5 Replies Latest reply on Oct 27, 2009 2:40 AM by Pareek fx
    Draw String using graphics ?????
    Pareek fx
      Hi all,
      I need to have text displayed on a sprite.Can we draw strings as graphics in flex, the way we do it in .NET using drawString
        • 1. Re: Draw String using graphics ?????
          Daniel Freiman Level 1
          The easiest way to render text is to add a flash.text.TextField to the
          Sprite.  (The flash.text.engine package is newer, more powerful, and would
          also work but is more complicated.)  Check the livedocs for the specific
          version of flex you're using.  And remember, TextFields don't size
          themselves so you need to set the width and height explicitly.  There is no
          way to do this by going directly at the graphic object (without manually
          creating a font renderer yourself).
          - Daniel Freiman
          • 2. Re: Draw String using graphics ?????
            Pareek fx Level 1
            Thanks Daniel,
            I am using the same for now..But in this case I am avble to dispatch the
            events related to the graphics object to which th TextField sprite is added.
            we draw a polygon ,then add a textfield to it in the way as described by
            you.But by doing so we are not able to dispatch the roll over event
            associated with the polygn to which the Text Field is added.
            Any idea to this...
            Thank You
            2009/10/26 Daniel Freiman <forums@adobe.com>
            - Daniel Freiman
            • 3. Re: Draw String using graphics ?????
              If the TextField is not interactive (the user can't edit or select the text)
              set the mouseEnabled=false.  I think this should make the mouse act as if
              the textfield weren't there.  The other option would be to create a sprite,
              draw the polygon on that sprite, and then place the polygon on top of the
              textfield.
              - Dan
              • 4. Re: Draw String using graphics ?????
                Pareek fx Level 1
                Daniel, we have tried using mouseEnabled=false,but it doesn't works.
                Using the second option suggested by you will make the TextField invisible .
                As the polygon placed over it will hide it after filling the polygon with
                some color.
                Thanks a ton for replying
                We'll wait for your response.
                Thank you
                2009/10/27 Daniel Freiman <forums@adobe.com>
                text)
                textfield.
                - Dan
                • 5. Re: Draw String using graphics ?????
                  Pareek fx Level 1
                  Hi Daniel,
                  Thanks  a lot.
                  We worked a bit on the code after u r advice abt. mouseEnabled property and
                  finally we have resolved the issue.
                  We assigned mouseEnabled,mouseChildren and buttonmode property as false on
                  the sprite of which text field was a child.
                  This way we achieved what was required.
                  Thanks a ton
                  Pareek
                  2009/10/27 manish pareek <manish.deepak@gmail.com>
                  some color.
                  Thank you
                  >> text)
                  >> sprite,
                  >> textfield.
                  >> - Dan
