13 Replies Latest reply on Oct 27, 2009 2:56 AM by Ron Colmen
    Combine 2 in to one.
    Ron Colmen Level 2
      How combine write a script to pass a valuve from flash to php and load xml results with the onRelease command?
      1
      sender.onRelease = function () {
      senderLoad.fin = fin.text;
      senderLoad.sendAndLoad("www.abc.com/myphp.php",receiveLoad);
      receiveLoad.onData = function (src) {
      tf.text=src
      2
      var fax:Array = new Array();
      var tel:Array = new Array();
      var company:Array = new Array();
      x:onLoad (www.abc.vom/myphp.php, onFinish);
      function onFinish($success:Boolean, $results:Object, $xml:XML):Void {
      if ($success) {
        • 1. Re: Combine 2 in to one.
          if xml is being returned from your php script, you only need 1.  just cast that return (src) as xml:
          var xml:XML;
          xml=new XML(src);
          parseXML(xml):
          function parseXML(xml:XML){
          // parse your xml here
          • 2. Re: Combine 2 in to one.
            Ron Colmen Level 2
            Thank you sir! That was helpful.
            Results displayes as 'undefined' and no image. Attached is just a screenshot of the php output (when run in the browser).
            The current  script.
            xml=new XML(src);
            parseXML(xml);
            emb.loadMovie(image)= $results.image[0].value;;
            comp.text = $results.company[0].value;
            tf.text = $results.email[0].value;
              gotoAndPlay(10);
            • 3. Re: Combine 2 in to one.
              Ron Colmen Level 2
              I'm getting all text fields 'undefined' and there's no image appearing. My prase seems to be incorrect. I've red many on prasing xml over the net but I don't seem to get how to match them here according to my requirements ($fin).
              • 4. Re: Combine 2 in to one.
                what's the following show:
                xml=new XML(src);
                parseXML(xml);
                tf.text = xml;
                • 5. Re: Combine 2 in to one.
                  Ron Colmen Level 2
                  it brings up the entire thing.
                  <?xml version="1.0" encoding="utf-8"?><item><email>abc@abc.com</email><image>http://www.abc.com/ruth.jpg</image><datecreated>2009-10-25 05:10:49</datecreated><company>FOR TESTING PURPOSE</company><address>can, roxy, country</address><phone>7-1400-2070</phone><fax>1-2345-6789</fax><genemail>abc-gen@mail.com</genemail></item>
                  I kept on searching simple examples for xml prasing over the net and I can not find any which would help my requiremnt. I'd like to have each item in seperate dynamic text boxes and the image to load in to a movieclip.
                  • 6. Re: Combine 2 in to one.
                    use:
                    function parseXML(){
                    tf.text=this.firstChild.firstChild.nodeValue;
                    whatever.loadMovie(this.firstChild.firstChild.nextSibling.nodeValue);
                    • 7. Re: Combine 2 in to one.
                      Ron Colmen Level 2
                      I'm still getting 'undefined' and no image displayed??
                      xml=new XML(src);
                      parseXML(xml);
                        compa.text=this.firstChild.firstChild.nodeValue;
                        addres.text=this.firstChild.firstChild.nodeValue;
                        fasci.text=this.firstChild.firstChild.nodeValue;
                        phone.text=this.firstChild.firstChild.nodeValue;
                        geneml.text=this.firstChild.firstChild.nodeValue;
                        emb.loadMovie(this.firstChild.firstChild.nextSibling.nodeValue);
                        gotoAndPlay(10);
                      • 8. Re: Combine 2 in to one.
                        don't nest parseXML().  use the code i gave.
                        • 9. Re: Combine 2 in to one.
                          Ron Colmen Level 2
                          Nothing changed. I'm still getting 'undefined' in all the fields and nothing in the movieclip.
                          PHP alone in browser displays as
                          tf=abc@ghi.comcompa=FOR TESTING-PURPOSEaddres=city,cityfasci=1-2345-6789phone=7-1400-2070geneml=abc@mail.comemb=http://www.bac.com/database/ruth.jpg
                          xml=new XML(src);
                          parseXML(xml);
                            gotoAndPlay(10);
                          PHP
                          if($line = mysql_fetch_assoc($results)){
                          echo "tf=".$line["email"];
                          echo "compa=".$line["company"];
                          echo "addres=".$line["address"];
                          echo "fasci=".$line["fax"];
                          echo "phone=".$line["phone"];
                          echo "geneml=".$line["genemail"];
                          echo "emb=".$line["logo"];
                          • 10. Re: Combine 2 in to one.
                            it still looks like you're nesting parseXML()
                            • 11. Re: Combine 2 in to one.
                              Ron Colmen Level 2
                              You mean like this? Still not getting the text & image.
                              xml=new XML(src);
                              parseXML(xml);
                                gotoAndPlay(10);
                              • 12. Re: Combine 2 in to one.
                                no.
                                xml=new XML(src);
                                parseXML(xml);
                                  {  //<--what's this for?
                                  gotoAndPlay(10);
                                  }  // <-- what's this for?
                                • 13. ENDS!
                                  Ron Colmen Level 2
                                  Thanks Sir! I got it working!!
