3 Replies Latest reply on Oct 23, 2009 7:43 AM by the_wine_snob
    Can PPRO CS4 and PE8 on the same PC .
    Anthony Abegglen Level 1
      The reason I want to know is ,I have just upgrade from CS2 to CS4 I miss the DVD auothring app that I had in CS2 and the PE8 would be more than enough for my need.thank
        • 1. Re: Can PPRO CS4 and PE8 on the same PC .
          Allen Joy
          I dont think there would be any problem.I am using both the versions and they co-exist fine
          • 3. Re: Can PPRO CS4 and PE8 on the same PC .
            the_wine_snob Level 9
            The only issue, of which I am aware, was with CS2 Production Studio and the addition of PrE 4. Obviously, Adobe did not anticipate that folk might have the former, and then install the latter. When I did, I found that there was already an Adobe KB Article on the problems. PrE 4 broke most of the CS2 Production Suite, but a simple Repair Install took care of it. I was up and running in about 1 hour (after I found my CS2 Production Studio discs).
            Now, two things to take into account: CS4 is still current and PrE 8 is new. The majority of users would be going from PrE to PrPro, and not the other way around (as I did with PrE 4). Reports might not have come in yet, if there are issues. To date, I have seen none in either the PrE, or the PrPro forum, and I read almost every post in each.
            If there is an issue, I would anticipate that the old "cure," of a Repair Installation, would fix things again. However, after the CS2 vs PrE 4 thing, I believe that Adobe has thought about all situations with CS4 and PrE 8, but could be wrong.
            Good luck, and sorry that I do not have the definitive answer for you,
