1 Reply Latest reply on Oct 26, 2009 12:57 PM by Flex harUI
    Need conceptual help with embedding flash with flex
    DaveFastFingers Level 1
      I have been learning flex UI design for some time, and have a decent grasp of it using FlexBuilder. But I haven't played with flash animations at all.
      If someone else builds a flash animation (FLA or SWF file right?) and I want to embed and display those in flex... I'm a little fuzzy on how that works, and would like some help with the conceptual understanding.
      For example, if someone built a flash intro and login page purely in flash (no flex components at all). How does the logic work? And how would I incorporate that into what will then be a flex app after the login page?
      I'm trying to understand the following scenario:
      1) flash intro sequence
      2) flash only user login form (no flex ui components on the login page, is this even possible? I think so)
      3) login calls a function which handles server login communication and either:
         a) loads a flex component/application on success
         b) runs a different flash animation sequence
      How do the different animation sequences work? Are animation sequences something I can call from a function in actionscript? I'm not clear how these work at the most basic conceptual level.
      How do I embed and run this sequence of flash animations in my actionscript environment?
      David
