0 Replies Latest reply on Oct 25, 2009 11:40 PM by sy_ascafe
    addEventListener does not work anymore after re-creation of element of same id?
    sy_ascafe
      My script works as follow (simplified), and the addEventListener does not work after re-create of element of same id.
      Am I making any mistake and so cause it failure to work?
      ( I have repeated declare var el here, please just ignore it )
      // creating a div container
      var el = document.createElement('div');
      el.id = 'div1';
      document.body.appendChild(el);
      // then a childnode
      el.id = 'div1_1';
      document.getElementById('div1').appendChild(el);
      document.getElementById('div1_1').addEventListener('click', eventHandler, true); // works fine
      // then try a remove event test
      document.getElementById('div1_1').removeEventListener('click', eventHandler, false);
      document.getElementById('div1_1').addEventListener('click', eventHandler, true); // fine, eventHandler run once only
      // remove event test works fine
      // and sometimes I need to remove all the nodes and event, and create the element with same id and attach event again
      var el = document.getElementById('div1_1');
      el.removeEventListener('click', eventHandler, false); // by referring the test above,  it should be work fine ...
      air.trace(document.getElementById('div1').childNodes.length)  // output 1 (no child nodes under div1_1)
      el.parentNode.removeChild(el);
      air.trace(document.getElementById('div1').childNodes.length) // output 0. ok, all nodes removed
      // create a childnode again
      el.id = 'div1_1';
      air.trace(document.getElementById('div1').childNodes.length)  // fine, output 1, html also display correctly
      document.getElementById('div1_1').addEventListener('click', eventHandler, true); // but nothing happened here
