0 Replies Latest reply on Oct 23, 2009 4:35 PM by GordonSmith
    [svn:fx-trunk] 11118: Did some code cleanup on the Spark components to enforce the conventions about how to order stuff within an AS file .
    GordonSmith Level 4
      Revision: 11118
      Author:   gosmith@adobe.com
      Date:     2009-10-23 16:35:38 -0700 (Fri, 23 Oct 2009)
      Log Message:
      Did some code cleanup on the Spark components to enforce the conventions about how to order stuff within an AS file.
      QE notes: None
      Doc notes: None
      Bugs: None
      Reviewer: None; no functional changes
      Tests run: ant checkintests
      Is noteworthy for integration: No
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/ButtonBar.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/CheckBox.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/DropDownList.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/List.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/NumericStepper.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Panel.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/RadioButton.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Spinner.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/TextArea.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/TextInput.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/ButtonBase.a s
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/ListBase.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/SkinnableTex tBase.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/Slider.as
