7 Replies Latest reply on Nov 6, 2009 5:11 AM by erthy
    Problem with text field .text atribute.
    erthy
      Hey,
      I had a mx:Text element and I put it onto a canvas for a tabbing system and now, my notation element.text="bla bla bla"; doesn't work. What am I doing wrong?
      Code below.
      <mx:WindowedApplication xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" initialize="otevritSlovnik()" width="1000" backgroundGradientAlphas="[1.0, 0.0]" backgroundGradientColors="[#FFFFFF, #6F8DFF]" height="360">
      <mx:Script>
           <![CDATA[
                import mx.controls.Text;
                import flash.filesystem.*;
                import mx.controls.Alert;
                import mx.controls.List;
                     // public var slovnikFile:File;
                     public var slovnikFile:File = File.applicationDirectory.resolvePath("slovnik.xml"); // The preferences prefsFile
                     [Bindable] public var slovnikXML:XML; // The XML data
                     [Bindable] public var addXML:XML;
                     private var pocet_slovicek:int;
                     private var maximum:int;
                     private var cislo_slovicka:int;
                     private var slovicko_1:String;
                     private var slovicko_2:String;
                     private var zkousim_z:int;
                     private var pocet_vyzkousenych:int;
                     private var vyzkousene:Array = new Array;
                     private var vysledky_do_streamu:String = "pes";
                     private var zkousi_se:Boolean;
                     public var stream:FileStream; // The FileStream object used to read and write prefsFile data.
                private function otevritSlovnik():void
                     stream = new FileStream();
                     if (slovnikFile.exists) {
                         stream.open(slovnikFile, FileMode.READ);
                         slovnikXML = XML(stream.readUTFBytes(stream.bytesAvailable));
                          stream.close();
                          vytahnout_udaje();
                     else
                         Alert.show("Nenalezeny žádné slovníky!");
                private function vytahnout_udaje():void{
                     var jmeno_slovniku:String = slovnikXML.info.jmeno;
                     var verze_slovniku:String = slovnikXML.info.verze;
                     var autor_slovniku:String = slovnikXML.info.autor;
                     var jazyk1_slovniku:String = slovnikXML.info.jazyky.@lang1;
                     var jazyk2_slovniku:String = slovnikXML.info.jazyky.@lang2;
                     var web_slovniku:String = slovnikXML.info.web;
                     var poznamka_slovniku:String = slovnikXML.info.poznamka;
                     var udaje_o_slovniku:String = "Jméno slovníku: " +jmeno_slovniku+
                                                          "\nVerze: "+verze_slovniku+
                                                          "\nAutor: "+autor_slovniku+
                                                          "\nWeb: "+web_slovniku+
                                                          "\nJazyk1: "+jazyk1_slovniku+
                                                          "\nJazyk2: "+jazyk2_slovniku+
                                                          "\nPoznámka autora: "+poznamka_slovniku
                     info_o_slovniku.text=udaje_o_slovniku;
                public function ask (slid:int, lang:String):String {
                     if (slovnikXML) {
                          var slovicko:String = slovnikXML.slovicka.slovicko[slid].@[lang];
                          return slovicko;
                     else {
                          var chyba:String = "ff";
                          return chyba;
                public function dalsi_slovicko():void {
                     if (pocet_vyzkousenych == 0 || pocet_vyzkousenych < zkousim_z){
                          cislo_slovicka = randomNumber(0, maximum);
                          if (vyzkousene.indexOf(cislo_slovicka)==-1) {
                               slovicko_1 = ask(cislo_slovicka, "en");
                               slovicko_2 = ask(cislo_slovicka, "cs");
                               slovicko1.text = slovicko_1;
                               nazor.text ="";
                               pocet_vyzkousenych++;
                          else {
                               dalsi_slovicko();
                     else {
                          Alert.show("Vyzkoušení proběhlo úspěšně! \n"+"Počet vyzkoušených slovíček: "+pocet_vyzkousenych+"\nZkoušelo se z: "+zkousim_z);
                          last();
                public function last():void {
                     slovicko1.text = "Great!";
                     nazor.text = "Výborně!";
                     odeslat.label="Zkoušej!";
