\src\mx\controls\NavBar.as:688]
                   at mx.controls::ButtonBar/commitProperties()[C:\autobuild\galaga\frameworks\projects\framework\src\mx\controls\ButtonBar.as:481]
                   at mx.controls::ToggleButtonBar/commitProperties()[C:\autobuild\galaga\frameworks\projects\framework\src\mx\controls\ToggleButtonBar.as:329]
                   at mx.core::UIComponent/validateProperties()[C:\autobuild\galaga\frameworks\projects\framework\src\mx\core\UIComponent.as:5807]
                   at mx.managers::LayoutManager/validateProperties()[C:\autobuild\galaga\frameworks\projects\framework\src\mx\managers\LayoutManager.as:539]
                   at mx.managers::LayoutManager/doPhasedInstantiation()[C:\autobuild\galaga\frameworks\projects\framework\src\mx\managers\LayoutManager.as:659]
                   at Function/http://adobe.com/AS3/2006/builtin::apply()
                   at mx.core::UIComponent/callLaterDispatcher2()[C:\autobuild\galaga\frameworks\projects\framework\src\mx\core\UIComponent.as:8733]
                   at mx.core::UIComponent/callLaterDispatcher()[C:\autobuild\galaga\frameworks\projects\framework\src\mx\core\UIComponent.as:8673]
              What's going wrong in this code?
              Thanks and Regards
              Shivik