                     zrusit.enabled=false;
                     slovicko1.enabled=true;
                     nazor.enabled=true;
                     nazor.editable=false;
                     zkousi_se=false;
                public function zkousej():void {
                     zkousi_se=true;
                     odeslat.label="Odeslat!";
                     zrusit.enabled=true;
                     nazor.enabled=true;
                     nazor.editable=true;
                     pocet_vyzkousenych = 0;
                     vyzkousene = new Array;
                     pocet_slovicek = slovnikXML.slovicka.elements("*").length();
                     maximum = pocet_slovicek-1;
                     zkousim_z = maximum+1;
                     if (zkousim_z > maximum+1) {
                          Alert.show("Chcete se nechat vyzkoušet z více slovíček, než vybraný slovník obsahuje. E-e!");
                     else {
                          dalsi_slovicko();
                public function kontrola() : void {
                          if (nazor.text == slovicko_2) {
                               vyzkousene.push(cislo_slovicka);
                                dalsi_slovicko()
                          else {
                               Alert.show("Špatně!! \n\nSprávně jste měli napsat: " + slovicko_2);
                private function randomNumber(low:Number=NaN, high:Number=NaN):Number
                     var low:Number = low;
                     var high:Number = high;
                     if(isNaN(low))
                         throw new Error("low must be defined");
                       if(isNaN(high))
                             throw new Error("high must be defined");
                       return Math.floor(Math.random() * (1+high-low)) + low;
                private function odeslat_click(evt:MouseEvent):void {
                       if (zkousi_se==true) {
                               kontrola();
                          else {
                               zkousej();
                  private function zrusit_click(evt:MouseEvent):void {
      </mx:Script>
           <mx:ViewStack x="10" y="44" id="viewstack1" width="960" height="310">
                <mx:Canvas label="Zkoušení" width="100%" height="100%" id="zalozka_zkouseni" backgroundColor="#FFFFFF" color="#000000" borderColor="#919191">
                     <mx:Panel x="10" y="10" width="250" height="284" layout="absolute" title="Údaje o slovníku:" id="slovniky">
                          <mx:Text x="10" y="10" width="210" height="224" id="info_o_slovniku"/>
                     </mx:Panel>
                     <mx:Panel x="585" y="10" width="362" height="284" layout="absolute" id="panel_vysledky" title="Výsledky:">
                          <mx:List y="10" width="322" height="224" id="vysledky_stream" dataProvider="vysledky_do_streamu" enabled="true" x="10"></mx:List>
                     </mx:Panel>
                     <mx:Panel x="268" y="10" width="309" height="284" layout="absolute" id="main_alternate" title="Zkoušení:">
           <mx:Form id="main_form" x="10" y="10" width="269" height="224" defaultButton="{odeslat}">
              <mx:FormItem width="100%">
                  <mx:TextInput id="slovicko1"  width="100%"/>
              </mx:FormItem>
                  <mx:TextInput id="nazor"  width="100%"/>
              </mx:FormItem>
              <mx:FormItem direction="horizontal"
                      horizontalAlign="center"
                      width="100%" height="47">
                  <mx:Button id="odeslat"
                          label="Zkoušet!"
                          click="odeslat_click(event);"  fontSize="25" textAlign="center" labelPlacement="top"/>
              </mx:FormItem>
              <mx:FormItem>
                   <mx:Spacer/>
              </mx:FormItem>
                      horizontalAlign="right"
                      width="226" height="26">
                  <mx:Button id="zrusit"
                          label="Reset"
                          click="zrusit_click(event);"  textAlign="center" labelPlacement="right"/>
              </mx:FormItem>
          </mx:Form>
                     </mx:Panel>
                </mx:Canvas>
                <mx:Canvas width="100%" height="100%" id="zalozka_about" label="O programu">
                     <mx:TextArea x="228" y="10" width="722" height="290" id="changelog" text="Slovíčka - Changelog&#xa;&#xa;0.0.3 - zvětšena tlačítka, přidán panel s údaji o slovníku a panel s logem (nefunkční)&#xa;0.0.2 - paměť na vyzkoušená slovíčka, vylepšení vzhledu&#xa;0.0.1 - základní funkce programu" textAlign="left" fontSize="15"/>
                </mx:Canvas>
           </mx:ViewStack>
           <mx:TabBar x="10" y="21" dataProvider="viewstack1" width="502" height="26">
           </mx:TabBar>
      </mx:WindowedApplication>
